Question about Rinnai Heating & Cooling
We have 3 bathrooms, two are close to the rinnai, one is further away. The one that is further away in the early morning fails to get hot. We run the water for 15 minutes and then still sometimes no hot water. Any solutions
  • 1,420 Answers
Chances are that you have a bad faucet that is drawing water from a cold water tap. You will need to have a helper turn on the hot water in that bathroom while you feel the pipes at the water heater and see if they are heating up. If they feel like there is no flow, the water is coming from somewhere and you will need to turn the shut-offs of at various sinks to target the problem faucet. If you find which cold water line is acting up, install a back-flow check valve so the water goes only one way, toward the faucet.
Posted on Feb 07, 2010
No hot water from kitchen tap
The hot side of the faucet is most likely plugged with something that came up thru the water system. The average thankless waterheater requires at least 1/2 to 3/4 gpm flow rate for the unit to sense flow and turn on. If there is not enough flow it will not fire and heat the water. Not sure about this particular unit but a few require at least one full gallon per minute flow. So chances are that if you fix the faucet, you fix the hot water issue at the same time
Jan 09, 2014 | Rinnai Water Heaters
Rinnai R75LS error 12. I recently went to fill my bathtub and got nothing but cold water. After checking the hot water heater it was flashing 12. After looking at the book saw it meant flame failure. My...
You may have instant hots for the sinks, a small heater for each location which won't be on the tub. If there is a flame fail the hot water heater is not working. Check the flame sensor and ignitor.
Jan 07, 2014 | Water Heaters
Have a Rannai R75LS and getting hot water everywhere except my sink in the bathroom. System doesn't come on with only bathroom sink running.
I think these have a water pressure s/w or water movement s/w id replace the aerator 1st to a non water saver one or if possible remove water flow reducer looks like a metal washer .. if this not help you may need to replace the pressure s/w...in tank..
May 01, 2011 | Rinnai Water Heaters
I have a rinnai 24 infinity model reu-242w-a. It ison the roof of a 3 storey townhouse we are moving into.Tthere are no remotes. It was working fine on demand until a plumber drained the system on the...
Ask the plumber who did the mods. to come a check that he hasn't crossed a hot/cold pipe. Really sounds like he has, this would cause hot water to mix with cold. Is the water hotter further away from where he did his work? This would be a clue. Easy way to check is to turn off the water to the hot water system, should be a valve on the middle pipe going in to the heater. This should turn off all water to all your hot taps. If you still have water at any hot tap or shower then the pipes have been crossed.
Mar 21, 2011 | Water Heaters
My Rinnai 24 will only start when I use the the hot water in the kitchen (which is closer to the heater). If I open any of the hot water taps in the bathroom it doesn't work.. I have to start the hot water...
Looks like your recirculation pump might be bad. If your opening a valve close enough to the heater and it comes on, It sounds like it's giving your pressure switch a false reading and allowing it to come one while the farther away you get, it is not enough line pressure to overcome the safety's of the heater.
Sep 28, 2010 | Heating & Cooling
My kids just bought an older home w/a rinnai continuum nc-45-4us. right now their house phone isn't installed, so they can't phone, but they can't turn on hot water. any suggestions
Run through the basic checks
  • Power lead from the heater plugged in a socket turned on.
  • Gas on to house
  • All valves below heater in on position.
  • If they have controllers in the house turn on (key pads marked with Rinnai logo in kitchen or bathrooms usually)
There is a turbine that spins in the heater when a hot tap is run. If the heater has been sat for some time not operating the turbine might have stuck. Run the hot tap and keep it running, using a hammer give the centre pipe connection under the heater a firm hit a few times(not too hard). This might unstick the turbine.
Sep 21, 2010 | Rinnai Digital Remote Water Heater Control...
No hot water in sink and shower
it sounds like 1(or more) of the motorised valves arent working.find the valve and make sure you are getting power to it via a tester,if so then it probably needs the head on the motorised valve changed
May 04, 2010 | Rinnai Digital Remote Water Heater Control...
I have installed a 4 gallon inline water heater close to the bathroom. The main hot water heater is at the other end of the house. Now the hot water in the bathroom runs luke warm when the washing machine;...
you don't have a circulating line in it,, there for it is pulling the hot only,, when you have the 2 systems you have to have it circulationg or take 1 out, it being it is hot water they will vapor lock,, meening no hot water , you could get a circulating pump that actually hooks to the cold and hot side under the sink far away from the water heater and it has a timer on it that will circulate the water at certain times of the day,,, this would solve your problem
Jul 02, 2009 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Need to wire a zone control for a closed system with a circulator
thats because the rinnai does not have a set up for a circulating pump it would make the unit run all the time,, they are not designed to work that way,, you will have to just wait for the hot water to get to the faucet just like before,,don't let any one tell you there is a way once the water flows it turn on the tankless so it would never shut off, you could get on that goes on a timer on say the farthest fauset away from the unit and set the timer to come on like 2 min before you are ready to use the water in that bathroom in the morning or at night other then that there is nothing else you can do
Jan 28, 2009 | Rinnai Digital Remote Water Heater Control...
Heating & Cooling Logo
171 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
