Question about Electrolux Vacuums
My electrolux sidekick, model 1562 makes a nasty screeching sound.It happens as soon as it is powered on,the noise then gets intermittent after qa few minutes and then goes away.This cycle is repeated evry time i use it.I have checked it for binding and obstructions and oiled the motor.I think it's the roller brush but oiling it didn't seem to help
  • 126 Answers
SOURCE: Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Posted on Jan 27, 2008
SOURCE: Roller/sweeper on my Electrolux Pronto
After 3 years my Pronto slowed down and needed new batteries. I just replaced all 8 internal batteries. It cost just under $30 with shipping and took 1 hour of soldering. If you're not handy with a soldering iron, don't attempt it. All of the batteries are soldered together in series. You need to order the 8 (4/5 Sc size, 2000 mAh) Nickel metal hydride (Ni-MH) batteries with tabs. The source I used was www.BatteryJunction.com. Here's a link to the battery page: http://www.batteryjunction.com/tenergy-45th-sc-1-2-2000-tabs.html
PS The vac now runs GREAT!
Russ
Posted on Jul 18, 2009
  • 143 Answers
SOURCE: Hello. My dyson dc04 keeps making a loud screeching noise.
remove base cover by 3 'screws' 1/2 turn anti clockwise and clean well remove fibres replace cover and re try.
Posted on Sep 14, 2009
Vac Belts
  • 701 Answers
SOURCE: Older Dyson 07 Animal, loud ratcheting noise on carpet setting
That is an indication that the belts are worn, stretched or broken. You simply need to replace the belt. Here is a link to the belt(s) you need and a manual you can view:
Dyson DC07 Belts and Manual
Posted on Dec 05, 2009
Vac Belts
  • 701 Answers
SOURCE: Roller brushes on vacum won,t turn and vacum makes
You need to replace the belt. Here is the belt you need and the manual:
Bissell Healthy Home Belt and Manual
Posted on Jan 09, 2010
My Dyson DC14 Animal has begun to make an awful squealing/screeching noise. The beater bar is functioning well and there does not seem to be a loss in suction. The nasty sound happens with and with o
Hi there, it's Jack at Dyson.
An unusual noise like this can often be caused by something simple, like a part or a seal slightly out of position. I appreciate you've checked your DC14 thoroughly for issues, but we're usually able to diagnose the cause most effectively by listening to the machine over the phone.
When you have your DC14 easily to hand, I would encourage you to give the Dyson Customer Helpline a call to speak with our experts. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Feb 15, 2015 | Dyson DC14 Animal Bagless Upright Cyclonic...
Vacuum attachment problem
The roller brush assembly has to most likely be replaced or at least cleaned and lubed but better off just to replace it.
With 30 yrs. experience dealing almost exclusively with the original Electrolux, I have a legitimate store front business and do service by mail at a reasonable cost if interested. mickeymackmark1@yahoo.com
Hope that helps! Mick
Feb 01, 2014 | Electrolux Sidekick Ii Upholstery Power...
My upright electrolux persicion vacuum when turned on just makes a horrible sound both on bare floor and on carpet brush does not turn
Hi, sounds like you need a new belt or brush and bearings . Sometimes when a belt goes it makes a bad noise as one of the belt teeth make be worn out. Hope this helps.
Jan 22, 2014 | Electrolux Vacuums
Hi, my dc07 cleaner has developed a very high pitch screech its not a constant sound but intermittent and last for a second or two and is very unpleasent, its a loud cleaner anyway but this noise is so...
hi.
it sounds like the bearings in the motor are worn out. the only solution is to change the motor, or the entire hoover. motors are available from ebay for about £35 and it will then need to be fitted. unfortunately these bearings do wear out eventually. once they start to make screeching noises like this, there is not much life left in them, and they will get worse rapidly.
if you decide to change the motor yourself, please feel free to ask for more details on how to do it.
hope this helps
Aug 16, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My electrolux Epic 6500 power nozzle Model N109J will not work. It had an intermittent short which I thought I fixed (some of the insulation on the wires were pinched). I fixed the wires and it worked...
The switch is definitely a possibility, but other problems can also cause this.
Bad switch, needs replaced.
Broken wiring in power nozzle, wands, hose, or canister.
Bad PN motor.
I strongly recommend taking it to the nearest authorized Aerus Electrolux store for a diagnosis (should be free). Allowing them to do any repairs necessary is recommended, as well. This will ensure it's done correctly.
http://www.aerushome.com/storelocator/
Feb 23, 2011 | Electrolux Epic 6500 Vacuum
We have an electrolux central vac. The power head won't turn on. It has a 3 way switch on the handle. When to the left it is just air for the floor. center is off and to the right is the power head. ...
I assume you did press the reset switch on the power nozzle. If so, there are a number of things that could cause this. To rule out the hose and power switch, connect the Sidekick (if you have one) to the handle. Turn vacuum on. If the sidekick runs, the problem will be in the wands or power nozzle. Try connecting the power nozzle directly to the hose. If it runs, the problem is the wiring connections in the wands, or from the lower wand to the power nozzle. Check all connections for discoloring and broken or cracked wand fittings.
The wiring in the elbow of the PN is a fairly common problem, especially with certain models. A piece inside breaks, resulting in the wire connection to not make contact. No contact means the PN motor won't run. And there's always the possibility that the PN motor is bad.
If the Sidekick doesn't run when connected directly to the hose, the switch could be bad, the wiring in the hose could have broken, which is another common problem in older hoses, or the ECV board in the vacuum could be bad.
If the problem hasn't been resolved at this point, it's best to take the entire machine to the Aerus Electrolux store near you for a free diagnosis.
Jan 07, 2011 | Electrolux Central Vacuum
Loud 'drilling' noise from motor area when turned on.
Sounds like bad bushings/bearings in the motor -- need to replace them.
May 27, 2009 | Electrolux Vacuums
Vacuums Logo
291 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
