wikiHowhttps://www.wikihow.com > ... > Jewelry > Watches
10 steps
1.
Read the labels on the 4 buttons on your watch. If you can't look up a manual right now, you can probably figure out how to change the time with some simple ...
2.
Press the "Mode" button or hold it down until the time flashes. The minutes or hours of most digital watches blink when you're in the time setting mode. On ...
3.
Use the "Start/Stop" button to change the individual numbers. Once you get the minutes or ho
hi Claude. Press and hold the "Adjust" button to until the "Time" digits begin to flash. Use the "Start/Stop" and "Split/Reset" buttons to set your digital watch to the correct hour and minute increments. Press "Mode" to display the "Date" setting screen.31 Mar 2015
How do u set a digital watch?In normal time mode, Hold L2 for 2 seconds to alarm time set mode, then L2 again to normal time set mode, the second digits begin flashing. Press R2 to reset the seconds to "00", press R1 to switch to the minute digits. Press R2 to advance the minutes. Press R1 to switch to the hour digits.4 Button Digital Watch - Dakota Watchhttps://www.dakotawatch.com/PDF_FILES/Digital.pdfSearch for: How do u set a digital watch?
Hold top button 3to5 seconds until display starts to flash then use bottom button to scroll through menu and top button to adjust.once set up hold bottom button 3to 5 seconds.you may need to try this reverse as some digital displays are Chinese and things get back to front.
? 1:13
https://www.youtube.com/watch?v=4FmHYMeXbDA
Oct 26, 2011 - Uploaded by Vedant Sen
https://www.youtube.com/watch?v=u_H5I3H15R8 ... how to setyour digital watch {UPDATED} - Duration: 1:20. by Vedant Sen 3,424 views ... The 10 Greatest Wrist Watches of all Time REVISED FOR 2014 - Part 1 - Duration: ...
? 8:40
https://www.youtube.com/watch?v=kBvaePDtEUU
Jun 27, 2012 - Uploaded by Pitskate
How To Change The Time On Most Digital Watches. Pitskate ...How to change / set time on Armitron watch, 45/7004. - Duration: 2:02. by ...
Thanks for contacting FixYa.
Instructions generally dont tell you how to change batteries.
I would highly recommend you take to a watchmaker/ jeweler to have this done with the right equipment.
Jewel
Press and hold the "Mode" button on the right side of your Arnette digital watch for three seconds to change the watch's mode. Press and hold the "Mode" button repeatedly until flashing digits indicate that you have entered the watch's time-setting screen.
Use the top and bottom buttons on the left side of your Arnette digital watch to increase and decrease number values as desired.
Press and hold the "Mode" button repeatedly to exit the time-setting screen and return the watch to time-telling mode.
Set Analog Watch
Pull out the watch crown on the right side of your Arnette analog watch.
Turn the watch crown clockwise to adjust the hands of your Arnette analog watch to the appropriate time.
Push the watch crown back in when you are finished setting the time on your Arnette analog watch.
I haven't been able to find instructions for your watch but since most watches operate in a similar manner try the following:- (I assume that your watch had an lcd screen.)
Press the mode button until you reach the alarm setting feature, "AL"? there may be one feature that is specifically for hour repeat "HR"? use one of the other buttons to turn it from "ON" to "OFF".
Press the mode button to return to normal operation.
