Question about RCA P60920BL 60" Rear Projection Television
P60920BL beeps at me.
When the tv is plugged in it beeps about every second or so. Thats all that happens. It is a faint beep, cant tell were it is coming from.
  • 61 Answers
Sounds like you have a flyback transformer and horz output bad,the beep is because the output is shorted
Posted on Mar 04, 2008
Dryer has continuous faint beep
Have you had a power surge or power go out when the machine was running-----electronics go coo coo when this happens---it may be resolved by unplugging the dryer for a couple of days---then plug it back in & see if it does it again----another issue if the electronics get wet some how roof leak spilled water/fluid--hose replaced on washer which is usually next to the dryer---also check your owners manual to see if this is an issue do to a malfunction of electronics sending a code to check for an issue--that's all I dream up for now--sorry I couldn't do better
Apr 17, 2015 | Maytag Neptune MDE5500AY Electric Dryer
Brother 4000D innovis machine....when I turn it on, it will not start up..the lcd screen is faintly lit, and the machine just beeps
I had the same problem Machine off! I took off the rectangular cover on the right side (had to pry it carefully} GENTLY Pushed in connections of wires to board and then plugged in and it worked!! I happened a couple of times They must vibrate loose. All I has to take apart was that rectangle cover
Jan 18, 2013 | Brother InnovIs 4000D Computerized Sewing...
Want power up but is making a beeping noise
The beeping is usually caused by the Flyback transformer and HOT transistor. You can get the 239111 flyback and HOT repair kit from www.tvrepairworld.com
Nov 23, 2011 | RCA P60920BL 60" Rear Projection...
When i turn tv to av1 (where connected) then turn ps3 on the ps3 lights up but nothing happens on the tv I have to pull plug to ps3 and plug in again and turn ps3 on then it works, but this cant be good...
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. might be a video setting that is bad.
Jan 23, 2010 | Sony Playstation 3 (PS3) Console
Cant get a 1080i picture . tv supports this and i'm using a component cable . ( no socket for HDMI cable on tv )
try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
after plugging in the hd cables
Oct 21, 2009 | Sony Playstation 3 (PS3) Console
Has started to beep whenever items plugged into
If it's more than 3 years old, you probably need new batteries.
If the beep started after plugging anything additional into the UPS, you may be in an overload state, and the beep is telling you that it's choosing to beep and not function as intended rather than smoking itself. Try unplugging a piece or two from it and see if the beep goes away. If not, probably just you're batteries giving out due to old age, they'll only give you 3-5 years.
Oct 11, 2009 | Dynex Computers & Internet
I cant get my ps3 to reset. I was using it on a HDTV and I swicthed it back to a regular tv using AV cables and it will not show pic. just sound. Everybody says to reset it by pushing the button on the...
Try using a different Tv.
"First beep it turns on second beep nothing and third beep turns off.will not reset."
Your friends are wrong, pressing the button at the front of the console only turns the console on and off. If the problem doesnt change then contact the sony customer helpline.
Jul 29, 2009 | Sony Video Game Consoles & Games
The AC Adapter makes a beeping noise and doesn't charge the batt.
I would verify that the battery will take a charge. If the battery is bad, the charger will tell you that it is not charged. It will not tell you why, just that it is not charged. If not plugged into the computor,again, battery is not charged. Hence, the beep.
Good Luck and hope this helps.
Mar 15, 2009 | Toshiba Portege R100 Notebook
Tv won't come on
Beeping in that model usually refers to the flyback needing to be replaced or the Horizontal output transistor. Flyback is most likely the cause as the HOTransistor will usually blow a fuse causeing the set to be dead.
May 22, 2008 | RCA P60920BL 60" Rear Projection...
Televison & Video Logo
123 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
