Question about ASUS Terminator P4 PC Desktop
How do I open the case to change the power supply? All I see are rivets on the back that are permanent.
I recently came across one of these odd little cases. There is a plastic tab under the front panel of the case. Push the tab in with a screwdriver, and pull the bottom of the front of the case out away from the case. The entire front/side case will hinge upwards, and come off.
And good luck on the power supply, it looks to be proprietary on this case.
Posted on Jun 21, 2010
  • 30 Answers
Do you have a latch on the back? If so, pull it and your systems protective covers will fall to the ground! If not, you will have to unscrew one of the side panels.
I am not responsible for any damage done.
-K.R.
"I know what I know because I know what to do!"
Posted on Feb 07, 2010
Justice password journal low batteries
I used a set of cutting pliers and lifted the back two rivets off. Then i gently peeled the paper up and slid a knife under the strap that was glued down. Replaced the batteries, put the rivets back in and used a small screw driver to mesh the strap back on the rivets. Lightly re-glued the strap and scotch taped the paper back on. Back in business, made one girl happy!
Dec 26, 2013 | Justice Girls Electronic Password Journal
Starting capacitor failed. Replaced it and found new capacitor getting very hot. Does anybody know if this is a capacitor start or permanent split cap electric motor? No easy way to open the motor case to...
hi, more than likely a psc motor on a `small pressure washer.
The usual problems with the capacitors failing is down to a poor power supply, wether it be using a long extension lead of too small a size, or the power supply itself.
check voltage to machine while using it, a voltage drop will cause characteristics of motor to change, phase angles etc..
A refrigerator starting relay would not have the required amperage ratings for a pressure washer..
hope this helps , andy
Oct 12, 2013 | FAIP 1500 PSI Electric Power Washer
My computer makes noise when i turn on it
There could be many different things. One could be the computer fans, second could be the hard drive going bad, third would be the floppy drive doing a start up test (don't have to worry about that one) Check the fans first they are the easiest to troubleshoot.
-please vote for me :D
Mar 09, 2011 | Belkin Computers & Internet
I wntt to access the power supply fan on my cq2009f desktop. I can remove one side and the front but it appears that I need to remove the rest of the case and this looks like it is riveted to the chassis....
If you want to remove / replace the fan you will need to completely remove the power supply box from the computer case.
There should be 4 screws on the back panel of the case holding the power supply box in place.
Unplug the computer power cord and monitor cable from the back.
Open the computer case and disconnect all the cables from the power supply to the components and motherboard (be sure to keep track of what goes where).
Hold / support the power supply box inside the case while you remove the four screws from the back so it doesn't fall down and break something on your motherboard.
Once you have the power supply box out of the computer case, you will need to remove the 4 additional screws holding down the power supply box cover. Once the cover is removed you will see and be able to remove the power supply circuit board and the fan if you want.
Good luck and please comment back if this was helpful.
Feb 03, 2011 | Computers & Internet
How do I open my power edge to replace RAM. I t looks like it is riveted in back
You can conveniently crack open the case without tools by swinging open the door that covers the front bezel, using your fingers to untwist a setscrew that lies underneath, then sliding off the side panel
Jan 01, 2011 | Dell PowerEdge 830 Server
I need to change my power supply in my HP Pavilion a705w, and the screws are on the back, the 4 main to the supply, but I'm on the other side of the power supply and I can't get in there to change it. How...
There should be at least 4 more larger screws, maybe even "thumb screws", that will have to be removed as well. These screws hold the sides of the case on. Try removing those and sliding the sides back to open up the case
Jul 19, 2010 | HP Pavilion a705w PC Desktop
How to chang out the front drivers side electric window motor
you need to remove the door panel and with the window up and wedged so it dont come down on you remove the power connections to it and drill out the rivets and remove the old motor reassemble new motor and either rivet back in or bolts are supplied make sure the bolt faces out so not to interfere with the glass
Sep 07, 2009 | 1994 Buick Roadmaster
How do I get a dell dimension 3100 case open it seems pop riveted shut. is there a trick or do the pop rivets have to be drilled out
Easy.
1. Stand in front of the PC i.e. you face the start button.
2. Push the tab at the top back of the casing
3. Pull the right hand side cover of the casing and it should just pop open - the latches are at the bottom.
I think most people try to open the left side and wonder why the ......
Mar 12, 2009 | Dell Dimension 3100 PC Desktop
Remove cabinet to get to hard drive
There should be 2 thumbscrews on the back part of the case where the side panel would slide back and off. On some other cases, there is a button on the bottom you need to press to have the side panel swing open.
May 28, 2008 | E-Machines Emachine C2684 Power Supply...
ASUS Terminator P4 PC Desktop Logo
238 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
