Question about Dryers
My dryer gets hot and spins but takes several cycles to get cloths dry
  • 5,911 Answers
If your dryer is heating, but you are experiencing longer dry times and/or poor drying efficiency, the following link can give you some items to check before you assume there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back and let me know. Please include your MODEL NUMBER, so I can determine how your dryer is configured. I hope you find this information is helpful.
NOTE: If you thoroughly check everything and still have problems let me know. The problem could be related to a thermostat beginning to fail.
Posted on Feb 07, 2010
3 Suggested Answers
  • 351 Answers
SOURCE: dryer gets hot spins takes several cycles to dry fully
ahhh very common, clean clean clean inside the dryer, take the lint screen put some toliet bowl cleaner on it let it sit while you are tearing the dryer apart and clean the whole dryer vent and or change it, make sure the flap outside is not stuck shut as well...
Posted on May 08, 2009
ftw1952
  • 10319 Answers
SOURCE: Clothes not dryin
clean out the exhaust vent tubes thoroughly. the moister sensor will shut down the high heat if clogged full of lint
Posted on Jun 06, 2010
Whirlpool dryer is not drying properly. Have to go through a couple of cycles to dry clothes.
2 things are needed to dry clothes. 1 is good air flow. Check to make sure that the dryer vent is not clogged or partially clogged with lint. Also make sure there are no kinks in the vent hose. With the dryer running you should feel good air flow blowing out of the outside house vent. The 2nd thing a dryer needs heat. Check to see that the dryer feels warm to hot when you reach in to tough the clothes. It is possible that the heat element has partially failed. Another thing to investigate is how well the laundry machine is spinning out the water in the spin cycle. This spin cycle is used to get as much water out as possible prior to placing the clothes in the dryer. The wetter the clothes when they come out of the laundry, the longer it takes to dry them.
Oct 01, 2010 | Whirlpool Dryers
Clothes not dryin
Jun 06, 2010 | Estate EED4100SQ Electric Dryer
Washer-dryer # wm3677HW will not dry,heats up, run, on and on
You're a moron. This unit washes and dries. That's the whole point of it. Perhaps you should do some research before answering the question. the most likely cause is the water lever sensor.
Aug 09, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Dryer not heating as it should. Gets warm, but takes several cycles to dry clothes
Could be 2 things... either your heat source is out of repair or your vent is blocked. Since you say it only gets warm I'll assume the problem is with the gas coils inside the unit. These parts are replaceable
May 12, 2009 | Maytag Dryers
Dryer gets hot spins takes several cycles to dry fully
May 08, 2009 | Dryers
Dryer does not dry
Problem is likely:
- heating element, or
- one of several thermal limit switches in the electrical circuitry
If you want to further pursue, let me know.
Apr 28, 2009 | Kenmore 73952 Gas Dryer
Our maytag dryer is not drying our clothes in a timelymanner. The dryer gets hot but the clothes take several hours to dry.I heard there is a part that takes to moisture out ,if that is true could that be...
I have had a similar problem. Clothes would be hot inside the dryer after a full cycle but still wet/moist. The cover for the vent to the outside had been smashed down against the vent. Steam was still coming out but air flow was being impeded. Also, be sure to check that the flexible tube to the vent is not blocked by dust, spiderwebs,etc. Hope this helps!
Oct 07, 2008 | Maytag Dryers
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Cloths not getting dry
id look into a clogged and or kinked exhaust vent. perhaps where it leaves the home theres a screen over the housing thats clogged itself w/lint. its generating heat, thats good now just needs to release it somehow
Mar 16, 2008 | Washing Machines
Dryers Logo
65 people viewed this question
Top Dryers Experts
