Question about Refrigerators
Compressor is loud, we can hear it click for almost two minutes before it clicks on - any ideas
  • 32 Answers
COMPRESSOR GOING OUT,REPLACE.
ALSO MAY BE LOSE AT BASE..BUT IT SOUNDS LIKE YOU HAVE A BAD COMP.
MOST REFRIG'S HAVE 5 YEARS WARRANTY IF IT WAS PURCHASED BEFORE 1-1-2006,LACUZ12
Posted on Feb 07, 2010
Ge ghs25j refrigerator
Yikes! that sounds like the starter capacitor or starter relay.
Your meter must be able to show very low ohms to distinguish a short from a normal coil. Relay coils like that can be very low... like 10's of ohms.
If you bypassed the relay, then you are sending the compressor into over-current (because there is no starter capacitor) or the compressor is shorted.
There is somewhere a starter capacitor or "condenser" that basically gives the motor a boost to get it turning. These capacitors usually open up after a few years. You can get a new one at a refrigeration or AC parts store. It will be marked with a number like 22 uF. It is round or rounded and has a metal covering. Be sure to get the right kind because all this stuff you are working with is dangerous to make a mistake with.
When that capacitor is bad, you will hear the compressor hum loudly and then click. If you are just plain mean you will wait a few minutes and it will do it again... but what you are doing is going to ruin you compressor when there may still be lots of life in it.
On the other hand, if this has gone on too long, the compressor may be ruined anyway. But a new capacitor is much cheaper than a new compressor by a long shot!
Dec 17, 2013 | Refrigerators
Loud buzzing
What is the model number of your unit? If you look at the compressor (back of unit big black bulb looking thing) do you see a picture of an indian on it?
If your compressor looks like this (techumseh compressor) then you almost certainly need a new compressor.
Mar 13, 2013 | Refrigerators
My refrigerator/freezer is making a sharp buzzing noise followed by a loud click. Its been doing this every few minutes for a while, and now today, everything in my freezer appears to be defrosting.
Is that buzzing/click you hear from the compressor area?
If it is from their, the relay on the compressor has gone out, or the compressor is locked up.To determine which of those it is the amprage draw using a amp meter clamped to the wire on the overload thermostat where the relay is, must be measured, if 17 or higher amps the compressor has locked up, if its around 5 or so the relay has gone out and replacing both relay and overload will fix it.If the compressor has locked that is a major repair and may cost up to $1200
Gene
Aug 07, 2011 | Amana Refrigerators
The refriderator had been making clicking noises for quite a while and i s wondering what is was, every ten minutes or so it sounds like a motor in the back clicks on and vibrates very loud for about 6...
That sound you hear is your compressor trying to start. You will notice that the freezer temperature will begin to get warmer, while the fresh food side "seems" ok, but it wont for long. Now the problem might be the compressor itself, or the start device which starts the compressor. You will have to either buy a start kit and hope that is it, or bite the bullet and call A Fast Local Refrigerator Repair service and have them test your compressor.
Dec 10, 2010 | Refrigerators
Compressor clicking on very loud every couple
it sounds to me like your loosing your compressor, but not really the clicks are comming from the realy and overload, they are attached to the compressor, and turn it on and off
replace those two and you should be ok
www.appliancepartspros.com
look in the compressor section
you should be ok
Oct 24, 2009 | Refrigerators
My 53564 side by side refrigerator seems to be
good catch........
pull the unit out and listen to the back and bottom
that click is more than likely comming from the compressor electriacal connection
it could be just loud, but if you have not herd it before its probaly going bad
Oct 14, 2009 | Kenmore 53562 / 53564 / 53569 Side by Side...
It will run for a very short time then turn off and if you turn the defrost timer till it clicks it turns back on
The defrost timer is sticking if it only clicks a couple times before it starts. Try turning off the frig. and play with the timer, you will hear a differance in the clicking. When it has a loud click it goes into defrost and then you will hear a second loud click and it will come out of defrost and the compressor will start.If you are only hearing one loud click when you have did this before you can just replace the timer.
Aug 05, 2009 | Maytag Refrigerators
01% humidity
When you push the power button, the blower fan comes on. In a few minutes you should hear a second "click"--that is your compressor starting. Do you hear that second click?
The compressor is located in the rear bottom on the right side looking at the machine. After you press the start button and the blower fan comes on, bend over near the back of the unit and listen for the "click".
Sep 06, 2008 | Kenmore 54501 Dehumidifier
Maytag msd2454gr
The click is not normal. The compressor is not starting and is tripping the overload. There is a chance the start relay on the compressor is shorted, but most likely the compressor will have to be replaced.
Unplug it for several hours until the compressor cools down and then try it again, if it starts up ok when it is cool the compressor is the problem for sure.
If it is less than 5 yrs old the compressor is still covered by warranty and will be replaced free of charge.
Dec 07, 2007 | Maytag MSD2456G Side by Side Refrigerator
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
