Question about Kenmore Washing Machines
My washing machine wont spin; its a top loading; where is fuse?
My washing machine wont spin; its a top loading machine, quite old.
gdmisp
  • 66 Answers
SOURCE: washing machine
BELT NEEDS REPLACED OUR THE DIREC DRIVE NEEDS U JOINT.
Posted on Jul 03, 2008
docjohn174
  • 943 Answers
SOURCE: Whirlpool top load washer LSQ9610LG0 wont spin but makes noise
HI thanks for your question. the part that failed is called the motor coupling. it s located on the motor and the transmission. if you need help to replace come on back. but that's the part you need to change. thanks
Posted on Oct 14, 2008
SOURCE: washing machine will not spin
MY WASHER WANT SPIN AT ALL
Posted on Nov 15, 2008
SOURCE: old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Posted on May 07, 2009
SOURCE: GE Profile wpre6100gowt, wont agitate or spin
same problem
Posted on Sep 06, 2009
Drum wont spin in washing mode. it only works for rinsing and dry spinning. sharp ES-M38 washing machine
Because i know nothing about Sharp washers could you tell me if it's front loading or top loading? Is it less than 6 years old? Does it give any error codes? Thanks.
Jan 20, 2013 | Kenmore Washing Machines
Admiral top load washer wont spin
Are you saying the machine completely quits? Or it still drains and all just not spinning after the first time?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 15, 2012 | Maytag Washing Machines
Old washing machine will wash will not spin stops after wash cycle
I worked on one that would not spin. I removed the agitator and found a king sized pillow case.
It is quite possible you have the same problem. I took some photos and posted em HERE and HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 19, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
My Maytag bravos wont spin out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 23, 2010 | Maytag Bravos MTW6600T Top Load Washer
Zanussi FJS 1425W - the machine is not spinning the clothes so clothes are quite wet when they are washed so have to spin but this is also not working well - washing purchased approx 7 yrs ago -
hotpoint top loading washing machine serial number TS182924N MODEL NUMBER HNXR1060T8WW. machine won't spin and will not empty water, just a humming noise. number on scamatic diagram 175D275OGO71 MACHINE IS APROX 20 YEARS OLD
Jan 06, 2010 | Zanussi Washing Machines
Whirlpool front load washer wont drain or spin
Sounds like the pump quit working and needs replaced
Jun 15, 2009 | Whirlpool CAM2752KQ Top Load Washer
Washer won't agitate, drain or spin
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
Oct 14, 2008 | Whirlpool LSQ9610L Top Load Washer
Washing Machines Logo
23 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
