Double vision on my samsung HDTV 1080i
Hi, My TV is approx. 3 years old and just recently started to show double vision. It started when I moved it from up stairs bedroom to my living room and approx. a week later it started to double vision. Did the move cause the problem or how can i fix it? Thank you double vision and distorsion colors on my samsung HDTV 1080i model st54j9p
  • hdtvsamsung Mar 12, 2008
    same prob ...any solution ?
    Scholar:
  • 87 Answers
If one or more of the colors, red, green or blue have separated from each other and you can`t correct the problem using the convergence procedure as described in the users manual, that would indicate you have a convergence problem. Bad solder connections on the convergence output chips are common. If the set had a rough ride down the stairs while moving, that may have facilitated in exposing a preexisting condition. However, the most likely cause is the natural failure of one of the convergence output chips and or related components and not the move. The fix is to have a qualified technician address the problem. This is not a do it yourself job.
Posted on Feb 22, 2008
We recently moved the tv and now when we turn it on it has double vision. It kinda looks like a 3d movie. What could be the issue? Is it worth fixing?
If tv picture was fine before moved then check dry/ cold solder joints/ connections on convergence output ICs and nearby circuit area.
Local tv repairman will resolder loose/ dry solder connections to solve double vision picture problem.
TV worth fixing if picture is good.
Thanks.
Feb 18, 2011 | Sony KP-57WV700 57" Rear Projection HDTV
My smasung hdtv 1080i is about 8-10 yrs old. it
you have a convergence problum. The convergence ics go bad about every 6 years
Apr 15, 2010 | Sony KP-53S65 53" Rear Projection...
I am seeing double vision on my television.
I do not know your TV's model number, if your TV is a 3D television, please turn the 3D function off in the system menu.
Jul 01, 2017 | Sony Televison & Video
Double vision on Samsung HDTV 1080i Model PCN542R Need a convergence amp board. Where can I purchase one, and how much is it
Hi .
Its much cheaper to replace the stks on there own.
It may also have a couple of 3.9 ohm resistors cooked.
Nov 17, 2008 | Samsung HCN653W 65" Rear Projection...
Double vision on my Mitsubishi 46 inch width screen--TV is 5 years old
any repair shop can re converge the tv for you.id do some calling arond and get a few quotes to see what it would cost to have them come to you
Oct 09, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Samsung hc-p4241w problem
Look for 2 Big black chips they will be together on convergence broad STK-392-110s,120s replace both ics.Use STK-392-180s
Mar 29, 2008 | Samsung HC-P4241W 42" Rear Projection...
Im seeing double on my 36inch Mitsubishi projection!
Do the colors seem "separated" somehow?  Sounds like the projectors might have become misaligned. Has the TV been knocked by pets/children/spouse?
Nov 26, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Replace the convergence ICs. you will need two of them. They are located on a large aluminum heat sink with STK numbers. They cost about 10.00 each. They need to be soldered in. Its an easy repair if you can solder. Let me know if you need any additional info.
Sep 16, 2007 | Sony KP-53S65 53" Rear Projection...
Televison & Video Logo
384 people viewed this question
Top Televison & Video Experts
Electro Med Services...
