Question about Frigidaire FDB1050REM Dishwasher
Dishwasher is leaking from the lower right side, it appears as though it's leaking from inside of the outside cover (the metal part)if that makes any sense.
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
p
Posted on Sep 29, 2010
I have a ge profile pdw8200 dishwasher. it go thru a patial cycle then shuts off.
Check the electrical connections where the power enters the dishwasher. (behind the lower kickplate, on the right side of the machine) Open the metal cover, hold on one of the twist on wire connectors, and firmly tug each wire to make sure none are loose. Check all the wires. There is a good chance one of the wires will come right out of the twist on wire connector when given a tug. Correct the poor connection, and you should be good to go.
Jan 23, 2011 | GE PDW8200NWW / PDW8200NBB Dishwasher
Leaking from the lower right hand side during rinse cycle.
I had the problem with dribbles of water from the right side lower edge of the door, causing puddles across the floor.
Found there was a RECALL on MDB6000AWW models. The door inside panel was replaced by the dealer for free. No more puddles.
Aug 27, 2009 | Maytag MDB6000 Dishwasher
Door leaks on the floor in front of my dishwasher
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
Dec 07, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
Ge nautilus leak left side
If your dishwasher leaks, check these: Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Oct 05, 2008 | GE Nautilus 24" Built-in Dishwasher
Leaking problem from the door
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Water-inlet valve
Hoses
May 03, 2008 | Bosch 24 in. SHE44C05UC Stainless Steel...
Diswasher Leaked, now Won't Work
if you see a float inside of the dishwasher make sure its cleaned well.that float tells the control board when to drain and to fill with water.the symptom you descibe tells me its trying to drain,make sure the float moves freely.if you dont have a float you will see a metal probe clean that up as well.try this and if it doesnt fix the sensor may be part of the drain body and it has failed(leaking).
Aug 27, 2007 | Bosch SHU9915UC Dishwasher
Sgs43a Dishwasher
Most of the time with dead bosch dishwashers, i find that the wire nut has melted where the service cord is connected to the appliance. This connection is on the lower right side of the dishwasher. you get to it by removing the two screws from the toe kick, then removing the screw holding the cover on the metal junction box, if it has one. Make sure power is off, then check the two connections inside that box. Usually the black wire is melted and needs to be repaired and re-connected with a new wire nut. Good luck!
Jun 10, 2007 | Bosch 24 in. SGS43C12 Classixx...
Dishwashers Logo
122 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
