Question about Refrigerators
My freezer seems to have stopped working but the refrigerator seems to be okay. Is it the freon or something else?
  • 4,793 Answers
Could be temp sensor faulty .freon is a cfc. not used anymore,hardly likely to leak.....gas unit sealed for life
Posted on Feb 09, 2010
I have a problem with my s75438dt,the fridge as stopped working
If defrost heaters in freezer stop operating during defrost cycle, ice builds up around coils and blocks cool air from being blown to refrigerator side. If ice you need to defrost with heat and replace heaters. Remove rear freezer wall and look for solid ice covering coils. Also push freezer door switch closed while keeping door open and determine if fan is working.
Feb 06, 2016 | Refrigerators
Side by side Whirlpool in insulated cold garage ompressor seems to be running all the time, freezer not working fridge is warm
Sounds like low on freon. Some refrig. has a charging port. It may even say on name tag what type of freon to use. You need a guage to check if unit is low on freon.
Jan 20, 2014 | Gladiator Freezerator Top Freezer...
Kelvinator push button
It's low on Freon. You will need a qualified technician to recharge it and check for leaks. Sorry, but refrigerators are NOT designed for "do-it-yourselfers".
Sep 06, 2017 | Refrigerators
Freezer isn't cold, defrosted all of my food and the refrigerator part doesn't seem very cold either.
If your refrigerator cooling doesn't seem to be working well, and you have no idea what to look for in troubleshooting your problem, there are some things you can do to try to figure out your problem without paying a serviceman to come into your home.
Freezing
Most new refrigerators come with automatic defrosters. Although this is a standard feature the drain hole in the defrosting assembly can get clogged with debris, lime, or even ice. If this happens the defrost will not work and there will be a build-up of ice in your freezer that begins to block the freon from flowing properly and causing heat to react improperly and cause your refrigerator to stop cooling.
Freon
Freon systems in a refrigerator are closed systems but on occasion you may need a recharge. Refrigerators use R-134a freon, just like in an automobile. The old R-12 freon is no longer available, so if you have an older model of refrigerator you will not be able to obtain the freon, and it will be recommended that you replace that refrigerator.
Seals
The seals that are on the door of the refrigerator and freezer can dry rot with time. When you begin to see the seals cracking or warping, if your refrigerator opens more easily than before, or if you see the the door does not close fully without pushing on the door then the gaskets around the doors will need to be replaced. They are held in place by clips and the replacement is an easy fix.
Holes in Lines
Let's face it, many people find ice in their freezer or the back of their refrigerator and will try some self-help without knowledge. They will grab a knife or fork and start chipping away at the ice. This is extremely dangerous. There is a great risk of puncturing a hole in the freon lines by stabbing at the ice. Since freon has the purpose of cooling most ice collects the thickest on the inside of the walls with the freon lines right behind the plastics. A better method of removing the ice is to empty your refrigerator, turn it off and leave the door open. If you want to speed up the process you can turn on a blow dryer and aim it at the edges of the ice. If you aim at the edges you will warm up the ice and create warm water which will flow down and help to separate the ice panel from the wall.
Uneven Refrigerator
If a refrigerator is not even on the floor it may not close properly. Rock your refrigerator and see if it seems to topple from one foot to another. The feet on a refrigerator can be adjusted by screwing in or out and leveling each foot individually until they are all even.
Non-Problem Warming
If your home is hot your refrigerator will work harder. If you put a lot of food in your refrigerator and freezer, your coolant will have to work harder, and it will seem to take longer to cool. It is just that there is a lot of food that is trying to freeze or maintain cool temperatures.
Good luck
May 31, 2011 | KitchenAid KSRK25FVMK Stainless Steel Side...
Maytag MTF2155GRW Refrigerator Both freezer and refrigerator are not cold. Fans are blowing warm air in both freezer and refrigerator. Any ideas what is wrong?
Freezing
Freon
Seals
Holes in Lines
Uneven Refrigerator
Non-Problem Warming
Hope this will help in solving the problem......
May 08, 2011 | Maytag MTF2155GRW Top Freezer Refrigerator
Not getting cold enough to freeze, How to check Freon
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 05, 2010 | Kenmore 53082 / 53084 Side by Side...
Fagor refrigerator (3FCA-68NFX): no cold air in the refrigerator
u may have a duct that goes from the freezer to the fridge that is closed off or u may have a stopped up freon line and if thats the case ur probably going to have to call a tech but check the duct first if u have one in that particular fridge
Mar 01, 2010 | Fagor 3FCA-68NFX Stainless Steel ...
The upper freezer is no longer cold enough to freeze water; the refrigerator itself seems to be working o.k., but I'm not sure of that even.
it seems that you are low on freon if your freezer does not freeze enouht water you need freon cause you have a small leak in the system thanks from gilles
Feb 18, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
GE TFX27R SBS refrig too cold
To answer your question that is how the coil is supposed to be wrapped. Just because the unit stays really cold has nothing to do with low freon. Low freon you would ice up and the system would be warm. This sounds like your really is bad and needs to be replaced, due to the fact that nothing is telling the copressor to shut down. This is how it works. The thermostat sends a signal to the thermocouple, which in return sends a signal to the relay which sends a signal to the compressor to run or stop. If the relay goes bad it will let the compressor run all the time. Please rate if you are satisfied
Feb 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
