Question about Sony Playstation 3 (PS3) Console
TV Malfunction after use of PS3
My brother brought home a ps3 today and asked my assistance in connecting it. He bought it off a friend without the plug to connect to the TV. I saw that the slot looked the same as my ps2 slot, so I took it from my ps2 and inserted it into the ps3 and to my surprise it fitted perfectly. After trying a different array of inputs i saw that i was getting no signal, just a black screen so i decided to remove it for good just as i did, i heard the TV turn off, since then my TV won't turn back on. The PS3 wasn't on for more than a good 15minutes so i doubt the TV got fried off the 15minutes of start menu, or maybe it did. Any advice, Diagnosis?
Any will be greatly appreciated the TV in question is the TV used in the living room, so as I speak there is a bounty out for my head.
    Scholar:
  • 121 Answers
Yikes, that sounds like you are in trouble---probably not the best thing to do.. well the only thing that i can suggest is to disconnect all the cables from the tv but unplug it first and even remove cable then rescrew it on after a few seconds.. wait for about a min, then just connect the tv back to the cable box only as you would if you didn't have anything else to connect.. see if that helps.. if not i would suggest also going to the manufacturere site and see if you could get some online assistance.. if your tv turns back on then i would advise buying the cord needed for the ps3---ebay is the best bet.. good luck.. let me know if this helps...d
Posted on Feb 22, 2008
Connecting my ps3 to a jmb tv?
Do you mean the TV is on AV or the PS3 is on AV? Either way, try this, it will not hurt your PS3 at all!
Turn off the ps3, then hold down the power button until you hear the second beep, then can take up to a minute. Once you hear the second beep allow it to boot normally.
My friend swears you need to do this with the ps3 powered on. But I don't think so, but just in case the original solution doesn't work, try this.
If this doesn't work, it's probably a problem with the cords, or the tv.
Apr 28, 2013 | Televison & Video
I have just recently bought a second hand PS£
Ohhhhh u got there a problem i had months ago. PS3 only gives u one output signal at a time, that means either u use it hdmi or u use it the normal rca way.Bad thing is that the ppl at sony didnt think of this kind of situation.
What u need to do is go to ur friend's house and use his hd tv to config ur ps3 to the correct output signal(rca), both on video and audio. If u bought the ps3 from ur friend, he should know how to do it, since he had to config it to hd in the first place. Be sure to probe it with the config u are going to use at home :)
Nov 01, 2009 | Sony Playstation 3 (PS3) Console
PS3 image keeps scrolling and is in black and white
I am an Australian ( 240v) and I took my PS3 to the Caribbean (110v - same as the US) and it worked fine as far as power concerned. However as I had the PS3 set to work on my TV back home (PAL) when I took it over there & plugged it in (NTSC) I had a similar problem. I fixed it like this: when the PS3 is turned off hold down the power button for 15-30 seconds it will reset the PS3's settings to defult and it should work on the system that it's connected to. Hope it helps
Jul 02, 2009 | Sony PlayStation® 3 (80GB) Console
Audio problems connecting ps3 to bose lifestyle 48 system
audio has to connected seperatly.vs 2 is for video connection only..Bose is a ripoff.... u pay all that money and you need a seperate audio connection plus all those wires..it isn't worth it and regret i bought it.
Jun 14, 2009 | Bose Lifestyle 48 Series III System
Ps3 blew up a 2nd tv
Make sure that you are not plugging either the game system or the TV into a surge supressor device or any other equipment that may allow you to have reversed the polarity of the AC current coming into the equipment from the wall outlet. Remember, most modern electronics equipment has a "hot" ground power supply. That means there is the possibility that you are sending current thru the ground return path of the items you connect in this way.
michtech
Feb 17, 2009 | Sony Playstation 3 (PS3) Console
PS3 Works on HD TV without Sound, no sound or display on a reg TV
when u connect ps3 to your tv turn on main switch now red led will come on press and hold touch button ps3 will come on keep your finger on the button and ps3 will turn off again factory settings are now reloaded this will work because i often change from standard v to hd tv
Jan 18, 2009 | Sony Playstation 3 (PS3) Console
Played ps3 on my brothers hd tv
do u have hd?
if not u need to change ur settings to video instead of hd! but when i had to i needed it hooked up to hd first then went through settings to change it or it will be blank screen!
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
No sound or display
go back to your friend or another with a hdmi tv then connect the ps3... when connected go into the menu for display and switch output from hdmi to scart it should then work on your tv
Oct 24, 2008 | Sony Playstation 3 (PS3) Console
Hi I recently played my ps3 on my friends tv using an hdmi lead and all was fine. Now i have returned home and tried to play my ps3 without the hdmi lead and it wont work can you help please.
go back to your friends with your ps3 and change the tv settings on the ps3 back to scart output but also take your scart lead and have it plugged in at the same time. once you have selected scart output unplug the hdmi cable to make sure the settings are right. hope this helps you.
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
PS3 - HDMI to SD change issues
While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.Good Luck!
Sony Playstation 3 (PS3) Console Logo
29 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
