posted by Landcruiser on Feb 22, 2008
Sirs,
My maytag neptune mah5500bww is leaking water from the bottom. The water is coming out from the middle towards the front. No water leaking out of the bottom towards the rear.
Comment by Landcruiser, posted on Mar 04, 2008
aborcass,
Good call!! The boot was torn right next to the drain hole. I used another fixya posting to guide me thru the removal and re-installation of the new boot. I would recomend the Maytag boot over the after market boot. Saved me some money!! I am passing the link to your website to all of friends that like to "try" to fix there own stuff.
2 Other Users Have The Same Problem
Comment by davemcham, posted on Aug 17, 2008
mine is leaking out of of the door.
Comment by Guest, posted on Mar 04, 2008
Water leading underneath toward front
Rating Locked! (?) Landcruiser has rated this solution as FixYa!
Solution #2
posted on Aug 20, 2008
Here is the solution I found that worked for me, there is a small drain hole at the bottom of the boot that is connected to a drain hose. Remove the hose and clean out to make sure that it has not become plagged. replace hose and reattach boot. Mine stoped leaking imediately.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Maytag Neptune MAH5500B Front Load
Email this problem
Email this problem
Can you Help with these Washing Machines problems?
Maytag Neptune MAH5500B Front Load Washer
Keeps buzzing--won't start
Washer display says... Answer This...
Maytag MAH3000AWW
Maytag MAH3000AWW
My washer does not always... Answer This...
can someone help me please,,,,,...
the ccu board went bad, I put... Answer This...
Maytab Neptune FL washer
the lights on the panel won't... Answer This...
MAH4000AWQ MAYTAG WASHER
The washer starts, fills with... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
Find Parts
