Question about Presto Cool Touch (07034) Indoor Grill
I lost the paper that came with the griddle with the temps for cooking different food types. ie: pancakes are at 250 degrees and sausage at another temp. do you have one I can print off my computer?
I asked a friend with the same grill
Posted on Feb 08, 2010
I need a 20-in. Electric Griddle. know of any?
Yes, Lodge made a nice 20 inch cast iron griddle has bigger surface to cook more food with two side handles to make it easy to move. You have some other options like Presto 22 inch griddle, check out this link for different size griddles and pans with detailed information.
GroomNStyle Top 5 Best Saucepan and Pot reviews 2015
Feb 20, 2013 | Kitchen Appliances - Others
What do you use an electric griddle for?
I use mine for okonomiyaki. This way you cook it at the table and it stays warm and then you eat it!
for more about how to make this:
http://www.closetcooking.com/2009/05/okonomiyaki-japanese-pancake.html
Jan 24, 2013 | Kitchen Appliances - Others
Cuisinart Griddler won't cook pancakes
That is one of my favorite griddles. its possible you opened the lid too early while cooking that is why you couldn't achieve the browning you desired. You can check our post for more info on the Best Electric Griddle Pan.
Top 6 Best Electric Griddle Pan 2017 Buying Guide For Cooks...
Sep 20, 2017 | Cuisinart GRID8PC Griddler Adjustable...
Food sticks to griddle
You can either use a cooking spray like Pam on the griddle prior to heating it. Or if you're cooking steaks, rub a little olive oil on each side of the steak, before seasoning (kosher Salt & Fresh Ground Pepper) it. For meats, always allow them to come to room temperature before grilling and allow the grill to preheat until is extra hot. The hotter the grill/griddle, the less likely red meats will stick to it.
Hope this helped you and Happy Grilling!! Thanks for choosing FixYa.
Aug 12, 2011 | Coleman Roadtrip Grill LXE 9949-750
I press the bake button, i choose temp Ie:350 degrees, wait until goes up to temp, next thing you know, it shows 350 but the food is not cooking. press cancel, press bake and 350, temp starts to climb from...
More information is required make model, display type LED, or blue neon red light goes out when on temp, without more info cannot help.
johnf1
May 17, 2011 | Ovens
Cleaning the griddle of our Dynasty Range and standard operations.
This addresses the cleaning question only. I was a chef for 27 yrs.  Once the griddle surface has begun to rust, and this can and even will be the case on a new stove, you have to get agressive with it. You're going to use sanding tools and oil.
If the griddle top is heavily rusted, I use my electric palm sander fitted with fine emory paper (the black stuff that can get wet). Wet down the surface with a small amount of oil and work the sander evenly over the entire surface in rhythmic strokes from front to back or side to side. I don't have a scientific reason for this but my gut tells me not to work in circles or random strokes. Try to work the entire surface evenly to avoid creating high or low spots. Use a straight edged spatula or I use a dough cutter (flat edge of about 4" and available from culinary store for under $10) to cleanly scrape  the dirty oil off the surface. Sand in shorter durations & clean often to avoid grinding dirty flavor into the surface.
Once you have it clean its time to season it. With a better oil focusing on flavor, spread a thin layer over the surface and cook at about 250 degrees for 15 - 20 minutes. Repeat this after every use until you build up a layer of cooked oil almost like enamel to resist rust between uses. This makes a teflon like finish to your griddle.
For regular use and cleaning scrape down immediately after cooking and while the griddle is still hot. When its cool use a hand sanding block you can get from the hardware store. The one I prefer is a firm sponge with emory paper wrapped around it. I store this in a bowl on the shelf above the stove because it is oily and dirty. Alternately you can also use rock salt and a kitchen rag to loosen food particles stuck to the griddle but this makes for messy laundry or throw away rags. We also use viengar or lemon juice and water to loosen food while the griddle is still hot or warm. NEVER USE SOAP!!!!!! You want your food to taste good don't you?
The oil used for cleaning can be anything with minimal flavor like canola oil but the oil used for seasoning the griddle should be a high heat type like sunflower.
Personally I only cook in black cast iron pans and the above method is how I treat them as well. Rock salt and water is all I ever need to clean them between uses.
Rick Casey
Jun 22, 2008 | Dynasty DGRSC 48-4GCB Gas Kitchen Range
Not cooking completely
replace the oven temp sensor. it looks like a probe that is in the oven, at the top
Jan 25, 2008 | Frigidaire FEF366DC Electric Kitchen Range
Temperature
You can cook anything on this that you can cook in a normal frypan. Check your cookbooks & use the same temps that you would use with an electric frypan. For eggs & bacon, 300-350F would be a good place to start.
Jul 16, 2007 | Toastmaster TG21W Indoor Grill
Presto Cool Touch (07034) Indoor Grill Logo
74 people viewed this question
Top Presto Kitchen Appliances - Others Experts
Paul Bade
Jim Goldsmith
Jim Goldsmith
Are you a Presto Kitchen Appliances - Other Expert? Answer questions, earn points and help others
