Question about Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
How do you clean out the baffles filled with lint in the Whirlpool Duet dryer?
  • 5,911 Answers
To remove the dryer drum baffles on a Whirlpool Duet, follow these steps:
1. UNPLUG the dryer.
2. Remove the top panel of the appliance by removing the screws that hold the panel in place in the rear of the dryer. With the screws removed, the panel will slide back, then lift off.
3. Locate the bolts that hold the baffles in place on the outside perimeter of the drum. There should be 2 for each one.
4. Remove the screws for the baffle and it will come off.
HELPFUL HINTS:
1. Remove ONE baffle at a time so you can use the remaining baffles to turn the drum manually.
2. Drum rotates in a clockwise direction.
3. When removing or reinstalling each baffle, duct taping it place will keep it from flipping around when you get to the last bolt holding it in place. It will also keep it from dropping in the drum when removing, and help you hold it in place to reinstalling.
If you have any questions, please let me know. I hope this helps you.
Posted on Feb 07, 2010
How do I clean lint from the Whirlpool dryer baffles?
Are you talking about the baffles on the drum ?
Jan 07, 2015 | Whirlpool Dryers
How do I fix the noise coming from the dyer bin
depends bad rollers? bearings? baffle is filled with junk? something stuck in blower?
Sep 05, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a whirlpool duet model gew9250pw1 dryer it gets good and hot put when the cycle is done some of the clothes are still damp.i not sure if it is the timer or a censer. i know when we start it the...
Look for an airflow blockage. Be sure lint filter is cleaned and if lint is accumulated in the air stream path, take a vacuum or brush and clean it out. Dirt and lint are a dryer's worst enemy.
Mar 17, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Hair/Lint collecting on the Baffles of the dryer
I once heard you can periodically spray "Spray Starch" on the baffles themselves to alleviate lint and hair buildup. If you can prevent the unwanted particles from building up on the baffles theoretically they should be trapped in the dryer's lint collector.
Mar 01, 2010 | Whirlpool Dryers
Lint has built up inside the 3 plastic fins of Whirlpool Duet
What is the model Number. Does your lint screen go thru the top or is it in the door.
Jan 31, 2010 | Whirlpool Dryers
I have Whirlpool Duet Dryer that has a noise.
It is common for small items (such as coins) to get stuck inside the dryer drum baffles. You can easily remove them without disassembling the entire dryer. The screws that hold them in place are located on the outside of the dryer drum. In order to access, follow these steps:
1. Unplug the dryer.
2. Remove the top panel of the dryer by removing the three screws located in the back of the dryer holding the panel in place. Once the screws are removed, the top panel slides back, then lifts off.
Each drum baffle has two screws holding it in place. Remove the screws and the baffle will drop into the drum allowing you to easily check inside each one.
Another source of dryer noise is something caught in the blower fan housing. You will need to remove the lower toe panel directly below the dryer door to access. Follow these steps:
1. Open the dryer door and remove the lint screen (the blower fan cover will not come off with the lint screen in place).
2. Locate the screws that hold the toe panel in place along the bottom front edge of the panel. HINT: Propping the front feet of the dryer up can give you better access to reach the screws (a 2x4 works well for this). With the screws removed the toe panel will drop down, then come off.
3. Remove the screws that hold the blower fan cover in place.
Inspect the blower fan housing for any objects that may be vibrating against the fan blades.
If you still need further assistance, please let me know. I hope you find this helpful.
Sep 01, 2009 | Dryers
Whirlpool duet electric dryer taking too long to dry
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
A2 - If the vent  doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket  thermometer can be used for this. It should cycle between 120 degrees and 170 degrees. Check that the drum seals to make sure the are not worn out.
Mar 03, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My whirlpool duet dryer is taking 3 cycles to dry????
have you checked your lint trap to make sure that it is clean after every load? Also the lint vent to the outside may be clogged and will not let the dryer vent like it should. This is dangerous. So check and replace if needed.
Dec 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Electric Dryer 4yrs old, not drying the load completely
The sensors are two metal strips inside the drum. They are on the right side just behind the filter. They are silver colored and have a slight curve to them. You cannot see them unless you put your head inside the drum. I clean my sensors with a non metal pot cleaner like 3M Scotch Brite. These sensors also fail if you dry silicon backed carpets.
Jan 20, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer Logo
644 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
