Question about Sony Reader Pocket PRS-300
I bought the sony reader prs-300 for my girl on christmas 09
Unit will not turn on, all i get is a quick flash of amber light, and im assuming that the red light thats on when it is plugged in to the usb means its charging.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 89 Answers
1. Connect the Reader to a different USB port of the Computer.
2. Connect the Reader directly to the USB port of the Computer; dont use any USB hub or adaptor to connect the Readr to the Comp.
3. Disconnect the Reader and then press the RESET button.
4. Try connecting the Reader to a different Computer to check whether the USB port of the Computer is working properly.
5. If the issue still persists, service may be required. Follow the below link to initiate the repair: http://eservice.sony.com/
Posted on Feb 08, 2010
Prs 600 ereader screen contrast problem
The PRS-300 "Pocket Edition" ereader is a device that did provide a far better than ... I bought the Sony Reader Pocket Edition to use for my public library's downloads. ... Conservatively, I probably read upwards of 20 hours each week, both ..... Well lets just say it only seems like there are a few words on the screen at a time. ...
Jan 03, 2012 | Sony Reader Touch PRS-600
I let my reader PRS-300 connected to pc all night to charge the battery, but now it doesn't turn on...what i can do??? and i tried to connect to pc again to see what happened, but not even the red...
Hi vailzamorta!
You can try to do a "Soft Reset" on the Reader. Do not worry, this will not affect your ebooks =)
1. Disconnect the reader from the computer
2. Hit the Reset button at the bottom of the unit for 3 seconds with a paper clip
3. Slide the power switch at the top of the eReader
4. The screen will blink and show opening book.... allow the reader to load
Just in case here are some other steps to try in case this does not make any difference
http://digialreader.freeforums.org/solution-for-frozen-sony-reader-t10.html
GoodLuck!
eBookBoy
Jul 26, 2011 | Sony Reader Pocket PRS-300
When i turn on my prs 300, the screen flickers and the light on top is yellow. when its done trying to turn on the light flashes a few times and thats it.. i've tryed several computers and they cant...
Hi jmjohnson198!
1. Connect the reader to the AC Adapter (If available). If not, then connect the Reader via USB to the computer
2. Hit the reset button for 3 seconds.
3. The red steady light should come on, if not, try the reset again while the unit is connected
4. Allow the reader to charge for 40 Minutes (on PC make sure the computer does not go into sleep mode.
5. Disconnect the reader and see if operational.
GoodLuck!
eBookBoy
Jul 16, 2011 | Sony Reader Pocket PRS-300
It's hung up on the opening book. The only other thing it will do is say usb when attached to computer. I have a Sony E-Reader. 300.
jcow874580,
Probably a charge issue, follow this. Hope this info helps:
1. Connect the reader to the computer for 15 minutes (make sure a red steady light comes on)
2. Disconnect the reader and hit the reset at the bottom for 3 seconds
3. Try to turn the unit on
This should resovle the problem
eBookBoy
Jun 29, 2011 | Sony Reader Pocket PRS-300
My sony PRS300 screen is frozen and unable to shut off the screen
I have this same problem with my PRS-300. I can reset it by connecting it to AC power and resetting it, but it continually freezes up, rendering the unit useless. The Sony repair facility in Laredo has had the unit since 8/27 and has not been able to repair it.
Sep 11, 2010 | Sony Reader Pocket PRS-300
Sony PRS 300 reader STUCK, FROZEN, 184 books on it!
did you use the usb to recharge it? maybe you've connected the usb to the ebook but it didn't recharge. The battery will drain if you just connect it to the computer but didn't recharge (bad contact between the book and usb, mine does that). try to recharge it, make sure the light beside the on/off button is on (red), let it sit for few hours that it should be fine
Aug 02, 2010 | Sony Reader Touch PRS-600
My Sony reader prs-600 is frozen. The reset button doesn't do anything. How do I unfreeze it? A part of my screen still works, but a big part doesn't. What can i do?
Try holding the reset for 5-10 seconds, then flip the power switch quickly, three times. If this doesn't work, check the light next to the power switch. If it is flashing yellow, follow the same process. It might take up to three tries.
Jul 21, 2010 | Sony Reader Touch PRS-600
Broken screen for sony prs-300
Since the screen of the Reader is broken, you require to send the Reader to the Sony Service Center. Remember that this will not be covered under warranty, since this is physical damage. However, this Reader is covered under the Sony exchange program. This excange is with the simmilar or comparable model. Please go through the below mentioned page get the information about repairing the unit or about getting exchanged.. http://eservice.sony.com
Jan 23, 2010 | Sony Reader Pocket PRS-300
Cant get the reader library installed on my computer
Perform tyhe troubleshooting steps listed on the page to get the issue resolved: http://www.kb.sony.com/selfservice/documentLink.do?externalId=C1003504
Dec 27, 2009 | Sony Reader Pocket PRS-300
Sony Reader Pocket PRS-300 Logo
1,183 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
