Question about LG 42PX5D 42 in. Plasma HDTV
Color Speckling in Dark Part of Picture
In the dark part of the picture only speckle spotting of various colors appear in a scatter fashion. It doesn't appear that this is happening in other parts of the picture, but maybe I'm just not seeing it. From a distance this isn't noticeable, but up close it is really quite bad. The service company said that this is an inherent problem with plasma but I can't find it on any other plasma TV's the same age as mine - just under 2 years.
  • AndyGump Mar 20, 2008
    The tech that serviced the TV for this problem implied that he had done this and he thought he got improvement, but he didn't
    Guru:
  • 1,894 Answers
Sir it happens in all kinds of plasma Tvs sir.
Posted on Mar 23, 2008
  • dewan nafees ahmed Mar 23, 2008
    Main support number 1-888-373-4368
    Email support info@regent-usa.com
    ooops ignore that last post sir
    Sergeant:
  • 395 Answers
The set needs to have an adjustment in the panel voltages. this must be done by a qualified tech. the panel has now gotten it's full aging and now needs to be adjusted. this adjustment does not need to be adjusted again after this has been done.
Posted on Feb 22, 2008
Why red speckling around the border of the picture
try adjusting the voltages on the panel display, the voltages are listed on the label on the panel itself. Adjusting them up or down within 10 to 15 volts should affect that speckling around the picture, if not then the panel will most likely d to be replaced
Apr 12, 2015 | LG 42PX5D 42 in. Plasma HDTV
Colored spots on Samsung HLP5063W
The color wheel or the DLP chip itself will cause this. Parts can be had here: www.shopjimmy.com
Jun 27, 2017 | Samsung HL-P5063W 50" Rear Projection HDTV
How I can sapture a picture in ISO mode??? what is the purpose of capturing aphoto in ISO mode??
ISO is not really a "mode", every photo you take has an ISO rating; it's one of the three main ways of controlling how light or dark a photo is. (The other two are shutter speed - how long the sensor is actively capturing for, and aperture - how wide is the hole (aperture) that the light passes through.)
You can think of the ISO rating like a volume control - it's how sensitive the sensor is. At ISO 100 the sensor is at its least sensitive - you get the smoothest picture but you need lots of light to do it. At ISO 800 and higher, your sensor is most sensitive - your camera will take pictures in lower light, but there will be more 'noise' - meaning the speckled effect you get on digital pictures.
It's similar to the volume control on a radio. When you have a strong local station you can turn the volume down, and you'll still get a great quality sound. But if you are trying to pull in a distant station, you turn the volume up and put up with a bit of hiss just to hear what they're saying.
Just the same with a camera. When you have strong sunlight, you can turn the ISO down and you'll get a great picture. But if you're trying to pull in a dark photo, you turn the ISO up and put up with a bit of speckling, just to see the image.
Hope this helps.
Feb 02, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
Poor picture no color
OUCH! LARGE DARK SPOT IN CENTER IS NOT GOOD FOR PROJECTION TV. YOU BURNT THE TUBES. THE LOSS OF COLOR IS THE ROOT CAUSE SOUNDS LIKE A DEFLECTION CIRCUIT PROBLEM. THE TIMING FEEDBACK IS USED TO SYNC THE COLOR CIRCUIT. IF THE TUBES LIGHT WITHOUT DEFLECTION THEY BURN THE CENTER PHOSPHOR COATING INSIDE.
Dec 24, 2009 | Televison & Video
Picture color is way off when printed. For
Two things i would suggest in case get your printer serviced and get cartages refield with good quality of ink..
Jun 23, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Colors trail behind motion in picture...color too dark
replace T-con board ( top centre of lcd panel ) lvds cable plugs into this
Jun 06, 2009 | Sony BRAVIA KDL52XBR2 Television
Toshiba Plasma 42
plasma42 color flickers in and out and now its just snow,now its black screen. still have sound.please help me.. what board should i replace??
Dec 29, 2008 | Toshiba Televison & Video
I get a red/blue/green static at the top of my plasma tv.. when the picture goes to a dark color its usually speckles red.. then when its a light color it doesnt really show.. wats the problem?
In some cases it is just a matter of making voltage adjustments on a plasma set to get rid of the spots you are seeing. I would look for a reputable technician in your area to see if this is the case. Good luck...
Nov 18, 2008 | Televison & Video
Dark greys appear a dull green.
could be a jumper that needs to be removed on the DMD board, or a setting in the factory mode, mute-182-power will get you in there
Jul 11, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Lg42px52 speckling.
The speckling is caused by the CTRL board. The firmware needs to be updated. Unfortunately LG does not provide a media slot for downloaded upgrades. You must order an install the factory updated CTRL board located between the power and the Y sustain boards.
Nov 24, 2007 | LG 42PX5D 42 in. Plasma HDTV
LG 42PX5D 42 in. Plasma HDTV Logo
161 people viewed this question
