The cold water will not shut off even when the machine is off.
  • 32 Answers
INLET VALVE NEED REPLACED,STICKING OPEN,LACUZ12
Posted on Feb 07, 2010
Even when the machine is set to cold it pulls in hot
not sure on that one most machines are cold fill now,,think it is to do with the valves been closed , even though the machine is in a cold wash it registers a fault when any of the valves are closed
Nov 10, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Have a top loader Admiral which has a shut off problem: cold water will not shut off even when unplugged...figure it's the cold water selonoid.
Yes exactly the problem w/power off and it continues to fill it's defiently the solonoid valve
Gene
Aug 04, 2011 | Admiral Washing Machines
I have a Maytag (FAV6800AWW) top load washer. The cold water won't shut off except at the valve. The cycle will run properly with hot water but if you have the cold on it just runs until it...
the water valve is bad in the rear area inside the machine,its controlled by electrical solenoids and the valve is stuck open even with the unit shut off,replace the valve combo hot and cold as these dont repair
May 29, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Why the cold water keep coming even when the washing machine is of
the cold water is coming in the machine when the water is off is that what you said? shut off the faucets that go to the machine bad water valve its the piece that the hoses connect to please write back to clarify on when the cold water shuts off thanks again
Rick
Dec 03, 2010 | LG WM2277H Stainless Steel Front Load...
Kenmore HE 3.8 washer has only hot water even with cold settings
If the washer fills very slowly when you have it on a cold setting the cold water may be shut off behind you washer or possibly the hot and cold are switched. if that is not the problem then you have a relay problem with the machines electrical system.
Jul 01, 2009 | Kenmore Washing Machines
The cold water does not shut off. The machine
Need to replace the inlet valve assembly. Dont know what make or model it is, but the part is relativly cheap, and the job is not that hard. Just getting in the cabinet to replace is the hardest part. With many different models, would need to know what model you have to get you in the cabinet.
Apr 26, 2009 | Washing Machines
HOTPOINT WD62 FILLS WITH WATER WHEN NOT BEING USED
All washing machines have a solenoid valve for turning on and shutting off the water coming in, one for the hot water and one for cold. It sounds like one of them has a slow leak.
Try shutting off the cold water supply to the machine for a day and see if the tub fills with water. Next try shutting off the hot water supply and leaving the cold supply on. This will tell you which valve is leaking.
This solenoid valve is something you can buy from an appliance parts company. In some cases, someone handy may even be able to disassemble it and replace a washer that is leaking.
Until it is repaired, you can get by with shutting off the water supply when you are not using the machine or shutting off the supply that is leaking. For example, if it's the hot water supply valve that is leaking, just shut off the hot and do only cold water washing.
-Vince
Oct 03, 2008 | Hotpoint Washing Machines
Cold water will not shut off even when washer is off.We left unit unpluged over nite and still have same problem LG washer # wm1814cw overfills
You have a stuck cold water solenoid valve.
Try openning the machine and tap on the cold solenoid valve.
If this dowes not work, you may have to replace the valve.
Mar 25, 2008 | LG WM1814CW Front Load Washer
When temp is set on hot water--hot water shuts off & cold water comes out
In the machine, you have a solenoid that the water hoses come into. That piece is controlled by a timer. The hot water during the cycle, does it shut off completely during fill or intermittent?
Mar 16, 2008 | Washing Machines
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
