Question about Toastmaster TWB2 Cool Touch Belgian Waffle Maker
Need to know how to clean the waffle cooking plates. Do they come out?
    Problem Solver:
  • 9 Answers
They do not come out you - before cooking you need to spray with non stick cooking spray - after cooking you clean with soap and spong on counter DO not submerse into the water - keep the plug away from water - wipe clean with damp cloth
Posted on Feb 08, 2010
I have a pre owned wm-4. No owner's manual. Can the plates be removed for cleaning?
These instructions are taken from a WM14 waffle maker, maybe they will work for you. It doesn't say anything about removing the plates:
"Wipe Cooking Plates with absorbent paper
towel or a soft cloth. Although the Cooking Plates are coated
with a non-stick coating, some batter or ingredients may still adhere
to the Waffle Maker. To remove, simply pour a little cooking oil onto
the baked-on food. Allow to stand for 5 to 10 minutes. This should
soften the food and make it easy to remove with absorbent paper
towel or a soft cloth. If the preceding measure fails to remove the
food residue, we suggest wiping the Cooking Plates with a slightly
dampened cloth and a little non-abrasive detergent."
Mar 28, 2011 | Salton WM4 Waffle Maker
Vitantonio waffle maker
have you open your waffle? if you already open it, check if theres a cut to the wires of you your waffle or check if there is a lost tread on something. thanks!
May 05, 2008 | The Home Marketplace 70047 Waffle Maker
Cleaning your waffle iron WPLT4
Let me start by telling you WHAT NOT TO DO.
  1. Never clean a waffle maker while it's still hot. Let it cool completely.
  2. Never dunk your entire waffle maker in water.
  3. Never use scouring pads, steel wool or abrasive cleansers.
  4. Never use a knife or pointed object to clean your waffle maker(I've actually seen that advised on less reputable sites).
When it comes to cleaning a waffle maker, your first source of information should always be the owner's manual. There are many different kinds of waffle makers, so your buddy Mr Breakfast will gladly defer his expertise to the company that makes your waffle maker.
What I can speak about is my own favorite waffle iron. It's a modern electric waffle iron with non-stick and non-removable baking plates. That's the same kind you have? Oh good. It looks like you came to the right guy.
Cleaning the baking plates:
  1. Remove any small puddles of oil with a dry paper towel.
  2. Brush away any crumbs with a soft-bristled kitchen brush or old toothbrush.
  3. Remove any batter stuck to the iron with a rubber spatula.
  4. To remove really-stuck-on batter, douse the baked-on batter with cooking oil. Wait 5 minutes for the batter to soften. Dab the batter off with a paper towel or cloth.
  5. To prevent staining and long-term oil build up, wipe down the baking plates with a damp cloth or paper towel.
  6. Make sure the waffle iron is completely dry before storing.
To clean the exterior, wipe down the housing and handle with a damp cloth.
Keeping it clean:
There are a couple things to remember to make sure our kind of waffle maker stays clean.
  1. Unless stated otherwise in the manufacturer's instructions, you should never coat the baking plates of a non-stick waffle iron with cooking spray. Over time that will give you a gummy build up that will turn your waffle maker to junk. Today, when a waffle maker makes the claim that it's non-stick, they really mean it. The only oil you need is the oil in the recipe. If your waffles are sticking, it's your batter that needs more oil, not your waffle maker.
  2. Unless stated otherwise in the manufacturer's instructions, don't use soap to clean your baking plates. Soap can be the enemy of a non-stick surface. Oil - on the other hand - can be a great friend. It creates a thin layer that helps maintain the non-stick surface. Soap will completely obliterate that layer of friendly oil. Harsh soaps can deteriorate the manufacturer's non-stick surface over time.
Mar 05, 2011 | Salton WM4 Waffle Maker
ProLine waffle maker sticking. Followed all direction from factory. No Pam used.
The plates on the waffle maker need to have some sort of cooking oil or butter to lubricate and prevent your waffle mix from sticking.
Spray some PAM on the plates once the correct temperature has been reached, or alternatively brush on a little melted butter or vegetable oil. Pour in your waffle mix and when cooked the waffle should lift straight off.
Jan 16, 2011 | KitchenAid Pro Line¿ Waffle Baker
How do i clean a phillips kb5500 waffle maker. can you submerse it at the plates don't seem to detach
no,,,,dont put it into any water,,,,heat up the waffle maker then wet a dish cloth and put it in the waffle maker for a fuw seconds,,the steem will clean the plates and you can then wip the plates off with a "hand full" of paper kitchen towel so you dont burn your hands,,, to keep it clean just after cooking put a drop of cooking oil in the waffle maker wip it round with kitchen paper
Jun 27, 2010 | Kitchen Appliances - Others
How do you remove the plates for cleaning?
I looked for you model by using Salton WM4 and found nothing. Is there a better model number?
Closest match was Russell Hobbs
RHBW4 and RHBW4CAN
This unit is also made by Salton
I checked several Salton user manuals and none of them had removable plates. They all stated this in the use and care guide:
Cleaning
To keep your Waffle Maker operating properly, clean regularly.
1. Unplug the Waffle Maker and allow it to cool completely before cleaning.
2. Never immerse the waffle maker in water or any other liquid.
3. Wipe the exterior with a soft, damp cloth. Dry thoroughly.
4. To remove any remaining batter on the Cooking Plates, wipe with a soft, damp cloth or absorbent paper towel. Dry thoroughly.
5. Do not use steel wool, scouring pads, or abrasive cleaners, as they will damage the finish.
Jan 26, 2010 | Salton WM4 Waffle Maker
Waffles are separating when we open the plates
In my experience this is due to sticking on the plates. I spray a little cooking spray on them with each batch I make.
Maybe they arn't quite done.
Jul 12, 2009 | Waring WW150 Waffle Maker
I need instructions for a waffle maker mine are lost
When making a waffle have your batter made plug in your maker and get it started heating if there is a light it will go off whenit is hot enough if not wait aprox 2-3 minutes at the most 5 then spay or brush the inside of the plates with a nonstick cooking spray or brush with butter then pour your batter in the center of the bottom plate and close the lid it should start steaming right away watch the steam it is a never fail indicater of how done your waffle is the less steam the more done your waffle is, there is a lot of trial and error with waffle makers, you should spay or brush between each waffle or they will stick. Let me know how it all cooks out. goofballlovers
Mar 24, 2009 | Kitchen Appliances - Others
I need a user manuel i tried to make waffles the other day and they stuck to machine. what a mess
even though it may have teflon on the plates it will still need nonstick cooking spray or butter brushed on both plates between before each waffle made then watch the steam once the batter is in and the lid down the more steam the less done wait for very little steam to be coming out and open should be pretty good. let me know if this helped thanks goofballlovers
Mar 10, 2009 | Toastmaster 200 Waffle Maker
CLEANING THE TOASTMASTER WAFFLE MAKER
If the plate are not removable, clean with soapy rag. Otherwise remove and clean with warm soapy water. After drying, re-oil with light coat of cooking or olive oil.
Mar 08, 2009 | Toastmaster 234 Waffle Maker
Toastmaster TWB2 Cool Touch Belgian Waffle Maker Logo
300 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Oscar Netto
Oscar Netto
Mohamed Ismail
Mohamed Ismail
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
