Question about ViewSonic VX900 19" Flat Panel LCD Monitor
My ViewSonic VX900 works great for several days and then the screen turns black I have to unplug it to reset it. It will not respond from the mouse to restore the screen. When you move the mouse you see a slight flash in the screen but it still stays black.
  • 80 Answers
Often problems with LCD monitors can be traced to bad capacitors. The following sites will help you identify if your monitor has bad capacitors, and how to replace them.
www.fixyourmonitor.com and http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
Posted on Jun 13, 2010
VX900 19 in. Flat Panel LCD Monitor: when i turn it on the screen is black....
You may have backlight inverter failure, check the fuse as shown in my pictures, you can also have bad backlight assemblies also, but check the fuse on the inverter bd first, verify that you do have 12v at the fuse.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX900/
May 16, 2010 | ViewSonic VX900 19" Flat Panel LCD Monitor
Have an old view sonic vx900 (~5yrs old). When you
Check the fuse on the inverter board and also verify it does have have 12vdc feeding the fuse. Worst case will be the lamps, power supply caps look OK?
Jan 18, 2010 | ViewSonic VX900 19" LCD Monitor
My monitor will turn on for less than a second, but then will go completely black. I've tried unplugging it and checking the connections, but nothing has worked.
mrtyler7, With monitor connected to a KNOWN GOOD pc that is displaying the WIN-desktop, then and only then turn-on the Viewsonic VX900. Note what happens. After LCD screen BLACKS out tell me if the desktop can still be seen if you point a bright flashlight 1 inch form screen??? You may or may not see the desktop depending on how far the "switch-mode-power-supply" has gone into SHUTDOWN mode to try and save it's self from a catastrophic faliure. Get back to me with result of test on fixya or by email. Also check out YOUTUBE for short video clips on "lcd monitor disassembly" or "lcd repair" or search web for stuff like "swollen caps" or "badcaps.net" or "bad electrolytic capacitors" !!! You may fall into this type of failure catagory. Let me know what plan of action you will be interested in. I will also let you know what other options you have. I'm louie12fix on fixya or lmistyrel@aol.com
Oct 04, 2009 | ViewSonic VX900 19" Flat Panel LCD Monitor
ViewSonic VX900 19" monitor stopped. After it is powered down and then powered up, you see a picture for about 1 second and then it goes black again.
check your cables and unplug from the mains to reset the monitor. also if you have a seperate graphics card try using the onboard graphics if this does not work
thanks
please rate me and give me a fiya! if it works for you.
Apr 05, 2009 | Computers & Internet
Screen resolution not clear when photo put onto desktop
Hi...there,
You need to reset your resolution. Right click on your mouse, go to properties. Then click on settings, on your L/H side are your screen resolution: moved the bar to more in the middle or to your desired settings...
Oct 15, 2008 | ViewSonic VX900 19" LCD Monitor
Viewsonic VX900 blank screen
Here is a pic of the fuses on the inverter board for a Viewsonic vx900, you can visually inspect them as well if you do not have a volt meter. While visual inspection is not 100% reliable, usually when these are popped you will see the red line across them is black or broken.
Dec 06, 2007 | ViewSonic VX900 19" LCD Monitor
Vx900 viewsonic monitor problem . Blank screen except for power off/on
no, Viewsonic has the part for sale 42.99 - free shipping. Easy to replace
May 25, 2007 | ViewSonic VX900 19" Flat Panel LCD Monitor
Not responding to movement
Dear Stef, First try replacing the mouse's batteries, if this fails then try resetting it using the reset button - both on the mouse and the receiver. If you experience trouble resetting, you may try to disconnect the receiver and the mouse physically. Unplug the receiver and take off the mouse's batteries and then reconnect them.
Jan 09, 2006 | ViewSonic (CW2206) Keyboard
Computers & Internet Logo
149 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
