Question about Gateway MX7122 Notebook
I need to replace the power button circuit board on my gateway MX7122 laptop
  • Gateway Master
  • 19,396 Answers
Hi.
The power button circuit board plastic cover is held by clips, and gets removed using carefully a small screwdriver under the hinge cover, after removing the screws at the bottom of the laptop. At least it worked this way on all the Gateway laptops with separate On/Off and button board that I have done. Ensure that you have removed batteries and disconnected power first.
See also instructions at page 43 of this manual.
Once the cover is out, the next step will be testing the switch, by either jumping contacts, or reading impedance. Reading impedance with power off is safer. When switch is pressed the circuit must close and open.
If the problem is the board, and not the button, then proceed removing keyboard, undoing board connector and screws, and replace the board.
More disassembly instructions on manual above.
Part available here.
Regards.
Posted on Feb 07, 2010
Hey i need to purchase a gateway nv53 power board,cable,spring & button cover. I would like where can i purchase it & where to get it fixed.
From a quick search edrence89,
http://www.skyline-eng.com/index.cfm?fuseaction=product.display&Product_ID=7564
http://cgi.ebay.com/GATEWAY-NV52-NV53-NV54-SERIES-POWER-BUTTON-BOARD-/110641410161?pt=LH_DefaultDomain_0
Pictorial disassembly of a Gateway NV53 series Notebook PC,
http://www.insidemylaptop.com/disassemble-gateway-nv-series-laptop-fix-power-jack/
[The Gateway NV5302u is part of the Gateway NV53 series, just as your NV5378u is.
The heading is for replacing the DC Power Jack, but I thought the pictorial guide may come in handy ]
Free Service Manual for the Gateway NV53 series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-gateway
Drop down to the second line in the first paragraph, and click on NV53.
This is a PDF file. It may take up to 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 17, 2011 | Gateway NV5378u Notebook
Hi, any ideas how when I took the hard drive out of the exact laptop.\r\nIt came out of Gateway MX7122. The screen broke on 1 so I took the hard drive out of broken one and put in the good machine that had...
Please reinstall the operating system on the new drive you kept and install ALL drivers. Even after installing all the drivers if you face any problems, there might be some other problem might be present in your laptop.
Hope this helps to you. .
Jun 28, 2011 | Gateway MX7122 Notebook
Are there more than one memory module slots on a gateway mx7122? I can see the one that is accessible from the bottom and it is empty. This laptop will not boot up and the only light that comes on is the...
Yes there are 2 ram/memory slot with a max of 1gig per slot.
If the lap top had gone shut off due to lack of power recently then you may need to reset the bios by taking out the battery on the motherboard "looks like a watch battery." Then leave it out for a few minutes and replace and the computer should boot widows.
Sep 24, 2010 | Gateway MX7122 Notebook
Will not start at times. When it does it shuts down again.
remove the battry for many hours,specially after shutdown and put it back just when you need to working
Jun 19, 2010 | Gateway MX7122 Notebook
Gateway nv52 won't turn on
I also had this problem. I turned it off and it would not turn on. I found the solution. First, extend the laptop screen as far back as it will go. Don't just stop the screen at a ninety degree angle. My laptop screen pulls back to about 135 degrees. Now press the power button. It should start up.
Why do I think this works? Well...I used to own an older model thinkpad that had a short "male" connector on the screen, that when the screen was folded down would enter into a "female" connector on the base of the unit and trigger sleep mode on the unit. This is how the system could automatically hibernate when the screen was closed. The little male connector broke off, and I couldn't get the system to wake up, because the connection to tell the laptop that I had the screen up or down no longer worked. I couldn't even power it up. I had to take an ink pen and push the connector through the female end to indicate to the motherboard that I'd opened the screen before it would even turn on.
It appears that the same type of mechanism is built into the long BAR under the screen of the NV52 and somehow it can't determine when the screen is open or closed. If it detects that the screen has not been opened, it won't power up. This safeguard prevents the laptop from being turned on mistakenly while closed up in your laptop bag. Extending the screen back resets the mechanism and it should turn on. Sorry for the long explanation...
Jan 15, 2010 | Gateway NV5215u Notebook
Borken on/off switch. It is down and will not
please sell it for me your laptop gateway mx7122 my email is rahel_habte@yahoo.com.
Oct 03, 2009 | Gateway MX7122 Notebook
Replacing Power Button Circuit Card on Gateway W730 K8X Laptop
The instructions for replacing the keyboard include the cover you have to remove to replace the power button pcb. The power button pcb is attached to the bottom of the bezel that covers the hinges/button array. In a nutshell you just remove the 2 screws indicated in the instructions, pry the hinge covers up a bit, then gently pry the bezel up from the bottom. remove the ribbon cable, pull back the small piece of tape, remove the three small screws holding the pcb on, and remove it from the spring clips.
Apr 11, 2009 | Gateway Computers & Internet
Power button replace
I had this same problem, it comes from a poor design. I didn't want to pay for a replacement part and I needed it fixed quickly, so I removed the power button assembly and drilled a small hole directly over the power button on the circuit board. Now I have to use a pen or pencil to turn on the computer, but hey it works!
Mar 30, 2009 | Gateway 7405GX Notebook
Gateway MX7122 Notebook Logo
52 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
