Question about Lexmark Z715 InkJet Printer
Message says paper jam, but can't find paper - Lexmark Z715 InkJet Printer
  • 4,041 Answers
Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 07, 2010
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
MESSAGE : RECORDING PAPER JAM
Dear
The paper jam is a common problem, you need not to replace to ink cart.
Check the plain paper inserted properly or there is no paper inside, Put power OFF and ON. Also some model needs to press OK or START key to remove the paper jam message after removing the jammed paper.
Thanks.
Mar 06, 2015 | Office Equipment & Supplies
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
HP 3005dn Printer Tray 1 paper jam error
If message in display panel reads [13.XX PAPER JAM [LOCATION]]Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken.
Soln.
For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation.
For message 3.0 PAPER JAM [LOCATION]
means
A non-specific paper jam occurred.
Soln
1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation.
For more help check yhis site
http://www.printertechs.com/tech/error-codes/error-codes-0-19.php
Nov 26, 2010 | HP LaserJet P3005n Printer
Hp Officejet L7480 false paper jam message. Resetting the printer has no effect.
Hp paper jam error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
May 20, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Middle light blinking message says paper
Look for any small rips of paper caught in a sensor back there. There are little "fingers" that the paper runs over and its all timed. if one of those sensors are jammed with something or sticky, error messages.
Sep 22, 2009 | HP DeskJet 550c InkJet Printer
Network Printer 12 paper jam
In order for a jam message to reset to READY, the printer logic is looking for an "06 COVER OPEN" message. The top cover of the machine must be opened to clear the jam message. If the top cover interlock switch is stuck closed, the printer logic never clears the jam message, even after all the paper has been removed. The printer appears hung with the paper jam message and can only be made READY by powering the printer Off and back On.
Jun 16, 2009 | IBM Network Printer 12 Laser
Paper jam message, but actually no paper jam
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Mar 25, 2009 | Lexmark X83 All-In-One InkJet Printer
Jammed paper message
I get a Jammed paper message on the read out, I have cleaned out all the paper and pressed stop/cancel button but it still keeps saying that there is a paper jammed in it.
May 04, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
I860 False Paper Jam Message
Check the back of the printer. There should be door at the bottom. Your paper jam could be there.
If this helps you, please rate me. Thanks, Patty
Nov 06, 2007 | Canon i860 InkJet Photo Printer
Lexmark Z715 InkJet Printer Logo
91 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
