I have a 6 year old Dell with XP, plenty of hard drive and memory. I could not scan using the software, I went on the Kodak website and followed the
Step-by-Step Solutions and Repair which nothing worked, including the Kodak Clear Utility they reccomend for ridding your system of the software, it just locked up at the end.
So, I spent several hours on the phone with Technicians trying to uninstall and reinstall the ESP3 software. None of their methods worked even step by step manually un-installing every file and folder...
So I wrote a nasty email to them and they sent this back, which by the way, didn't work for me either, but maybe it can for you.
According to your email, the issue is that you have not been able to
install the software for the printer on your computer. We understand
the importance for you to have your printer working properly.
To help resolve this issue, please follow these steps in the order they appear:
1. Disconnect all USB devices from the computer, including the Kodak EasyShare all-in-one printer.
2. Uninstall the Kodak EasyShare 5000 series all-in-one software:
a. In the Control Panel, select Add or Remove Programs (Windows XP) or Program and Features (Windows Vista).
b. Select one of the following software programs from the list of currently installed
programs, depending on which one appears in your list:
Kodak EasyShare software
Kodak all-in-one printer software
c. Click Change or Remove (Windows XP) or Uninstall (Windows Vista).
d. When the Install Wizard appears, click Next.
e. Depending on the issue(s) you are experiencing, do the following:
If
you are experiencing errors with the Kodak EasyShare software, such as
a Tricode, in addition to errors with the KODAK AiO Home Center
software, select Remove, click Next, and follow the on-screen
instructions for removing the software.
If you are not
experiencing errors with Kodak EasyShare software, select Modify to
uninstall only KODAK AiO Home Center software, and click Next.
f. In the Custom Setup window, select Remove from the drop-down menu for the Kodak All-in-One Printer, and click Next.
g. In the Ready to remove the program window, click Next.
h. In the
Uninstall Complete window, click Continue.
i. Restart the computer.
3. Delete the files and folders that can interfere with the installation.
For Windows XP, delete:
a. Printer folder in C:\Program Files\Kodak
b. Both the Eastman Kodak Company and KDS_Kodak folders in C:\Documents and Settings\All Users\Application Data
c. Kodak 5000 Series AiO folder in C:\Documents and Settings\All Users\Application Data\Kodak
d. Printer folder in C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup
For Windows Vista, delete:
b. Eastman Kodak Company folder in C:\ProgramData
c. Eastman Kodak Company folder(s) in C:\Users\your name\AppData\Local
4. Run Disk Cleanup.
a. Open My Computer.
b. Right-click Local Disk (C:) and select Properties.
c. Click the Disk Cleanup button.
d. When the Disk Cleanup for (C:) window appears, select the
Temporary Internet Files, Recycle Bin, and Temporary Files check boxes.
e. Click OK, and then click Yes to delete all files and begin the Disk Cleanup.
f. When the Disk Cleanup is finished, click OK in the Local Disk (C:) Properties window.
5. Shut down all background applications.
a. Select Start > Run.
b. Type msconfig in the Open field, and click OK.
c. Select the Startup tab.
IMPORTANT:
If not all the applications in the Startup Items list are selected,
write down which applications are selected so you know which ones to
turn on again later.
d. Click Disable All , then click OK .
e. When prompted, restart the computer.
6.
After the computer restarts, insert the KODAK EASYSHARE 5000 Series
All-in-One Software CD into the computer CD drive to begin the
installation.
a. Insert the printer software CD into the CD-ROM drive.
b. In the KODAK EASYSHARE 5000 Series All-in-One Software window,
click Next.
c. Select CD Installation, and click Next.
d. Select I accept the terms of the License Agreement, and click Next.
e. Select Custom, and click Next.
f. Select Not Installed for every feature, and click Next.
g. When To begin the installation process appears, click Next.
h. Select Remind me later to register, and click Next.
i. When the Kodak Statistics Collection window appears, select Yes, and click Next.
j. When prompted, connect the printer to your computer.
k. Click Next when the Next button becomes active.
l. When Congratulations, your Kodak printer has been successfully setup appears, click Finish.
m. Click Continue, and then close all windows.
7. Before restarting the computer again, turn on the background applications.
b. Type msconfig in the Open field and click OK.
d. Under Startup Items:
- If only some items
were originally selected, select the check box in front of the items that you noted in Step 5-c.
- If all background items were originally selected, click Enable All, and click OK.
8. Restart the computer.
