Question about Sony Playstation 3 (PS3) Console
My ps3 wont connect at all. the power is on and no display on the tv. the connection is correct
    President:
  • 1,139 Answers
Please try these steps :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Posted on Sep 11, 2010
Unhooked from one tv and hooked to another now says 480 pixels and wont play
If connected with hdmi connect power on ps3 and tv,,should detect it,,if rca jacks connect to tv,,power on both,,hold power button down for few seconds ,,u will here a few beeps,,or it will powerr off,,,should come on screen,,go to display in settings on ps3,,,,to change anything,,goodluck
Nov 29, 2013 | Sony Playstation 3 (PS3) Console
PS3 Connection problem with this particular tv model.
connect PS3 to Tv with RCA cables (white,red,yellow) go to display settings change to HDMI, Tv should go black remove RCA cables and connect with HDMI.
Jan 10, 2018 | Samsung LE22B450 22 in. HD-Ready LCD TV
My playstation 3 was working fine, im now trying it on another tv and it wont work. i have tried all the reseting display settings by putting the console on standby and holding down the power button until...
Please check the cables used to connect the ps3 to the tv screen. whether it has been copatible or may experience constraints to connect. Replace immediately if the cable is not good. ps3 section for setting the output to a tv. hopefully help.
Aug 02, 2011 | Sony Playstation 3 (PS3) Console
Hi,i got a ps3 connected to sony bravia 22'inch my ps3 wont display anything in the hdmi mode .the power is on but no display ..i checkd the cables to be correctly fitted but no use..plz help me
Sometimes a system restore will fix this problem. Make sure that if you have more than 1 HDMI port on your TV that you have your TV tuned to the right HDMI port#. NOTE: A system restore will delete all saved game data. I recommend backing up your console onto a usb flash drive. GOOD Luck!
Feb 13, 2011 | Sony Playstation 3 (PS3) Console
My samsung tv wont connect to my ps3 through the hdmi cable, the tv works if i connect my laptop or anything else to it. iv tried my ps3 on my lg an it work just fine just cant get it to work on my samsung...
When you have PS3 connected to the TV with HDMI connector, hold the ps3 power button down for 5 seconds, when u hear 2 beeps, release it and it should display standard format on the TV, thats when you'll get the option to correct the picture mode for the PS3. Hope that helps.
Dec 23, 2010 | Samsung LN52A650A LCD TV
My playstation wont transmit a picture to my television
Make sure everything is connected correctly. Then, turn on the PS3 from putting your finger on the "power button" but HOLD IT DOWN. After a few seconds it will beep at you a few times. Check the TV. If the video OUT settings got messed up somehow, it should now display picture on whatever cables you are using "HDMI" or "Composite" . Hope this helps!
Jul 22, 2010 | Sony Playstation 3 (PS3) Console
Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
I’m happy to assist further over the phone at https://www.6ya.com/expert/kevin_c38b47f462e94458
Sep 15, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
When i turn on my ps3 the xmb menu wont show....
am sure about the computer part but for the xmb i can help reset ur ps3 by turning it on then turn it off by holding the buttonthen it back on by holding the power button it should beep pause and beep 2x this will reset ur display option back to normal then ur cables make a difference if ur using a SD TV use regular cables if HDTV use hd cables only on hdtv if use on SDtv it won't display or ur ps3 is set to an hd setting like 1080p it won't display on a sdtv so reset ur ps3 by holdin power button hope this help u
Jul 16, 2009 | Sony Playstation 3 (PS3) Console
Sharp Aquos LC-32B20E wont display a PS3 output via HDMI
kitconnolly,
I too went through this problem.
Step 1 - Plug in your "composite" cables and the HDMI cable to the PS3. Obviously, the "composite" cable are the ones that came with the system. You need to start with them as the default connector.
Step 2 - After connecting the "composite" cable and the HDMI cable to the PS3, connect the other ends to your TV.
Step 3 - Power on your PS3
Step 4 - Select display settings-->video output settings
Step 5 - Change from the current video cables to HDMI. (Your tv has different inputs. When you switch to HDMI in the PS3, you will have to switch your TV to the HDMI input that it is connected to, to get a picture)
Step 6 - Be quick, the PS3 will display a "test" for 30 seconds. You need to switch your tv to the correct HDMI input and press "X" on your controller to accept the change.
Let me know how this works for you.
Apr 03, 2009 | Sharp Televison & Video
My PS3 wont start up. when i turn it on i get noting no sound or image .
Check your HDMI (looks like USB connetion) Connection or your Composite video connection (yellow, red, white connections.) Make sure they are correct and tight on both your TV and PS3.
Most common connection to use 1st is the Composite video connetions. Yellow is your Video display; Red and White are your Sound!
Good Luck.
Sep 26, 2008 | Video Game Consoles & Games
Sony Playstation 3 (PS3) Console Logo
23 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
