Question about Jensen Car Audio & Video
Jensen uv10 amp hook up
Jensen uv10 amp hook u, i hooked rcas up to rear speaker rca. where do they go, because everytime i turn volume up the radio cust off
How to power on the amp on my flip out headunit
Posted on Jan 04, 2011
You can leave them there and change your fade settings or you can try to hook them to the sub output you will just have to get rca splitter
Posted on Oct 28, 2013
I hooked up my 2 dvc 12in subs to 1100 w interfire ib2900c 2ohm stable amp..however after hooked up subs make very loud bababababa sound when turned on ..what don i do to fix this?
It's in your rca lines or you are missing or don't have good enough ground to your amplifier or CD player. To check this simply unplug your RCA's at the radio it's your radio. If it dosent it's in your rcas
Oct 22, 2015 | Car Audio & Video
Radio works no power to amplifier 1992 ranger
The power goes to your amplifier straight from your battery into your amp so make sure that's good and there's a blue wire behind your radio should say remote you extend that wire to your amp and that tells it when to turn on and of course the rcAs from your radio to amp if it's a stock radio go buy a LOC cause it won't have rcas and to use a LOC well you have to take the speaker wires and hook them up to your rear speakers and then take the rcas from the loc and plug them in the amp but make sure the amp is grounded first
Jan 26, 2014 | Car Audio & Video
How to wire kicker 07cvr124 4ohm duel voicecoil 12in sub to my rockford fosgate 4channel punch 600r amplifyer
run the positive from one voice coil the the negative on th other than take th left over positive from one voice coil and the negative from the other and bridge it to the amp use the blue sub wire but u will have to buy a 1 unto to splitter to hook up ur rcas from amp
Mar 28, 2012 | Rockford Fosgate Car Audio & Video
On my amp the protection light apperas when i hook the rcas up (red and white cables), i changed the leads looked at all the other leads eg power earth etc. do you have any ideas, many thanx wayne
turn down the amps gain and radio volume to lowest.
a. disconnect the RCAs at the source end. (at the head unit)
b. connect only 1 RCA at a time to the amp. ok?/fails?
still fails? u have a short in the RCA wire. toss it.
didnt fail?
a. with radio off, connect RCA to radio while RCAs are connected to amp.
fails? you've got a dead short on radio side.
does not fail? turn on radio...fails? radio is issue. (not very likely though)
my quess is that you've left out a significant observation as the probability of a shorted radio is low and you say you swapped RCAs.
May 08, 2011 | AudioBahn Car Audio & Video
No audio with uv10
I have Jensen uv10. I hooked it up and this no sound in a 94 f159 4x4
Mar 20, 2011 | Jensen Car Audio & Video
What is the parking/ emergency brake code to bypass the jensen uv10 dvd player
uv10 radio dvd player all you have to do find the wire on the back uv10 radio and ground it..( parking brake wire)
Jan 31, 2011 | Jensen Car Audio & Video
When my RCAs are hooked up to my amp, my subs start hitting without any volume turned on
1. Check Grounding system (Player and Power Amp).
2. Ensure your RCA cable is OK
3. You might adjust volume or bass volume on power amp to maximum, just set all to 50% while you are tuning.
Mar 28, 2010 | Kicker CVR12 Car Subwoofer
Subs hit without volume on
4. Check the speaker out cables might contact the ground/ chassis
Mar 28, 2010 | Kicker CompVR 05CVR84 Car Subwoofer
Jensen cd 2610 aux input has little volume
first of all the rca jacks in the back of your radio are for plugging in an amp, not your mp3 player. there should be an auxiliary jack(looks like a headphones jack) in the front of the head unit. if there is no auxiliary jack in the front then you will have to go buy a new head unit with an auxiliary jack.
Jan 27, 2009 | Jensen CD2610 CD Player
Amp
if its the factory radio more likely it dont have RCAs ..You will need a 'speaker to line level adaptor" ..This has 3 or 4 wires at one end and RCAs at the other.simply connect a left and right set from behind radio or from rear speakers into left and right sets on adaptor ..then connect your RCA cables side to amplifier using RCA wires.
Dec 15, 2007 | Car Audio & Video
Car Audio & Video Logo
847 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
