Question about HP Photosmart M525 Digital Camera
Lens Error I am getting an error message: Lens error M525-14 (7f80). What does this mean and is it serious?
  • 4 more comments
  • Anonymous Feb 23, 2008
    lens error on my photosmart m437
  • sunshynajc Feb 23, 2008
    Lens Error: M525-14 (7f80)
  • jahsuah Mar 24, 2008
    al encender camara aparece lens error m527-14 7f80 y se apaga la camara
  • rrsmith Apr 22, 2008
    lens will not retract and camera automatically shuts down. How do i fix?
  • bingomama_07 Apr 28, 2008
    lens was stuck half way out i pushed it back in now it is stuck inside will not come out to take a picture
  • Desier22 Jun 25, 2008
    When i turn on my camera the lens doesnt eject, and it says lens error m525-14 (7f80)
I contacted HP about this & they told me that they don't offer service repair for this problem and that I would need a new camera. :/
Posted on Mar 16, 2008
HI MY CAMARA IS TURNING ON EJECTING LENS THEN IT GOES BACK IN RE SPITS LENS OUT THEN COMES UP WITH THE LENSE ERROR I HAVE PUT NEW BATTERIES IN REMOVED THE CARD BUT STILL NO JOY WHAT DO I NEED TO DO.
THANKYOU
JULIE
Posted on Mar 14, 2008
How do I restart the camera? The message says lens error and to restart the camera.
Lens error is a pretty serious problem. If power off-on doesn't clear it, it is a trip to the repair shop.
Nov 10, 2015 | Canon PowerShot ELPH 520 HS Silver 10.1MP...
Tip
Sanyo digital camera showing lens error 1114 or 112
Hi.
If your Sanyo digital camera is not starting and you get lens error 112 or lens error 1114 prompted on display, that means that the lens is getting stuck, and cannot extend or retract fully. The controller board detects the error on startup, and shuts down after displaying the error message.
This errors usually happen because of dirt, or because the lens mechanis mis damaged in consequence of a shock.
If lens does not retract, try helping the lens back, without putting too much strenght, while you turn off the camera at he same time.
If the lens does not extend, try tapping softly the back of the camera to help lens out, while you turn off the camera at he same time.
If the camera had been exposed to sand or dust, try blowing canned air on the lens.
If this does not work, the lens assembly must be taken apart completely and re-assembed, and for that you need a camera repair shop.
Also call the number listed on the owners manual to get support from the manufacturer.
Check also the links below for more troubleshooting in case of lens error:
Lens not retracting on digital camera.
Lens Error.
on Apr 09, 2010 | Cameras
I keep getting disc error message please eject disc, what can i do. thanks
Hopefully it just means you have to clean the laser lens. Otherwise it could mean a more serious problem.
Sep 29, 2014 | Toshiba Dvr20 Digital Dvd Recorder And Vcr...
What is a meaning of Error 00 for camera samsung nx10?
Error 00 error message. Disconnect the lens and carefully reconnect it when you see the "error 00" message with your Samsung camera. The problem likely occurred because the lens wasn't connected properly initially.
hope helps.
May 20, 2011 | Samsung NX10 Digital Camera
I'm getting a error message that says, "ERR 99".
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thanks
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 18, 2011 | Canon EOS 30D Digital Camera with 18-55mm...
My name is Madhu. I use the camera Canon EOS 400D / Digital Rebel XTi. When the inbuilt FLASH is on then a message pop up as "busy now", when i tried to click the camera to take a photo then...
Welcome to Fixya
Thank you
Apr 04, 2011 | Canon Rebel XTi / EOS 400D (body only)...
I get the message "error 11". What does it mean?
Error 11 is disk dirty, disc scratched, or mechanical failure. Try a lens cleaner. If that does not work, the CD player is bad.
Hope helps.
Mar 25, 2011 | Pioneer CDX-FM673 6-Disc CD Changer
99 error, CF memory card was removed to download pix. put CF card back in camera, but now get error message. removed battery and card several times, including replacing with another card. still get same...
Thank you for using Fixya!
Feb 13, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
E:61:00 on the display
E:61:00 means "Difficult to adjust focus Inspect the lens block focus reset sensor"
The simple solution to fix that error message was to the let the lens fully extend and give the lens a good whack. Possibly this error message for this means, that the auto focus motor was past the maximum set point.
goodluck
and do rate the solution if helped
Dec 06, 2010 | Sony Cyber-Shot DSC-P71 Digital Camera
Ex-z9 lens is bent and wont retrack. PUSHING THE POWER BUTTON GETS A LENS ERROR MESSAGE. aNY WAY TO GET LENS UNSTUCK
There is no DYI fix for your damaged lens, and attempting to repair it yourself will likely cause serious damage to the camera. Professional repair is needed to fix this problem.
Oct 25, 2009 | Casio Exilim Zoom EX-Z9 Digital Camera
HP Photosmart M525 Digital Camera Logo
217 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
