Question about Iomega Prestige 500 GB USB 20 Hard Drive
Iomega 500gb Prestige external hard drive problems
Hello, my Iomega 500gb Prestige external hard drive when plugged into my macbook 13'' via USB does not show up on the computer. It now makes an intermittent buzing sound as if trying to start up something mechanical. It lasts a little less than 1 second and happens about ever 5.
We live in an old house and have tripped the circuit breaker a few times while it was plugged in. It could also be that someone has knocked it over.
I'd like to ask if there is any way to confirm the actually problem (mechanical / electronic) or to repair the device. Of course my goal is to retreive my data, but even if I can get my hard drive just to work again, it'll be good news.
Thank you sincerely for any suggestions that you might have,
-Leander Lyons
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
Iomega LPHD-UP 500GB power issue?
The fault sounds like a power supply problem. The USB port on your computer supplies up to a max. 500MA and this may not be sufficient for the external hard drive to work properly.
I suggest you get a new AC power adapter for this drive.
Apr 13, 2012 | Iomega 500GB Prestige USB 2.0 Portable...
Is it possible to boot from an Iomega eGo Blackbelt Mac Edition Portable HD and also use it to clone an existing drive? I want to upgrade an existing 160GB Internal HDD in a Macbook Pro 17" to a...
It's possible to clone to this drive, but over the USB interface, it will be very slow. Firewire would be faster. It's also possible to boot from it, but again, it will be slower than an internal. What you've described, however, IS possible.
Feb 28, 2011 | Iomega eGo BlackBelt Portable Mac Edition...
How to copy my laptop hard drive to the Iomega Prestige 500GB Compact Edition, USB 2.0 Portable hard drive? I have read the user manual and there are no real directions on how to use this product. Thanks
right click the drive you want to copy
click copy
open your lomega hard drive
right click....click paste
or
right click the file you want to copy
click send to
click the name of your lomega hard drive
Jun 20, 2010 | Iomega Prestige 500 GB USB 20 Hard Drive
Doesn't work
am not so sure if this is a similar issue with iomega2_bing.gif external drive in which the drive wont show up on My Computer but when the external drive was plugged into an ubuntu machine the drive was being detected and working just fine.
Please try to do the same. plug your external drive to an ubuntu machine and lets see if it can be detected. If it is then the hard disk has a similar issue with iomega drives. check this link for the solution.
Apr 05, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
My iomega 500gb external hard drive has a broken.
My Iomega (33654) 500GB USB isn't working. When I turn it on the blue light comes on for a few seconds. I can hear / feel it working but then the light goes off (it is still whirring inside). The computer isn't recognising it. I think it's still under guarantee but I can't find the paperwork. Do you have any ideas?
Apr 03, 2010 | Iomega (33654) Limited Edition 500 GB USB...
Transfering photos to my Iomega Prestige 500GB Portable Hard Driv
Does the Iomega show up under 'my computer'?
It should be another drive (D, E, F whatever) and as such you put stuff on to it the same way you would put stuff on to your C drive.
Mar 16, 2010 | Iomega Prestige 500 GB USB 20 Hard Drive
500GB Prestige USB 2.0 Desktop Hard Drive
Try using a different USB cable, also power off the drive and then replug in the USB cable and power up connected to computer.
Mar 13, 2010 | Computers & Internet
Iomega Prestige 1.5TB external hard drive won't start-up properly
Try replacing the power supply. Especially if all you get is a beep and no drive motor noise. The power supply is 12 V, 1.5 A, center positive polarity. Iomega may even replace it for free if the drive is still under warranty. But don't use the phone. Use their free chat-live service. Again, assuming the drive is still under warranty, which is a year, I think.
May 15, 2009 | Iomega 1.5TB Desktop USB Hard Drive
Iomega Prestige 500 GB USB 20 Hard Drive Logo
458 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
