Question about Arris Touchstone 450a (CM450) Modem
How to get password to get access advanced login? pls
How do I reset password on 7voyager
To change the access password on your BT Voyager router:
  1. Open the Router Manager by going to http://voyager.home
  2. Click 'Advanced'.
  3. Click 'Continue to advanced'. When prompted to login, enter your username and password. What is the username and password for my BT Voyager router?
  4. Click 'System'.
  5. Click 'Admin Access/Password'.
  6. Enter your new password twice. Please keep a note of this new password somewhere safe. If you forget this password, you will need to reset your Hub to factory defaults to restore access to the configuration of your router.
  7. Click 'Apply'.
  8. If you now browse other pages of the Hub/Router manager, you will be prompted to enter your new password immediately.
http://www.voyager.home/
Oct 30, 2015 | Computers & Internet
Tip
How Do I Reset Laptop Password to Break into Laptop Login
"Help!!! How to recover my forgotten laptop password?" Situation is so urgent! Then search solutions online: laptop password reset, how to remove laptop login password? Carelessly, we forgot laptop password, then we now concentrate on how to unlock laptop password methods!
How do I recover laptop password on Windows Vista?
- Remove laptop Windows Vista password from Safe Mode
A. When laptop starts, please press "F8" key.
B. At the "Advanced Boot Options" windows, choose "Safe Mode with Command Prompt" and then login Safe Mode with available administrator account
C. Input "net user", press "Enter" key and then all the accounts will be listed.
D. Input "net user Lisa 012" (Lisa is the forgotten account name and the 012 is Lisa's related account password.), press "Enter" key to finish unlock laptop Vista password.
E. Input "shutdown -r" and press "Enter" to restart laptop, then we can login "Lisa" account again.
How to find laptop password for Windows 7
- Bypass laptop Windows 7 password with built-in administrator account
A. Power on laptop PC and press the key: F8.
B. At the windows of Advanced Boot Options, opt for "Safe Mode with Command Prompt" and confirm with key: Enter. Then PC starts Windows.
C. Select "Administrator" account shown on the account screen, and then access the windows - Administrator: cmd.exe.
D. Input command: net user Merry 123 and confirm with Enter. (Merry is the account required to reset password; 123 is the new password for account Merry).
Please note that the administrator account will be useful only we had set it enable. (The default status is disable.)
How can I Break password on laptop Windows XP
- Get into Windows XP laptop by default Administrator account
A. Press "F8" when laptop computer starts.
B. At the "Advanced Boot Options" windows, choose "Safe Mode" with arrow key and confirm with Enter key, then PC accesses Safe Mode.
C. Click "Administrator" on the Windows login screen.
Please note that if we have set the Administrator password before, we need to input the changed password instead of leaving "Password" field blank.
D. Start - Control Panel - User Accounts - Select the locked account and change password for it.
E. Restart laptop and login with the account newly reset password.
The above ways are referred to system with available account (default/built-in account or other accessible accounts with administrative privileges). While, if there is not other accounts to help us, how to reset laptop password?
Unlock laptop password with Installation disk: if there is not important data for us, we can use it for password unlock.
Laptop password bypass with password reset disk: we can use the disk only if we create the disk before lost password for the related account.
DIY a laptop password reset disk now: It is the last but not the least solution on laptop password recovery!
We need a CD/DVD/USB disk and an accessible computer to burn a .iso image file from Windows password recovery software! Take one of the most top-rated tools - Ainorsoft Windows Password Recovery Corporation as example:
A. Download Ainorsoft Windows Password Recovery Corporation and burn its .iso image file into a CD/DVD/USB Flash Drive from an accessible laptop;
B. Set PC with password locked to boot from burned CD/DVD/USB Flash Drive;
C. Reset forgotten laptop Windows password to a new one with the burned CD/DVD/USB Flash Drive.
Now, once we forgot laptop password, the last method will always make sure we reset password for laptop easily without IT expert knowledge.
Source: http://windowspasswordrecovery.net/article/laptop-password-reset.html
on Jul 15, 2011 | Computers & Internet
I forgot my 2go password and i need it urgently,pls.
am using a cellphone and i fogort my password and evrything. I want to register another account. Pls help
Sep 21, 2011 | Computers & Internet
Previous owners password wont allow me access the acer 5580 laptop, how do i access thanks david
Hi dcalchin...
1. Keep pressing "F8" as the laptop computer starts.
2. When the window "Advanced Boot Options" opens, choose "Safe Mode" with arrow key and confim by pressing the Enter key, then PC enters the Safe Mode.
3. Once you are in the Safe mode Click "Administrator" on the Windows login screen.
Take note that you have set the Administrator password before, you need to input the changed password instead of leaving "Password" field blank.
4. Then click Start > Control Panel > User Accounts > Select the account that is locked and change the password.
5. Restart laptop and login into the account you just created using your new password.
Please take time to rate me
Aug 28, 2011 | Acer Aspire 5580 Notebook
Cant access my facebook account on iphone 4 .( login failed, unable to connect to facebook ). i change my password 2 times but still login failed..but when my daughter used she can login successfully...
If you can successfully log into your account on your computer. Then you must be typing your password in correctly on the phone. Sometimes auto correct will effect password spots. Or you might need to just type really slow and make sure your not hitting one letter and it's registering as another letter. Which is the most common sign in problems I've seen on touch based phones.
Aug 19, 2011 | Apple iPhone 3G
I have a Netgear Wireless router n- wnr2000, how can i disable the macfiltering
You have to login to the routers homepage. To do this you need to go to you computer and open your internet browser. At the top in the address bar type 192.168.1.1 and hit enter. Then a login screen should appear. The username is admin and the password is either blank as in no password at all or it is admin or password. Once you login to the homepage go to advanced > wireless settings > click setup access list. Under access list you should see an option Turn Access Control On. Uncheck that option and save.
Feb 04, 2011 | 2wire (1000-100052-000) 802.11g/b Wireless...
I have problem for login my account.Yesteday i was change my password to my ID.Yesterday it will be working.But today i can't enter to login. Pls give anyone solution to rectify this pbm
Click "cant access my account or forgot password" near the sign in button and answer the security questions and reset with strong password.
Jun 30, 2010 | Yahoo Mail
Yahoo Mail Login problem
There was a problem accessing your account. Please try again in a moment.
Error #1
is this you getting ??
Apr 29, 2010 | Yahoo Mail
Asking about yahoomail and gmail password
Yes, so long as you added a secondary email address upon sign up, your password can be access/changed/reset from the mail login screen.
Jan 08, 2008 | Adobe Computers & Internet
Arris Touchstone 450a (CM450) Modem Logo
998 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
