Check fan trouble signal. can i fix it myself
Samsung wireless fp-t5094w check fan trouble signal. can i fix it myself
3 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: I have a Samsung plasma tv model fp-t5894w when i
These units may have more than one fan and usually do.
Way to approach this:
Someone needs to open the unit(if you are going to do that I have cautions and advice).
With back off first look to see if a lot of dust on the blades of the fans---even a moderate amount will slow them down--set will detect if a fan is not running or running too slow and shutdown is instant to protect the set.
If for example 3 fans all are usually powered from same source--if all three do not move--suspect the source for voltage. If one does not move or moves slower than the others suspect that fan.
What I do if one is not moving or is moving very slow--look to see if all fans have same markings or number and swap the slow one for another as they usually are connected with plugs.
Cleaning (blowing) the fans clean may cure it or not--if one fan is bad you may just want to replace all three--not that expensive and you only have to open set one time--also if one has failed how much life is left in the others?
Let me know what you find etc.
Posted on Apr 03, 2012
SD Tech
  • 14553 Answers
SOURCE: I have a 55 inch Samsung plasma tv FP-T5094W with a wireless av center. The capaciors in the av center are blown. The av center turns on and the blue light stays on for about 5 seconds and goes off. T
Capacitors do not get"fixed" if bad they get replaced----Not real hard as only each have 2 leads soldered in --one marked with a minus and the other a plus.
Also the value of the part and the working voltage are marked right on it.
take a good look and if need advice let me know.
Posted on Nov 05, 2012
How to increase my symbian mobile signal strength ??
I had same prob - after buying an LG Smartphone (SP) to replace my Samsung Mantra flip phone (FP), signal strength was so low that i couldn't use it except as a pc on wifi, so i had the FP reactivated. After ~ 6 mos sprint upgraded the tower and i had the SP reactivated. Now i get 1-4 bars, but if only 1-2 bars voice is sometimes nearly unintelligible... You CAN buy a signal booster and use it in your residence but the cost is hundreds of $. Or you can do research and try to find a SP which has high signal sensitivity. The Samsung Mantra FP has very good signal sensitivity and worked fine even before sprint upgraded the tower... the LG SP has much less inherent signal sensitivity and so needs a stronger signal to function. But there's more to the story...
If you have home WiFi you can switch to T-Mobile and use their WiFi option with your SP to send and receive cell calls via WiFi when your SP WiFi is enabled & connected. I suspect this is what I'll do myself when I get tired of the poor voice quality my sprint LG SP is now delivering. And my guess is that the WiFi option will be offered by all carriers evenually. T-Mobil is just ahead of the curve... IMO.
Dec 07, 2013 | Nokia 5800 XpressMusic Smartphone
I have a 55 inch Samsung plasma tv FP-T5094W with a wireless av center. The capaciors in the av center are blown. The av center turns on and the blue light stays on for about 5 seconds and goes off. The av...
Nov 04, 2012 | Samsung 50 in. Plasma TV
Check Fan No.3
Take it aparts look at which fan not spinning replaced that one that simple.
Dec 17, 2009 | Samsung HLN467W 46" Rear Projection HDTV
Samsung FP-T5084 No picture
For a 50 inch plasma....its worth it, in my opinion y-boards cost around $149 to $189
Nov 03, 2009 | Samsung FPT5084 50 in. Plasma HDTV
Internet/network problems
Connecting the laptop to your network using a network cable, does this solve your Internet problems?
Does this works without the Internet connection dropping out?
If the wireless connection has a low signal, try positioning the wireless router or the laptop to get a better signal strength.
Also try reinstalling your wireless driver.
Jun 20, 2009 | HP Pavilion dv6000z Notebook
Cooling fan stopped working.
http://www.samsungparts.com/search/search.asp
try to check all the accessories for your unit here
May 30, 2009 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Fp fault
The problem is pump is either broke or there maybe something is caught up in the impellor, easy to fix, remove front cover undo spring for door seal unplug electrics, remove both hoses on pump and undo bracket, then check pump, had same problem myself it was an elastic band and coins got it fixed myself saved a fortune hope this helps.
Dec 14, 2008 | Washing Machines
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
Electro Med Services...
