Question about Yamaha RX-V2600 Receiver
RX-V2600 Yamaha Optical connection from a TIVO 3 box. Some commercials I receive only a bass sound from, no audio. It changes when the next things starts, i.e. another commercial or the main program.
Selected Stereo 7 option on the 2600. Closed.
Posted on Apr 02, 2010
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
Connecting a YAMAHA RX-V2700 receiver to my TV and cable box
why not you use a normal AV cable
instead of hdmi cable
May 22, 2008 | Yamaha RX-V2700 Receiver
Yamaha RX-V2600 completely dead ... any ideas
If it is plugged in to a working outlet, and the AC cord is not broken, there is a problem in the power supply of the receiver. This provides all of the DC voltages that make all functions work. If it is completely dead, the display, the lights, the audio, (everything) is not working; and it is not likely there are separate problems in all of these areas at the same time.
Feb 17, 2013 | Yamaha RX-V2600 Receiver
I have a yamaha RX-V 2500 receiver that won't turn on.The front display stated to check the speakers, now the unit won't turn on at all you here is a clicking sound coming from the left rear of the unit....
Have you checked the speaker connections as requested? How about disconnecting all speakers and seeing what happens? If it works, you have a shorted speaker or wire.
May 13, 2010 | Yamaha RX-V2600 Receiver
I want the tv sound to go through my yamaha rx-v363 receiver
You can do a couple of things depending on your unspecified TV and/or cable box:
For vanilla TV stereo (at best) audio: if the TV has RCA audio out jacks, run them to DTV/CBL or TV input.
For cable box (potentially multichannel) audio, if your cable box has a digital coaxial or optical audio out, run it to one of the digital in's on the receiver.
Jan 24, 2010 | Yamaha RX-V463 Receiver
RX-V2600 HAS BLOWN FUSE CB5 10A 250V REPLACED NOW RECIEVER WILL CLICK THE RELAY ON THE OFF ANY SUGGUESTIONS WE CHECKED ALL OUTPUT TRANSISTORS
check the DC converter and associated transistors. an overload may have taken some out, and rendered the unit useless.
Jun 11, 2009 | Yamaha RX-V2600 Receiver
Since hooking up my dvd player(blu-ray)with hdmi, my video completly drops off after the receiver has been powered up for about 3 mintutes. This is not a problem when using component input and output- only...
The RX-V2600 is first generation HDMI and the firmware is HDMI 1.1a or b It will not pass video via HDMI. It's not a Yamaha problem, it was an HDMI problem. Every receiver with 1.1 or 1.2 firmware has issues. The newest version is 1.3b and so far so good. I'm a home integrator and still am leary of HDMI for that very reason! expensive cables too! if you are viewing on a TV 50" or smaller, the human eye cannot see the difference between 720p and 1080p. if your TV is bigger, run the HDMI directly to the TV and run Digital Coaxial or Optical audio to your receiver. That is the only solution. Hope this helps
Mar 22, 2009 | Yamaha RX-V2600 Receiver
Not reading digital sound, only analog
do you have the "B" speaker selector button pressed? i believe that it will only run in Stereo mode when running both at the same time.
Mar 01, 2009 | Yamaha RX-V2600 Receiver
Problem hooking up my Yamaha RX-V461 to my PS3
When you connect the optical cable to the ps3 you must change the output to optical on the ps3. To do this, startup your ps3 then go to settings then audio output settings and change it to Digital Out (Optical).
Dec 01, 2008 | Yamaha RX-V461 AV Receiver
Yamaha RX-V2600 Receiver Logo
78 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
