Suddenly unable to access on screen menu from remote control
Other than the power on-off button, the remote no longer seems to control the television. The menu does not show up. Further, the television control panel itself will not show a menu. We tried resetting the tv but that did nothing.
  • 187 Answers
SOURCE: how to reset lg lcd tv
Whe you press the power button the TV led have to blink several times and the it have to change to blue, meaning Tv is on.
If you press the power button and the led start blinking and goes off, then you need to replace the mainboard because it is damaged.
Bye
Posted on May 27, 2009
SOURCE: JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
Hi , I have the same problem with my LT-42X688,so i called the service of my extended warranty provider . the TV technician just left and told me the motherboard is the problem. he said its the third one this week he has seen with the same symptoms. he ordered the motherboard and i've got to wait 5 to 7 work days before the part will be in . I will keep you posted when the guy will return.
Posted on Jul 21, 2009
SOURCE: Panasonic remote and volume/channel buttons do not work
try unplugging while the TV is still on and plug it back after 5 mins and check. it should work.
Mine did. I know this may be a crude method, but it worked.
Posted on Sep 08, 2009
SOURCE: My son bought an AOC LCD TV (model L24H898) last
According to the manufacturer, to reset the entire unit do the following:
1. Press and hold "Menu" and "Channel +" on the TV. 2. Using other hand, press the power button. 3. A small screen should appear in the top left part of the screen. 4. Using the remote, select "Memory Recall" and select. 5. Power off and re-boot the computer 6. Run channel auto-scan to regain the picture.
Posted on Feb 24, 2010
  • 8457 Answers
SOURCE: My LG tv has a mind o its own. First off, the tv
The tv PCB board manual contol buttons board is shorted,that why u have ramdoom screen menu pop up.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tv manual PCB control board for the replacement.
Posted on Jan 15, 2011
Can't access DVD setup menu
Without its original remote control, you can't access it all functions. Try to get one original one. Contact the authorized service center for Sony.
Jun 02, 2013 | Televison & Video
Message volume fixed
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals). Setting the Extra Speaker Terminals Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver. 1. Press the On Screen button on the remote control to enter the On Screen Menu. 2. The On Screen display should be displayed on the TV/Monitor. 3. Press the Arrow Down button on the remote until Setup comes up in the screen. 4. Press the Enter Button on the remote control. 5. The Setup Menu will come up across the TV/Monitor screen. 6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker. 7. Press the Arrow Down button on the remote to select Manual Setup. 8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu. 9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up. 10. Press the Enter Button on the remote control to enter Power Amp Assign menu. 11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted. 12. Press the Arrow Down button on the remote to select 7ch+1ZONE. 13. Press the Enter button on the remote to select 7ch+1ZONE. 14. Press the On Screen button to exit the on screen menu. To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver. Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Aug 19, 2012 | Yamaha RX-V773
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
Panasonic dmrez27 dvd recorder stuck on dvd2 setting
If you point the remote towards sensor, simultaneously hold down the number (1, 2, etc) you want AND the enter button for 5 or more seconds it should switch to the number pressed. Remember if you have a second one, make sure it's off or put towel over its remote sensor. Sue
Feb 20, 2010 | Panasonic DMREZ27 DVD Recorder
Cannot access channel 73 on TV2
If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
If you are still unable to access the menu you may need to purchase a universal to access the menu.
Jan 11, 2010 | DISH Network DVR-625 DTV Receiver /...
Lost remote control. can't change language
It is always more difficult to operate the menu features of a tv using the manual buttons on the tv. I recommend you unplug the ac cord of the tv from the wall for a day while you go out and buy a universal remote control. After plugging the tv back in and turning it on initially most television on screen prompts immediately direct you to the set up menu which includes setting the language.
Follow the instructions on the universal remote and program the remote to the tv using the power button on the remote to determine if you have reached the right code. It will then be possible to operate the menu features of the tv via the remote control and thus change the language back to english.
Apr 28, 2009 | Hitachi C21 F800S TV
Unable to access menu with remote control
you cannot enter into menu on most universal remote only on off switch,channel change and volume up and down thats the most you can get out of a universal remote.you will need the originald remote.
Mar 04, 2009 | Emerson Televison & Video
Viewsonic n3251w will no longer display Closed Captions
You can reset your viewsonic remote control by removing the batteries, and holding the power button down for 10 seconds. Just 10 minutes ago I repaired my remote, which was doing absolutely nothing, not even turning the set off and on, Called Viewsonic, they told me this, and it worked ! Yay !
Dec 11, 2008 | ViewSonic N3251w 32 in. LCD HDTV
Sylvania SST4272
I had the same problem with a Sylvania SRT2227S. I kept trying to fix it using the remote but after reading your posting I pressed the Volume (down) button, which cycled through the same menus you mentioned. Then I pressed the Power button on the TV and that fixed it.
The problem started for me when pressed PIP, CC, and Guide buttons on a Philips universal remote control. My TV does not support these functions and it seems to put it in this "service mode". Now I can fix it by pressing Volume (down) or Menu then the Power button on the TV (do not use the remote as it is useless when the TV is in this mode). I hope this works for you too.
Nov 25, 2007 | Sylvania 6419TC 19" TV
Convergence Problems
If you did not use heat sink compound then you probably have not hurt the new IC's yet but you should remove them and add the heat sink compound NOW. If the convergence IC's are bad then you will have access to the convergence menu but the adjustments will have no effect. The fact that you switched the IC's and got the same results shows that the IC's are good. If your red convergence is still way out when the new IC's are installed then the old IC probably burned out the low value resistor associated with the Red Vertical (RV) channel.
Jul 02, 2007 | JVC AV-48WP30 48" Rear Projection...
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
