My 1988 Burwood battery operated wall clock is acting up. It generally works, but often the hands appear to stick together and stop moving. I've tried opening the face and bending the hands but they still end up getting stuck. I really like this clock and want to use it. Any suggestions?
If you are sure the hands are not touching as they pass, perhaps the minute hand and hour hand are binding together at the hub. Try this: Gently pull on the minute hand by gripping its hub with the nails of your finger and thumb. It should slide forward a little (or come off). Also the same for the hour hand, to ensure it is not binding on the face of the dial.
I don't know the particular clock, but if it has a SECONDS hand, this is often the one that needs to be freed.
If all the hands are free, all should be good. If it has a seconds hand and the clock stops when this hand is going "uphill", try a fresh battery. If this doesn't fix it, remove the seconds hand and use the clock without it. Or you could try to counterbalance the hand by adding a little weight to the opposite side... this could work, but as it increases the mass of the hand also, it still might be a problem.
Another way might be to shorten the seconds hand..!
I was reading the battery replacement procedures for the Garmin Forerunner 50 and have an alternate...
(More)
I was reading the battery replacement procedures for the Garmin Forerunner 50 and have an alternate observation.
To remove the spring clip that hold in the battery and plastic, place your thumb over the middle of the spring and gently press and slide the spring in a 7:30 to 1:30 direction. The spring pops out and the battery can be removed. NO PRYING IS NECESARY. Replace the battery. The spring is replaced by setting the 7:30 end in place and then sliding the 1:30 end in to lock it.(similar to the removal but in reverse). I hope this helps!
I just bought a fairly cheap watch and misplaced the receipt. The hour hand does not work and I need...
(More)
I just bought a fairly cheap watch and misplaced the receipt. The hour hand does not work and I need it repaired. Where should I go and how much do you think it would cost to be repaired?
