My pg up and H button fell off
I have all the parts but when i put the button on it dosnt feel right
it takes a lot of pressure to get the button to work
i cant be the parts cause there orginial parts
please help
i feel so bad cause my notebook dosn't work
its a Travel mate 340T
    Scholar:
  • 117 Answers
Is that the only problem your keyboard has is that one key?
There are little rubber fittings that go under that key..almost like a rubber ring on some...If that is missing then the key won't work properly.
Make sure the key is perfectly aligned when you pop it back on...uninstall the driver then reinstall it...See if that helps...
Note....notebooks are very particular with it comes to keys and alignment. Be careful
Posted on Feb 25, 2008
Horn dosnt work . steering wheel buttons dont feel correct.
It could just be that your horns are bad and need replacing. You got to the horn relay and have somebody push the horn buttons while you hold your fingers on the relay, if you feel it click the your buttons are good and you have bad horns.
Apr 26, 2014 | 1999 Saturn SL
Need help with the lid latch
Yeah, I would say that your lid switch came apart. Seems to be a common problem with lid switches made out of plastic. I think that it comes from people placing heavy things on top of the washer. Like themselves during the spin cycle. And it puts too much pressure on the switch making it come apart.
I go to repairclinic.com a lot with model numbers to find manufacturer part numbers. Then take that number and plug it into ebay. For this model I found W10059230 to be the part number. Found a lot of listing on ebay for really good prices. Amazon is another good source for parts for low prices.
As for putting the switch back together there is no way to do so and it work correctly. It will need to be replaced.
Youtube videos is another good source on how to do things. People have been nice enough to post hands on videos of a lot of different things. Great learning source.
Mar 20, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
SAMSUNG 3D LED TOUCH PAD REMOTE FELL AND BATTERIES CAME OUT PUT THEM BACK IN NOW ITS FROZEE LIGHTS ON BUT DOSNT DO ANYTHING
it probably crack or misplacent is done in its circuit kit ..i prefer u to take the remote in samsung care if it is in warranty if not u can open it by own and see what has happened but be careful donot touch the kit
Dec 23, 2013 | Samsung Televison & Video
Do you sell replacement parts. Top fell and cracked, bottom unit is good.
You can get them from the Crane Website: http://shop.crane-usa.com/products/category/1779.0.1.1.563.79630.0.0.0?pp=8&pg=3
But the bottom unit of mine is no longer working and I could send the top part to you instead of throwing the whole thing out.
Oct 31, 2010 | Crane Frog EE-3191 1 Gallon Humidifier
When chemical injector is attached, it works fine. When I put one of the power tips on, I do not get any pressure.
When using the chemical injector your machine is only having to operate under low pressure. This means that your pump only has to transfer water and does not have to compress it. When you insert a pressure nozzle you cause the pump to have resistance and therefore it has to compress the water to make pressure. If you pump seals or valves are worn the pump cannot build this pressure. You need to either rebuild your pump yourself or have it looked at by a service center. If you have any other questions or need parts or service please feel free to contact me using the information below.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Sep 23, 2010 | Honda Landa PG 3500 PSI Pressure Washer
The button for taking photos and zooming in fell off and is lost can this be replaced?
Hi, I've had the same problem - there are 4 legs that clip the zoom button on (which holds down the shutter button) and the ends of the legs snapped off. I didn't drop it or anything, just one day when I got the camera out the shutter button fell right off.
If you're in the US you can get a replacement part from here:
http://www.pacparts.com/model.cfm?model_id=EXZ110&mfg=CASIO&back=0&action=list_part
I think the part no: 10213210 is what you're after. Note that it's $8.50 (USD) and then they charge $11.50 (USD) to post it to you!
Unfortunately I'm in NZ and they won't sell it to me.
Feb 17, 2010 | Casio Exilim EX-Z110 Digital Camera
I have an Easy-Flo central vac unit. The handle on the electric hose has a switch on the handle. With the switch on ''O'' in the center, it's off. On the left, is the ''I'' position. The vacuum runs but...
You can't get that apart. I repair the switches on these hoses a lot. The only way to fix it is to just get a new switch and replace it. You can get a replacement switch here:
Switch Replacement
Nov 18, 2009 | Vacuums
The button for teletex dosnt work anymore one dsy
Take it aparts clean the part with a Q tip.See if the rubber inter film warn out,if it is u out of luck.
Aug 15, 2009 | Televison & Video
My (pg up) button pop off when trying to clean keyboard.
You cant put them back on, Its a new keyboard im affraid
Feb 19, 2009 | HP Compaq Presario v3000z Notebook
Volume Button.
hey there i have the same problem only difference is mine hasent fell off yet but mines broke while i was simply turning the volume up! and it happened the day i got it...i was not best pleased! lol
May 17, 2007 | Sony Network Walkman NW-A1200 MP3 Player
Computers & Internet Logo
268 people viewed this question
David Payne
David Payne
