Question about Protron PLTV3250 32 in. LCD Television
How can i change on dtv ,the mode air with cable
  • 11,896 Answers
When in the main menu, there should be a setting/option for tuner. Then if you have regular tv, switch it to AIR. If you are using cable, then switch it to CATV.
Posted on Feb 07, 2010
Getting snow when connecting polaroid tv to dish
Hi bevybab!
I would need more information as to which TV (1 or 2) you're experiencing the problem with, but if this is a new TV it sounds like you may need to change the modulator setup.
You can find the setting under Menu -> System Setup -> Installation -> Modulator Setup. If this is TV1, change the TV 1 Out to channel 3 or 4 depending on what you have listed. If this is TV2; change the mode from air to cable or cable to air and then put the TV on the channel it shows after selecting done to save the settings.
If you can provide more information or have any other questions let me know!
Tommy Faust
DISH Internet Response Team
Nov 27, 2011 | DISH Network 322 DTV Receiver
Hi my sharp lcd tv when switch to DTV mode, the picture freezes however the sound still remains. I cannot change channels or go into any DTV menu options. Have you encountered this before?
It is probably not the TV , but coming from your signal source, cable box, or statile, and allot of times it is do to bad cabling, need to run new cable, RG60.
Jan 25, 2011 | Televison & Video
How change setting to received a digital signal. Look like TV is in Analog mode. I put a coverted BOX and see TV without any problem but without converted Box, I see a white screen with noise. TV Model:...
U want free air DTV?Yes,have a good Digital antena or a roof antena hood up to ur tv.Goto the tv menu.Goto SETUP go down to Ch.setup enter and pick AIR not CABLE.Enter it again for scanning for DTV free air channels.After done the scanning u should have all the free DTV free air channels.
Jan 24, 2011 | Protron PLTV-32 Television
I have a Motorola DCT6200 DTV Receiver and the remote I am using for the device is not responding. I can still turn off my physical TV with the remote, and can still change channels on the Receiver itself,...
wrong mode!!!!!
put your remote back in cable mode and you will be back to normal.
usually up near top sometimes push "mode" then "cbl" sometimes just push "cable"
good description of problem, I can tell your a thinker.
99% sure this is your problem though
good luck
Dec 27, 2010 | Arris DCT6200 DTV Receiver
I change the tv # 2 and now I can't get to set the signal
Hey! My name is Becki Barned, and I am with Dish Network customer service! You have already gotten this issue resolved, but here are some steps in case you haven't! On tv2, try channel 60 and then 73. if that doesn't work, try to go to tv#1, press menu 6-1-5. Here, change (under tv2 out) the MODE setting from AIR (if it is on air) to CABLE, and vise versa. If the tv cannot go up past 69, make sure that the MODE is set to AIR. That's changing the setting for the TV#2, and with a new tv, this will usually fix it! Blog if any troubles!
Aug 21, 2010 | DISH Network 322 DTV Receiver
Never been able to get 1080i hd through HDMI cable or uhf hd antenna
The programs u are watching must air in HD to get 1080i.Like ABC,CBS are air in HD most of the times.Press ur remote display button will see what modes the shows are playing on.Alot of the channels programs only play on modes 420i,720i modes are just DTV.
Mar 24, 2010 | JVC HD-52G886 52" Rear Projection HDTV
Y/Pb/Pr outputs are green; needs
There is no calibration for the component video that I know of, check your cables you may have a bad Pr cable or the Pr/Pb ones may be mixed up.
Y (the green one) is for luminance, plug in ONLY this connector and you should see a black and white picture.
Now connect the Pr. You will now see red tones.
Now connect the Pb. And you will see blue tones.
Reverse the Pr and Pb and see what happens.
Oh and make sure you don't accidently have one plugged into a composite video or digital audio port.
Still not looking right?
Go into the input menu of the TV and change the component (or colourstream) input from RGB to Y/Pr/Pb. (most TVs do not have this feature.
Hope this helps!
Jan 24, 2010 | Samsung SIR-TS360 DirecTV DTV Receiver
The screen says Air, No signal the channels will not change on tv or remote DTV 265-D with built in DVD
Do you have an anntenna connected to the tv?  if so go to the menu and do Auto Channell Search. If you do not have a anntenna and have a cable or sattilite box you need to change the tuning band from air to cable.
I can assist further if needed.
lone99star
Dec 31, 2008 | Mintek DTV-263 26 in. LCD Television
No sound all of the sudden when on dtv
make sure input mode selector on the front is set to either analog or or digital. For example if the sound input from the dtv/cable is analog and you have it set to digital, you will get no sound. Change it to analog. This happens to me when using my crappy dvd/vhs player and I have a vhs playing (analog). Hope this helps...
May 22, 2008 | Yamaha HTR-5840 Receiver
Mintek DTV-263 26in with No Color
please locate with your remote and change from NTSC to PAL or from PAL to NTSC while whatching cable
Jan 09, 2008 | Mintek DTV-263 26 in. LCD Television
Protron PLTV3250 32 in. LCD Television Logo
43 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
