Question about LG DLE5932W Electric Dryer
Cannot select all cycles
Dryer turns on; turning selector counter-clockwise, it skips over delicates and ultra-delicate. Can select all other cycles. turning selector clockwise it gets stuck on ultra-delicates.
  • 489 Answers
You have a problem with the display board and may need to be replaced.
Posted on Apr 28, 2008
Why does my top load whirpool washer restart on its own after it finishes the last rinse and spin cycle. It does this on all settings, delicate, normal or heavy.
  1. Turn the washer off.
  2. Set the mode selector dial to NORMAL.
  3. Turn the dial counter clockwise ONE click (LEFT), clockwise THREE clicks (RIGHT), counter clockwise ONE click (LEFT) then clockwise ONE click (RIGHT).
  4. Now press the start button.
  5. All the cycle indicating lights should be illuminated.
  6. Press the Start Stop button once.
  7. Rotate the dial until Rinse, Wash, and Stop light illuminate.
  8. Turn the washer off and unplug it for 10 seconds.
  9. Finally, turn on the washer and it should now be reset.
  10. Run a test load empty to be sure the reset worked. If not perform the reset procedure one more time.
Oct 07, 2016 | Whirlpool Whirpool 3.5cu ft Top Load...
Kenmore 70 series dryer 110.96573220 only heats on time dry and delicate, not on normal
I would check the temp switch located in the console panel, sounds lile maybe the contact is burned since you have heat on delicate and timeddry.
Feb 02, 2013 | Kenmore 60172 Electric Commercial Dryer
My frigidare affinity dryer is only starting on delicates and touch up, can you tell me why this is happening?
Hi.
If machine runs only in low heath cycles, then there is a problem with timer control, low heath selector, or heating assembly (cycling thermostat).
The first thing to do would be locating the tech sheet. The sheet is tucked inside an envelope located inside the control panel assembly. In the tech sheet you will find instructions to run a diagnostic cycle. The diagnostic cycle will return an error code that will help locating the fault.
With different Frigidaire Affinity dryers you need to press and hold Pause Cancel and SELECT for about ten seconds, then leave, put selector to NORMAL, temperature selector to HIGH HEAT and touch START to run the diagnostic cycle. The procedure for this specific model is described in the tech sheet.
Regards.
Ginko.
Nov 19, 2011 | Dryers
My frigidare affinity dryer is only starting on delicates and touch up, nothing above that
Hi.
With different Frigidaire Affinity dryers you need to press and hold Pause Cancel and SELECT for about ten seconds, then leave, put selector to NORMAL, temperature selector to HIGH HEAT and press START to run the diagnostic cycle. The procedure for this specific model is described in the tech sheet.
I have a Whirlpool electric dryer, it is a Duet with a model # of: GEW9250PW1. When I try to select the the "normal" setting on the automatic side, it lights up the delicate light and has the...
Is the selector knob loose on the stem? Look on the knob to see if there is a set screw of some sort that you can tighten to set it where it belongs, it just seems it's loose and isn't pointing to where it should. Let me know if this works or not,
Please rate and comment, Thank you,
Joe
Sep 01, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a GE Washing/dryer Stackable machine combo. The speed maintain normal speed even with the Delicate Clothes option. How to trouble shoot? There is a Siebe Control that is connected to the timer Knob...
The speed change voltages are selected by the timer contacts. Try rotating your timer clockwise rapidly through several revolutions then select a delicate spin cycle and see if the speed is still too fast. If it is then the most likely suspect is the timer itself.
http://www.appliancepartspros.com/part_details.aspx?part_id=2045983
Model number used: WSM2780WAWWW
The timers are the same.
Thanks for using FixYa.
Kelly
Mar 18, 2010 | GE WSM2780W Stacked Washer / Dryer
Kenmore dryer model # 11067072600 I am getting a F40 error code after 3-4 minutes in any cycle and then the dryer stops. I have checked all connections & continuity. During the diagnostics test mode...
i would have to guess that its a problem with the control board. if it were the user interface it would most likely fail right away and not after a few minutes.
either one are expensive, but the board should cost about 120 bucks
Mar 13, 2010 | Dryers
Delic ate cycle taking too long to dry
This is normal because the delicate cycle is a low heat cycle.
Aug 01, 2009 | Dryers
Dishwasher finis tone
  • Open door, push and hold Delicate/Econo button, then turn the dishwasher on while holding Delicate/Econo button.
  • Release Delicate/Econo button.
  • If module beeps, then end of cycle tone is on. PressDelicate/Econo button to disable tone.
  • If module doesn’t beep after button is pressed, then tone is disabled.
  • Turn off dishwasher to save selection.
Jan 27, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Amana Washer model number LWD27AW
Try pulling the knob out & rotating counter-clockwise to unscrew it.
Nov 28, 2006 | Amana NAV5805A Top Load Washer
LG DLE5932W Electric Dryer Logo
243 people viewed this question
Top LG Dryers Experts
Mike
Mike
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
