Question about Refrigerators
Mini fridge not cooling - Refrigerators
  • Refrigerators Master
  • 4,654 Answers
Feel the compressor top is it running? no? If no unplug and jump the two thermostat wires and if runs replace thermostat. If compressor is running and not cooling there may be a freon leak inside the walls of fridge or inside the evaporator. Sea Breeze
Posted on Feb 07, 2010
My frigidaire mini fridge won't cool. Ice builds up on one of the wires on back and the cooling unit (I think) gets very hot
It sounds like it could be a restricted Capillary tube, which would require a sealed system repair by a professional repair person. A new mini fridge might be the way to go.
Sep 20, 2014 | Refrigerators
Fridge not cooling
The freezer compartment is easily damaged could have lost it's gas if you tried to remove the ice with something sharp. If the compressor is running all the time then it could be the problem.
Nov 18, 2013 | Haier 1.7 Cu. Ft. Mini Fridge With Freezer...
Model ZHSC02PP-- Mini fridge no longer cooling (18-24 months old)
Has it sat any amount of time without usage? Check and see if any of the 4 walls is cool, it could be that the fan isnt working.
Jan 30, 2012 | Haier Refrigerators
My Kenmore elite mini fridge turns on and the light on the inside comes on and the compressor is running and is pretty hot but the fridge is not getting slightly cool, what would cause this and how could i...
We had small fridge in our RV Travel Trailer.It would run to the tempure control setting,then it would shut off.Check it out,set it up high,then as is cools in about 12-24 hours then set it to 3-4 setting that should keep fridge Kool.Or you may need some fridgerant reinstall.Call your local repair man to quotes to recharge/fridge.Hope this help you out.
Aug 08, 2010 | Microwave Ovens
Fridgidaire Mini Fridge not cooling
pulled off back panel on inside of freezer, to find it was a solid block of ice. thawed, and plugged back in... working properly
Feb 08, 2010 | Electrolux Refrigerators
Fridge not cold
Hi
If the fridge in a close enviroment like a cupboard or closet??? There is not enough ventilation and hence the compressor is getting hot , reducing the cooling effency.
Or
The cooling gal has leaked and needs to be refilled.
Regards
Berry
Feb 03, 2010 | Refrigerators
Burning smell and dead mini-fridge/kegerator
If the compressor is being used for extended times without resting or getting the product cooled, could be the problem. On small refrigerators the inside is sized for the work load. The condenser coil on back or in some cases under the outside skin of the refrigerator is designed to cool the area inside by releasing the heat from inside.. You may need to modify your cooler to handle such loads with more cooling capacity and condenser with fan to help bring the product temps down more efficiently. Let me know, Thanks, Sea Breeze
Mar 19, 2009 | Sanyo SR-4912M
I have a mini fridge at school, a small Haier. My fridge is getting power and the motor gets very hot but the fridge is not cooling, not even a little... any ideas???
Hi ejb9,
I'm Harvey the Master Plumber.
Your question is: You have a mini fridge at school, a small Haier. Your fridge is getting power and the motor gets very hot but the fridge is not cooling, not even a little... any ideas???
May be low on freon or cloged expantion valve. You're going to need a certified tech to check and repair. Maybe it's time to look at the cost of repair verses replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | Haier Refrigerators
Koolatron Mini Fridge Overheating
Check the condensor fan behind the fridge which is designed to cool the compressor/gas line by blowing air over the condensor. When this fan motor seizes or stops running, the gas gets very hot and because it is skin cooled too, the outside of the fridge also gets very hot. You can overcome the problem temporarily by putting a standing fan behind the fridge, blowing onto the compressor and under the fridge untill you can have the problem rectified.
Nov 03, 2007 | Koolatron Mini Fridge Compact Refrigerator
Refrigerators Logo
542 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
