Question about GE Profile J2B918CEK / J2B918WEK / J2B918BEK Dual Fuel (Electric and Gas) Kitchen Range
Control console display is blank (like no power). Main oven is controlled by this console, therefore is not working. Lower oven (electric) has knob on front of range and still works.
  • 61 Answers
Bad board when you are sure of the part you need check out Appliance Parts Solutions they have good prices on parts. good luck
Posted on Feb 10, 2010
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
Maytag cwe4800acb oven shuts off and display goes blank during heating
Display on maytag oven 8114p471-60 went blank - Fixya
www.fixya.com/.../t16018814-display_maytag_oven_8114p471_60_we...
Jan 20, 2013 - Stove top electric ignition still works fine, so there is power going to the .... maytag cwe4800acb oven shuts off and display goes blank during .
Oct 10, 2015 | Maytag CWE4800ACB 2.6 cu. ft. 24" Single...
I have a Jenn Air JJW9830DDP double oven electric, and the temperature in the oven is about 100' less than what it reads on the display. I tested the temp sensor and it ready 1073 ohms. Any s
Well, your temp sensors can still be bad. If not, there's always a new control board you buy!
However, I wouldn't drink water from that oasis without making ABSOLUTELY sure I'm not seeing a mirage.
The only common denominators between your upper and lower oven temp readings is the firmware and the oven thermometer you are using to visually check the temps.
What type of thermometer are you using to check your oven temperatures with?
If it's not a digital thermometer used specifically for testing ovens, you might just be leading leading yourself astray.
You need a calibrated thermometer. If I don't have a calibrated digital thermometer on me, I use two or three oven thermometers (the dial type) and average the readings.
It's the only way to be as close as possible with a digital probe.
If you have thoroughly verified that your oven is in fact not reading the correct temperature, then you can adjust it +/- 35 degrees F via your oven's control panel.
To adjust the oven temperature:
1 - Press Setup pad.
2 - Select the down arrow to scroll to the next screen.
3 - Select Temp Adjust using the Quickset pads.
4 - Select upper or lower oven (select models).
-"Set temperature offset using the Upper Set Knob" is displayed.
5 - Enter the desired temperature change using the Set knob.
The temperature can be increased or decreased up to 35 degrees.
The temp. change is displayed at the top of the window.
6 - Press the Set knob to accept the change.
Now, if you are still worried about the temp. reading being off, replace both the upper and lower temp sensors. That's all you can do besides replace the main board.
Oct 24, 2014 | Jenn-Air JJW9830D Electric Double Oven
Keypad/clock went blank
Normally when a power surge lands a direct hit on a non protected circuit board, it will usually fry it completely. you can confirm this by shutting down the power for 5 minutes. if the control doesn't respond after the 5 minutes of no power, this will confirm circuit failure due to the surge and, you will need to replace the board in this case.
May 18, 2009 | Maytag CWE5800A Electric Double Oven
Oven blows main switch
There is a short circuit between the lower oven control and the lower element.
Disconnect the lower element. Put electrical tape on the loose terminals and turn the lower oven on.
If it does not blow, replace the lower element with a new element.
If it does blow, Check the wiring to the lower element for continuity to the frame of the range.
If you get continuity replace the damaged wire..
Finally, check the control knob switch for continuity to ground on the frame of the oven.
Mar 20, 2009 | Ovens
Display is blank, no heat no bake
The oven control panel has failed. For more tech help with this issue and a place to order parts I suggest you go the link below, it is where I go for parts and help. You will need to model number available. Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Jun 28, 2017 | GE Monogram ZET3058SHSS Stainless Steel...
The touch pad panel on stove is blank
on the ge range, you need an ERC its the main control for the oven. yes its costly. comes in a kit with a new wire harness
Nov 16, 2007 | GE Profile JGSP48 Gas Kitchen Range
Display no longer works
Yes, I see this but it isn't real common.  The control board (eoc) will have to be replaced.  Most of them are costly.  If you give me the complete model # from the sticker on the oven (may be behind bottom drawer) I can check into this better for you and get you a price.
Oct 18, 2007 | GE Profile JS998 Kitchen Range
Display doesn't work, but oven works
First turn the electricity off by locating the breaker to the oven and turn it off. Now wait for an hour or so and turn the breaker back on, if the display turned back on, you need a control board (other manufatures call it a clock, PCB or ECC but it's the main elctronic board with the diaplay built in). If it didn't come back on, turn the power off again and make sure all the wire harness's going to the board are connected good. Turn the power back on and it the display still doesn;t come back on you need to replace the main electronic control board. By the way double check the model number and brand because it might be wrong. Please post back.
Oct 04, 2006 | Whirlpool RBD275PD Electric Double Oven
Kitchen Ranges Logo
141 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
