Question about Panasonic CT-32G14 32" TV
No image from coaxial cable or any of the video inputson a panasonic CT-32G34
  • krodriguez11 Feb 07, 2010
    there is sound just no image .... at all
    Problem Solver:
  • 9 Answers
You have to have the TV set to the right input, look on your remote for input selection. Or try changing the channel on your TV
Posted on Feb 07, 2010
Color not balanced. All kinds of color is showing. Old set
Your TV needs to be demagnetised. So all what is required is to use a hand held DEGUASSING unit with the set switched on and to be moved around the picture tube front.
If there is heavy coloration , the fault can also be a failure of the POSISTOR within - found near the mains power supply input in the board and which is responsible for auto deguassing every time the set is switched on.
You must replace if this is damaged or not working.
Oct 08, 2011 | Panasonic CT-32G34 34" TV
How to dismount ENG36604G tuner from CT-27D11 27" Panasonic TV
With difficulty.
Soldered to board.
Only qualified techie can do it.
Oct 05, 2017 | Panasonic CT-27D11 27" TV
I have an older tv, (one with the vhs box built in), it has a cable box on top and I want to connect my dvd player. I have the yellow, white and red cable but I don't know where to connect on the cable box...
Cable boxes do not have an input for video. They only output video. If you would like to use both then you will need an A/V switch. Radio Shack has these switches for about $20 or so depending on which switch you get. Some have remote controls and some don't.
Mar 20, 2009 | Panasonic CT-32G34 34" TV
Panasonic CT-32SF36 isn't getting video from A/V receiver
Hello, I hope this message can help you, After reviewing the Panasonic TV info, and the Yamaha reciever info., I have found on page 19 of your owners manual for the Yamaha reciecver that you can connect the the cable box HDMI cable to the reciever, but the reciever needs to connect to the T.V. HDMI.
I see your T.V. has S-video in and your reciever has S-video out, what about your cable box if it has S-video than I would connect all your device together through the S-video jacks.
A further note is you can't down grade the signal from the cable box through the reciever to the T.V., so even though the technology is there on your cable box, it's not there on the T.V.. On that note there is 2 options 1) buy a new T.V. with HDMI inputs. 2) connect the system together using S-video or component cables (RCA). It will give you almost the same quailty if you use good cables. I hope this will help you and I look forward to helping you in the future.
Jan 14, 2009 | Panasonic CT-32SF36 32" TV
Panasonic CT-36SL14J White screen
my Panasonic CT-36SL145J won't turn on
Dec 25, 2008 | Panasonic CT-36HL43 36" TV
S-video problem on Panasonic TV
Have you tried another S-Video patch-cord?
Some cheaper ones short across pins.
What output from DVD are you using?
If composite video 'Yellow' RCA socket, a cheapo cable can also create sync problems ie signal timing, causing patterns on screen.
The S-Video is actually 2 signals - one for Chroma C and the other for Luminosity Y. With S-Video to S-Video connections, this gives better quality than composite, as each line can handle separate voltages, levels and frequency for Chroma = pixel color and luminosity = pixel intensity.
Composite has to cram all this info onto one channel, so signal quality is lower than S-video.
A hack that videophiles use is to place a 470nF ceramic capacitor across the 2 signal pins, instead of the cheaper just bridging them together.
This apparently helps to re-sync the combined signal from composite.
A tester on ohms and steady hands can test whether your cable is cheap-shorted type, or better synced type.
Across C and Y pins:
0 ohms=shorted
high reading or open=small sync cap
If making own cable mod:
Pins are closely spaced, so easier way is to strip and dress cable near S-Video plug, solder wires to cap accordingly, join composite to cap & Gnd as shown, insulate.
Nov 20, 2017 | Panasonic CT-36D31 36" TV
Panasonic CT-32G14 32" TV Logo
64 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
