Question about GE WBSR3140DW Top Load Washer
What is the problem with my washing machine if the tub is sitting a little cockeyed?
Wash tub removal?
There is corrosion on your drive shaft due to Liquid Detergent use. You will have to push the tub back down and yank it up several times to remove it... sort of a slide-hammer effect. Whirlpool Washing Machine Tub Seal and Bearing Kit W10435302 Whirlpool Washing Machine Bearing Driver W10447783 When the unit is fixed...SWITCH TO POWDERED DETERGENT!
Jul 12, 2016 | Whirlpool Washing Machines
Leaking into wash tub
The water inlet valve needs to be replaced. It is not sealing.
Here is a link to the part you need.
Aug 13, 2012 | GE Profile WPRE6100G Top Load Washer
Washing machine fills with water while sitting idle.
Another problem could be the inlet solenoid is failing to close properly, this could be caused by either an obstruction in the sealing part of the solenoid valve, a damaged or worn out seal or if the water pressure is too low. (some solenoids require water pressure to close off properly). To test this idea turn off the taps when not in use. If the water is still filling the tub, the back flow / syphoning idea may be valid. Also just to rule the idea out, turn off the tap to the machine and remove the inlet hose, if the tap "drips" this "trickle" of water maybe the culprit. If turning off the inlet tap fixes the problem you may need to replace the inlet solenoid.
Jan 08, 2012 | Whirlpool Duet GHW9150P Front Load Washer
We just bought a front loading machine and it seems to have hardly any water while washing. How much water should there be? Right now it looks like only the clothes are wet but no other water sitting in...
Front load washing machins are very water conservative. In fact a lot of moldern F/L washers use so little water that it doesn't even come up to the bottom of the door.
If the machine completes it's cycle, it obviously 'thinks' it's getting enough water to continue..
IMPORTANT...Do not overuse detergent!! This can seriously shorten the life of a F/L...! You're treating the amount of water...NOT the amount of clothes...Happy Washing
Good luck....Nomess
Aug 04, 2010 | Samsung WF203ANW Front Load Washer
My washing machine is having trouble getting past the rinse cycle. I checked the hose made sure it was secure and clear of any debris hair etc. Then tried to resume draining but once it starts back up it...
YOUR PROBLEM IS DOOR SWITCH OR CLOGED DRAIN PUMP THER SHOULD BE A ACCESS PANEL FOR THE DRAIN PUMP SO YOU CAN GET TO THE PUMP AND UNSCREW THE OUTLET TO UNCLOG DRAIN
Apr 26, 2017 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
The twin tub connected to the washing machine doesn't drain.
The laundry tub does not have adequate drain size to handle discharge from the washing machine. In addition, the kitchen and laundry area piping may not be correctly vented.
May 17, 2017 | Daewoo DW500M Top Load Washer
I have a meile w502 washing machine it leave rust stains on my washing
sounds like the bearings are on there way out, it starts by water getting past the seal that separates the bearings from the tub, when the machine is idle the rusty grease runs back inside the tub and sits in there untill it is used again, because its grease it floats on the surface of the water.
Aug 05, 2009 | Miele Washing Machines
Tub is very loose/wobbles during spin
could be the balancing spring. but if you do not know where it is hooked, then that would be a problem.
investigate and look for holes where it would be fitted to hook a spring. if there are three of them , follow the other two which are still hooked correctly.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool top load washer- tub will not keep balance
did you take out the shipping bolts when you bought it if you did then its the universal joint under the agitatot or in it more likely
Dec 29, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
GE WBSR3140DW Top Load Washer Logo
37 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
