Question about Apple iPhone 3G
Iphone was syncing with itunes sync stop iphone stuck on apple logo
    President:
  • 1,871 Answers
Just pull out the battery and try again . that should solve the problem.
If the phone software was corrupted during the process , then restore factory settings . after that i recommend you to update the software of your device .
good luck .
Posted on Feb 07, 2010
How do i sync my iphone to apple itunes
try for these steps :
connect your iPhone to iTunes .
on the computer select your iPhone.
click music> syn Movies
click option> syn option for any other
click apply to sync your iPhone at lower right bottom.
For more help https://www.apple.com/support/iphone/syncing/
and need any technical help Mac Tech Support .
Jun 24, 2014 | Apple iPhone 3G
How do i get the connect to itunes logo jammed on to turn off
Connect it to iTunes and sync it. That's what that means. The phone needs to by connected to iTunes so it can sync it and activate it for use.
There's no way around that. Thats Apples rules
Aug 24, 2011 | Apple iPhone Smartphone
Only in my iphone 3 apple logo cmng and itunes sign is coming with conector sign
That means you have to sync your phone with iTunes.
And to do that you must have an iTunes account (free) and the latest version of iTunes (free)
Then once you get those and iTunes installed, This is what you do
  1. Download and install the latest version of iTunes on your computer.
  2. Open iTunes.
  3. Connect the iOS device to your computer using the included USB cable and select it in iTunes under Devices on the left-hand side.
  4. Set up which items are to be synced: Click the corresponding tabs in iTunes to specify which information you want synced between the iOS device and your computer.
  5. Click Apply, in the lower-right corner of the screen, to sync.
I hope that helps you out. Anytime the Apple logo shows up with the iTunes logo that means the phone needs to by synced with iTunes and your apple account..
Thank you
Aug 21, 2011 | Apple iPhone 3G
My i phone will not sync with i tunes
Make sure your Itunes & Iphone have latest updates. Apple has updated 3 times since February and it can mess up sync. Update your computer first (under Apple logo - "software update") then log onto Itunes and update Iphone
Mar 28, 2011 | Apple iPhone Smartphone
My iphone 3g has frozen whilst syncing with itunes, apple logo and a space bar on screen now, cant turn off or home button not doing anything, phone goes straight to answer phone, help please thankyou
Sounds like it failed a software upgrade. Reboot by pressing and holding the power and home button for about 20-30 seconds, Then try syncing to iTunes again.
Mar 19, 2011 | Apple iPhone 3G
Iphone is stuck on apple logo
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Nov 30, 2010 | Apple iPhone Smartphone
How to sync outlook with my iphone without using itunes.
you have to use itunes. that is one problem with the iphone, its very dependent on itunes. so to sync your calendar, contacts, messages, or other files in the phone, you have to sync it with itunes.
Jul 26, 2010 | Apple iPhone Smartphone
I can't find sync in itunes ,can't sync iphone
Reset
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Sep 28, 2009 | Apple iPhone Smartphone
My Iphone 3g 8gig is stuck on the Apple logo
Try each of the following resets:
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jul 23, 2009 | Apple iPhone 3G
Sync iphone to outlook contacts
Speaking of syncing iPhone with Outlook, you can take advantage of iTunes to sync contacts. sync-iphone-outlook-contacts-oxaxc0rwhkhzilrwacqreyis-3-0.jpg
  1. Connect iPhone to computer with USB cable, and launch iTunes.
  2. Click iPhone icon, and choose Info the Summary Panel in left sidebar.
  3. Check Sync Contacts with, and choose in the drop-down menu.
  4. Click Apply at the right bottom to start syncing iPhone contacts with Outlook.
When the sync is finished, the contacts will show up in the Outlook contacts. Besides syncing contacts, you can also sync iPhone calendars and mails to outlook as well. But if you have noticed, the sync of iTunes is an annoying issue among iPhone users as during the sync of iTunes, the application may erase the available files in their iPhone.
http://www.leawo.org/tutorial/how-to-sync-iphone-with-outlook.html
Jul 19, 2009 | Apple iPhone Smartphone
Apple iPhone 3G Logo
16 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
