Question about HP Photosmart C4280 Aio Printer
I keep on getting an eror everytime i clik print and it never prints
  • 164 Answers
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 07, 2010
I used the print on both sides of paper. Now when I try to uncheck the print both sides it shows it unchecked but the next time I print something the arrow prints and tells me to turn paper over. How do...
folow these steps : start / control panel / printers and faxes / right click on your printer / proprieties / now here some ware u got to uncek the duplex printing , after that clik aply an ok.
Feb 02, 2011 | Lexmark Office Equipment & Supplies
Epson R1800: printing 13x19" velvet paper. hand feeding into rear of printer. keeps saying eror, or paper jam or ... then finally just spits the paper through and out.
why print velvet paper? the problem is the velvet would be too thick and it would jam the print heads because when they run over the paper it would pull the velvet and it would get jammed i don`t think you should print velvet
May 16, 2010 | Epson Stylus Photo R1800 InkJet Printer
Unexpected size in tray 2
whenever i took printout of a multipage file of Powerpoint. Everytime i have to preses the ok button to proceed with the print. because every page an eror comes displaying on screen of printer "UNEXPECTED SIZE IN TRAY 2" when i press the OK button it start printing the page. everytime i have to press the ok button to take print out. For example if i give a print command to a file that is having 15 pages. i have to press 14 times the ok button to complete the printing of 15 pages. pls help me in this
May 14, 2009 | HP LaserJet 2840 Printer
Small print from printer pages
you can adjust it during printing, clik file then print, and choose properties then adjust the printer settings
Jan 11, 2009 | Office Equipment & Supplies
I am trying to print a paper. it says the printer is paused.how do i un pause it
go to start menu control panel printer and faxes then select your printer
right clik it then u seee "resume printing: on 4 or 5 clik on it
thats all
Oct 03, 2008 | Lexmark Office Equipment & Supplies
I purchased a new lexmark 4 in 1 printer. I am running Wiondows Vista. My old printer (Lexmark) would not load properly so i had to purchase a new one. This one loaded the software and the drivers ok. The...
no go to control panel u see printer and faxes
right clik your printer and chose properties
then go to advanced
and enable button spool print doc...
also clik on start printing immedaitely.
check the button print spoled documents first
also enable advanced featurs.
Sep 29, 2008 | Computers & Internet
HP Photosmart C4280 Aio Printer Logo
89 people viewed this question
Seeker5211
Seeker5211
