Brother DCP-110C All-In-One InkJet Printer
Problem for Brother DCP-110C All-In-One InkJet Printer
Printing blank page
By Friul on Feb 22, 2008
Have recently installed a new set of inks in my brother DCP110C. The 3 colours are working fine but the black ink fails to print despite cleaning the print heads over and over again. What can the problem be? I installed a new Brother black cartridge, but I get a blank page when I try to print. I can print colours but not black. Help
Comments:
Feb 24, 2008
- ...did not work
Feb 27, 2008
- ...still not printing...help...I've installed a new black cartridge...I've Cleaned the cartridge as directed, but still no black print...the other clours are fine
Mar 04, 2008
- yes, I'm using original cartrides
Solution #1
posted on Feb 22, 2008
Somewhat Helpful)
DARKLORD1
Rank: Guru
Rating: 86%, 725 votes
Ok here are a few things to try first, if they fail to work, reply here with the results and we can work from there..
1.) remove the cartridge and blot it on tissue paper to ensure it has ink..
2.) go to the printer preferences
Start / All Programs / Printers and Faxes,,
Right Clik on the printer and click properties
YOUR PRINTER SETTINGS MAY VERY FROM HERE BUT ITS BASICALLY THE SAME PRINCIPAL AND YOU WILL FIND THE FEATURES JUST PROBERALLY IN ANOTHER LOCATION
Click Printing Preferences then maintenance
Click Cartridge settings
Ensure its set to print from both black and color cartridge..
Just find the settings and make sure its set to print from both cartridges..
Let me know how that plays off and we can work from there...
but that should work..
Was this helpful?
Yes
No
Solution #2
posted on Feb 27, 2008
Not Helpful)
Beni S-P
Rank: Guru
Rating: 85%, 2350 votes
Check cartiges if it is correctlly plugget in
Was this helpful?
Yes
No
Solution #3
Not Rated)
eagle338
Rank: Wiz
Rating: 84%, 1653 votes
Make sure you removed the top tab to let air in(probably did.)
Remove the cartridge and make sure the plastic on the
bottom got punctured when you installed it,and the little
piece of plastic isn't caught in the ink port.
Comments:
Feb 27, 2008
- Another possibility is that, maybe your head cleaning pump is not working.Check also for clogged head.Put some "FLUSH" in an injection tube ,remove black cartridge,very carefully put the tube hole in the pin and absolutely slow try to put some quantity of flush inside.If you can do that it's mean that head is not clogged
Feb 27, 2008
- If none of these work it means an internal mechanical defect in your printer. I would take the assistance of tech if this is the case.
Mar 04, 2008
- Hi! Did you try a different color cartridge? The possibility of a faulty cartridge cannot be ruled out..
Was this helpful?
Yes
No
Solution #4
Not Rated)
Astrobyte
Rank: Guru
Rating: 88%, 64 votes
Try this to reset the toner count first:
open front cover, press options and start key.
If that doesn't fix it, try this:
1. press the Menu & Mono start keys. next press the up arrow key 4 times to make the machine enter the maintenance mode.
2. Enter 8 & 0 by using the up arrow key & SET keys.
3. press the mono start key several times untill the purge count appears on the LCD.
4. enter 2 7 8 & 3 by using the up arrow key & set keys to reset the purge count to zero
5. press the stop/exit key to return to the initial stage of the maintanance mode.
6. enter 9 twice by using the up arrow & set key's to exit from maintenance mode
Was this helpful?
Yes
No
Solution #5
Not Rated)
otacon
Rank: Guru
Rating: 89%, 1925 votes
Are you using an original black ink cartridge?
Was this helpful?
Yes
No
Popular Solutions for Brother DCP-110C All-In-One
Questions and Unsolved Problems for Brother DCP-110C All-In-One
Do you recommend Brother DCP-110C All-In-One InkJet Printer?
Answer
Answer
DCP 110C PRINTER IS SWITCHED ON WHEN YOU RUN SCAN IT DOES NOT SEE THE PRINTER I REINSTALLED SOFTWARE... (More)
Answer
why is my printer (dcp-150c (brother)) prints green pictures
Answer
the printer is making a whirling sound and is not printing out there is no paper jamed inside
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in , AK
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
