Question about Rancilio Rocky Doser Espresso Grinder (Stainless Steel)
Have Rancilio Rocky for about 3 months. Noticed grinds around base from time to time. Yesterday picked up machine, saw accumulation. Tapped base, more came out. Took off base, about 2 oz. of grinds inside. Common or is mine defective?
  • 1,089 Answers
Hi There could be a piece broken around the chute where it comes out of the grinder and enters the grounds chamber. There is a rectangular opening in the plastic that can get broken causing the grounds to enter the machine.
Posted on Feb 07, 2010
Our Silvia, almost 8 years old, is putting out shots too fast (10 to 15 seconds), even though we've been dialing down the grind on Rocky more fine, putting more coffee in, and tamping harder. We...
Try to redo what you have been doing, but set it to the extremes to see if everything is functioning. If you set the grind say to 4, it should come out very slow or maybe not at all.
Jul 11, 2011 | Rancilio Silvia Espresso Machine
My Rocky is just out of the box yesterday and it seems to have jammed up. It still grinds, but I can't turn the top, at all. It is stuck, so I can't adjust the courseness. I can't see any obvious problem...
  1. stabilize the body of grinder
  2. provide block spin to be in release position
  3. get one 3 legged key for releasing oil filters
  4. put filter legs at upper holder of burrs
  5. start to release carefuly
be gentle at first, go forward and backwards to measure how much strength is required
Oct 31, 2010 | Rancilio Rocky SD Grinder without Doser -...
In the past I have cleaned the grinder blades 4 times however this time I noticed some of the grind mixture winds up on the counter under the main motor of the unit. When I picked up the grinder and shook...
Have you tried to hoover up the grinds from time to time, from the grinder blades. The coffee beans and ground can gather under the blades from over time. It should not be a problem though.
For better crema you may want to replace the blades.You should replace every 3-6 years. Rancilio Rocky Grinder Flat blades
May 07, 2017 | Rancilio Rocky Doser Espresso Grinder...
Silvia pressure issue
The Silvia comes equipped with a "pressurestat" that may have gone out of adjustment. Do a google search on that and you will find numerous pictoral guides on how to do this. The owner's manual that came with the machine (they have electronic versions at espressotec.com, among other places) will also give you basic instructions. Good luck!
Aug 22, 2009 | Rancilio Silvia Espresso Machine
Rancilio rocky grinder setting
to get starting point you adjust burrs to touch each other. when they touch each other you have finest grinding, after you hear metal voice you turn back 3 dots and grind only for 1 dose. you check it, if it goes to slow, you go one more back and clean gruinder, THAN you grind 1 dose more. 2 or 3 times and you will get perfect grinding.
Mar 28, 2009 | Rancilio Rocky Espresso Coffee Grinder -...
Have a Rancilio silvia machine, grind coffee with a Rancilio rocky. Problem is that sometimes... more often than not, the coffee coming out of the portafiller spouts comes out quickly and sprays all over...
Try taking the portafilter out and run water through it as if you were making an espresso. check if the water coming out is very fast. I believe there is a screen there that is held in by a flat screw. If you take that off you should be able to see light through it. If you can't soak it in some cleaner until you can see light through it. There could be a couple of things causing this. The other thing that comes to mind is that the boiler has to much pressure but it should say on your gauge if that is happening. You might find that it just needs a good cleaning.
Mar 21, 2009 | Rancilio Silvia Espresso Machine
Adjusting grind on Rancilio Rocky
  1. because it didn't work a wilde the upper burr holder could be jammed, carefully take id off, clean it good and then put it back until you touch lower burr with the upper.
  2. to get starting point you adjust burrs to touch each other. when they touch each other you have finest grinding, after you hear metal voice you turn back 3 dots and grind only for 1 dose. you check it, if it goes to slow, you go one more back and clean grinder, THAN you grind 1 dose more. 2 or 3 times and you will get perfect grinding.
Dec 09, 2008 | Rancilio Rocky Espresso Coffee Grinder -...
Rancilio grinder does not grind fine enough for espresso
After taking the top burr off several times and rescrewing it, I finally was able to exert enough force to get it to turn a couple of extra turns. Evidently there was some oil or coffee gunk (although I could see none) that snagged the bur. Now it appears to work as before.
This is a great, service by the way. Even the process of thinking through the problem so I could post it helped me solve it.
Nov 22, 2008 | Rancilio Rocky Espresso Coffee Grinder -...
Rancilio Rocky Doser Espresso Grinder (Stainless Steel) Logo
186 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
andy just round the...
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
