Question about 2-Way Remote Starter
Hi i just bought a 2004 vue the car came with just one key and nothing els a use to have a 2003 vue witch i still have the remote from can i program that remote to work on my 4004 vue?
  • 344 Answers
If you call your local saturn dealer and give them the FCC # on the back of the remote they will be able to tell you if you can use that remote for your new car
Posted on Mar 29, 2010
2003 staurn vue v6 wont start all no lights neither
make sure you put the right battery in your car.
Dec 17, 2013 | 2003 Saturn VUE
Tengu una camioneta saturn vue 2003, tengo problemas me en peso a tenblar y sevajan las revoluciones , cuando ago un alto sejalonea
hola trata de hacerle una lavada alos inyectores y cambio de aceite y bujias si sigue la falla escanealo para ver que no sea un sensor
Jan 07, 2011 | Saturn Vue Cars & Trucks
When I try to start my 2003 saturn vue the key is hard to turn unless I push brake very hard and turn the steering wheel. What's the problem?
My 2004 Saturn Vue had the same problem. I thought the ignition had to be changed and I drove the Vue a long time with the key hard to turn and pushing it in before turning it. I mentioned it to a Saturn Dealer mechanic while having warranty work done. He told me a new key had to be made using the key code (located on the inside panel on the driver door). They made it and it totally fixed the problem. I think any GM dealer can do that for you.
Jul 03, 2010 | 2004 Saturn VUE
Keyless remote stopped working, I replaced battery
The 1997 to 2003 Dodge Caravan and Grand Caravan use a standard key and remote setup with a separate remote fob. However, the 2004 to 2009 Dodge Caravan and Grand Caravan use a combination key and remote on one device. To program a new keyless entry remote for the 1997 to 2003 Dodge Caravan, you must have at least one functional remote, which is required to enter synchronization mode. To program the combination key for the 2004 to 2009 Dodge Caravan, you must have two functional combination keys. If you do not, you'll need to see an authorized Dodge dealer for keyless entry programming assistance.
2004 to 2009 Caravan Programming Instructions
  1. Insert one of your working combination keys into the ignition. Turn it to "On"; leave it in this position for about 10 seconds but no longer than 15 seconds. Turn it to "Off" and remove it.
  2. Insert your second working combination key into the ignition within 15 seconds of removing the previous key. Turn it to "On". After 10 seconds, you'll hear a chime and the "Theft" light will begin to flash, entering synchronization mode. Turn the key to "Off" and remove it.
  3. Insert the combination key you want to program. Turn it to "On." After 10 seconds, you'll hear a chime; then the "Theft" light will turn off. When the light turns off, the combination key--including the key and the remote--is programmed.
  4. Repeat Step Three for each combination key you want to program. A total of eight can be programmed.
Hope this help (remember comment and rated).
May 08, 2010 | 2008 Dodge Grand Caravan
Vue 2003 saturn
try locking and unlocking the car with the remote, maybe a anti-theft issue?? what do you mean" tries to start?" either the engine turns over or it doesnt. if it turns over, but wont run, thats another story.
Sep 21, 2009 | 2005 Saturn VUE
I need to program a key fob for a 2004 Cadillac CTS. I just purchased the car used. it came with ONE key and nothing els. I have recently purchased a keyless entree remote suitable for the car and was...
Remote Key FOB Information
Transmitter Programming
 1. Close all the vehicle doors.
   2. Insert the ignition key into the ignition lock cylinder.
   3. Press and hold the door unlock switch.
   4. While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
   5. Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
   6. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
   7. Repeat the previous step to program up to 4 transmitters.
   8. Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter programming mode.
   9. Operate the transmitter functions in order to verify correct system operatio
Sep 17, 2009 | 2004 Cadillac CTS
Don't know how to program remote
Its possible the remote battery is dead try replacing it.
Jul 26, 2009 | 2-Way Remote Starter
Car keys and keyless remote FOB programing/matching.
A Locksmith can cut and program keys. You likely did not save anything buying the blank online, locksmiths already have them on hand, and the key itself is not the major part of the fee.
I can not find a model EL, must be strictly Canadian
If this has been helpful, please post a review for City Lock Boulder Colorado USA listing on Google Maps
You may find a locksmith that has been background checked on a link from our website. I am not putting the link here, as it likely is a TOS thing
May 26, 2009 | 2001 Acura 3.2TL
Program factory remote keyless entry for 2003 Hyundai XG350
This bulletin supersedes TSB# 02-90-001.
DESCRIPTION: The security system keyless adapter cable (SPX/Kent-Moore P/N 09900-21300) is a special service tool (SST) that is used for programming new keyless entry remote transmitters to the factory security systems. The keyless adapter is used in conjunction with the Hi-Scan Pro (with Hi-Scan SOL Pro Software Version 09-29-03
or newer) and Data Link Connector (DLC) Cable. SERVICE INFORMATION: The keyless adapter cable can be used on the following vehicles:
  • 2001 - 2004 MY Elantra
  • 2001 - 2004 MY Santa Fe
  • 2002 - 2004 MY Sonata
  • 2001 - 2004 MY XG300/350 0390020a.gif
NOTE
  • The 2003 - 2004 MY Tiburon does not need the Keyless Adapter Cable to add keyless entry remotes to the factory security system. Instead, the Hi-Scan Pro connects to the vehicle using only the DLC cable. See page BE-60 in the 2004 MY Tiburon Shop Manual for the latest instructions.
  • The most current Keyless Adapter Cable Instructions are available in the following shop manuals:
SHOP MANUAL
PAGES
2004 MY Elantra
BE-73 - BE-74
2004 MY Santa Fe
BE-43 - BE-44
2004 MY Sonata
BE-40 - BE-41
2004 MY XG350
BE-46 - BE-47
KEYLESS ADAPTER CABLE INSTRUCTIONS:
  1. Connect the keyless adapter cable to the Hi-Scan Pro DLC cable. 0390020b.gif
  2. Plug the keyless adapter into the vehicle's 10-pin multi-purpose connector located behind the driver's side lower instrument panel (next to the DLC). NOTE Sample vehicle shown is the Santa Fe.
  3. Turn the Hi-Scan Pro ON
    and press ENTER
    . NOTE "Release date 29. Sep. 2003" OR LATER
    must appear on this screen. To update your SOL card with the latest software go to www.hmaservice.com and refer to TSB 00-00-001.
  4. Select option "HYUNDAI VEHICLE DIAGNOSIS"
    and press ENTER
  5. Select vehicle model and press ENTER
  6. Select option "TRANSMITTER CODE SAVING"
    and press ENTER
  7. Ensure that the key has been removed from the ignition cylinder before proceeding. 0390020h.gif
  8. Follow the steps noted on the Hi-Scan Pro screen to program the remote(s). NOTE The factory security system can only be programmed to accept two remote transmitters and MUST be programmed for both remote transmitters at the same time.
  9. Press ESC
    on the Hi-Scan Pro and verify that the remote(s) are functioning properly.
  10. Turn the Hi-Scan Pro OFF
    and disconnect the adapter cable from the multi-purpose connector.
May 22, 2009 | Hyundai Motor 2003 XG350
Windshield wipers in front wont work but rear wipers work
Hi! U need to check the switch and the wiring circuit that controls the motor.
Jan 15, 2009 | 2003 Saturn VUE
2-Way Remote Starter Logo
120 people viewed this question
Top Crime Stopper Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
John
John
Steve
Steve
Are you a Crime Stopper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
