Vertical lines and color off sometimes other times
Vertical lines of green and pink and color off sometimes other times works perfect cleaned inside fan very dusty thought maybe fan was causing interference
  • 231 Answers
SOURCE: Pink and Green on Non HD Stations
what is model of unit?
Posted on Nov 30, 2007
  • 1894 Answers
SOURCE: Panasonic TH-42PD50Uscreen colors all appear pink and green
the colour sensor on the picture display may have lost functioning....as in case of plasma tv`s the they use transistors for colour ......so better call a technician from the related company and do a check up.....no other solutions i hope.....
Posted on Jan 02, 2008
  • 105 Answers
SOURCE: Vertical red lines on screen
LCD correct?
There are 2 types of lines they may be showing, both requiring the replacement of the LCD Panel.
1. Delamination Lines- they are usually multiple vertical lines that do NOT flow from the top to bottom of the screen. Looks look water dripped down or something similar
2. Single/Multiple Vertical lines - This is normally 1 or maybe a few solid vertical lines that travel from Top to bottom. I belive in some cases they may only travel to the screen center.
In both cases, this will always show when the TV is ON. Even if there is no signal being input to the TV. There are other possibilities but these can be the most common. Both require a new panel.
Posted on Apr 29, 2009
  • 23 Answers
SOURCE: plasma TV with vertical lines
EASY! ok the 4th video processing unit is malfunctioning, if it is a Piano affect like the keys on the piano, then that can be fixed under your 1year warrenty after your 1year warrenty it will cost $200, but i could be wrong, i never studied panasonic plasma casue they ****, next time get a samsung.
the worst contrast and video ajustments, thats a panasonic.
trust me i am the flat pannel guru!
Posted on May 02, 2009
  • 1779 Answers
SOURCE: I have a 60inch lg plasma tv only a couple years
A good chance your upper buffer board connectors need cleaning. That board will correspond where the lines are. It's at the top of the set.
Posted on Jul 13, 2009
Hi I have a samsung plasma PN50C550G1F I havve right now 2 vertical lines that seem to change color with the background picture. Tv powers up fine sound work perfect.
Vertical lines on a plasma TV are caused by either a failing x-buffer board or a loose connection at the flex cable between the panel and the buffer board. Sometimes just removing the flex cable, cleaning it, snd reinstalling it will fix it.
Mar 17, 2015 | Samsung Televison & Video
Right side of screen blurry with lines-TH-42PX75U
Check the site linked below, and compare the screen shots. It has many kind of defective screen-shots to plasma displays. Compare them to that of yours, and make sure about the faulty board or others. http://electronicshelponline.blogspot.com/
May 20, 2013 | Panasonic Televison & Video
Vertical green line on left side of my laptop lcd
lenovo G450 a vertical line appears on the right side of screen. it is of pink colour.
Jul 03, 2010 | Samsung 204T 20.1" TFT-LCD Monitor
Vertical lines after the tv is been for a minute
If you can open LCD Tv than refit all connector of Mother Board
Jan 21, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
TV gets vertical colored lines, then shut off, green blinks conti
Bad Capacitors in the Power Supply could cause this. This Chassis has be famous for bad capacitors through out many boards. If you are not comfortable with working on the unit, and most are not, I would call a professional. The Chassis may need to be sent to Mitsubishi to be refurbished. This is a expensive repair and it would be advisable to call a Mitsubishi Professional to confirm diagnoses. Mitsubishi's Customer Service Number is 1800-332-2119. They also may be willing to help with the cost of repairs.
I hope this helps,
Skyassoc
Jul 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Vertical green line in papers
Your printer green cartridge drum cleaning blade is weak.you change it than solve it
May 30, 2009 | HP Color LaserJet 2600n Printer
My Xerox 6130 keeps printing vertical pink lines on pages
your color laser printer pink vertical line appear on the roller and film drum,
1) you need check the pink drum surface, it got damage if you find there is a different color vertival line on the drum surface, so you need change the pink drum.
2) check the pink drum cleaner (call brush to return the waste toner), it can not clean well sometimes, if the drum surface good.
Feb 06, 2009 | Xerox DocuColor 12 Printer
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
