Question about Dell Latitude D505 Notebook
Ethernet device missing
Lots of devices have yellow ? marks and no drivers can be found
  • 129 Answers
You can find all the drivers in the following link
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=LAT_PNT_PM_D505&os=WW1&osl=en&catid=&impid=
Posted on Feb 09, 2010
BCM5701 Ethernet
You need drivers for your Broadcom 5701 network interface card, and drivers for the others too. Go to HP website and look up that model. All the drivers should be there.
Jun 12, 2013 | Compaq Evo D510 PC Desktop
Ethernet controller missing hp compaq dx2200
That's probably why you've 2 network cards on your computer. Check is it's so, then connect your cable to the other connector and your network connection will work.
You can see in the control panel under network connection if you have to connection.
The card with the yellow question mark need drivers. For that check that on the vendor website.
Aug 06, 2012 | HP Compaq dx2200 PC Desktop
I formatted the PC. 8307 41G IBM Netvista. Now the LAN card does not respond.
go to device manager by right clicking on "my computer" in start menu and clicking manage,the ethernet driver should be missing,download the appropriate drivers for all devices with a yellow question or exclamation mark and install,peace
Aug 24, 2011 | IBM NetVista PC Desktop
I have a ibm t42p i installed a new windows xp but i have many drivers like pci modem .. vega .. wirless .. ethernet don't installed i went to ibm website and installed this drivers but still the...
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
also
you might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
click start control panel administrive tools computer management device manager scroll down network adapters + expand Ethernet driver you might see a yellow question mark? This means you need to update the driver right click you will have options to update driver disable uninstall or select properties general you will have the options to troubleshoot or to update driver rollback or uninstall
a yellow? question mark means you need to install/update driver right click to install driver
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
May 07, 2011 | IBM Computers & Internet
I reinstalled the operatiing system & it won't to the internet. Doesn't show an network conn ection in the device manager just a yellow question mark by the ethernet controller. I've installed all the...
Here are the stpes that you can try..Go to Device Manger select ethernet controller, then right click, select Properties and then select Uninstall. After this re-install your Ethernet driver. The yellow question mark means that the computer is not detecting the device.
Sep 10, 2010 | Dell Dimension 2350 PC Desktop
Ethernet controller misssing
I assume your referring to the driver. You can get that HERE.
Thanks for asking FixYa.
Mark
Mar 02, 2010 | ASUS P5V800-MX Motherboard
Ethernet controller driver can,t be found
Hi there.
right click in the adapter with the yellow mark and select properties, look in the device status box, if it says code 10 the device cannot start then you installed the wrong drivers for the adapter.
Get the correct network controller drivers from here >>>>>>>>
http://support.acer-euro.com/drivers/notebook/tm_2480.html
If you still suffer the same symptoms after the correct drivers are installed then the device maybe faulty.
Good luck
May 30, 2009 | Acer TravelMate 2480-2153 Notebook
I had to reformat my laptop and now I cannot get ethernet to work
you need the drivers for those devices marked with yellow --"yellow"ethernet
controller will not allow to access the web to download drivers to solve your problem--options are:- use the "original" driver disk that came with the laptop or download to another pc/laptop and transfer drivers using usb key.
Apr 27, 2009 | Dell Inspiron E1505 Notebook
Ethernet Controller
Needs a driver ...the easiest thing to is unistall the item with the ? mark and then reboot when it asks for a new driver during the found new hardware part see if you can browes to one
LB
Sep 19, 2008 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
Can not get online because of missing drivers for ethernet
do windows update custum scan least get driver for erther net on a cd from anther ok the custum scan then hardware add all
Feb 05, 2008 | Microsoft Windows XP Home Edition
Dell Latitude D505 Notebook Logo
35 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
