Question about Logitech Harmony 880 LCD Remote Control
Remote is not charging while sitting on the charger? Could it need a new battery?
    Novelist:
  • 101 Answers
1) Ensure the cradle is plugged into an active AC outlet and the LED light on the cradle is on. There is a switch on the bottom of the cradle to control the brightness of the LED, set it to the highest. Try different outlets if needed. Does the LED light turn on and stay on (does not blink)?
ANSWER:
2) Remove the battery. Place the remote on the cradle and check the LCD screen. The LCD screen should display a 'White' screen with possible colors before going off. Try this a few times to confirm behavior. Did the LCD turn on briefly?
ANSWER:
3) Reinsert the Battery. Have you charged the battery for at least 3 hours? If no, please recharge the batteries for at least 3 hours.
4) Did the battery ever boot the remote? If yes, please continue troubleshooting.
ANSWER:
5) Remove the battery. Check the 3 gold contacts on the battery to see if there are markings on all the contacts signifying it was connected correctly to the remote. Did the battery have markings on all 3 contacts?
ANSWER:
If you determine this is an issue with the charging cradle, contact logitech with the information below
The PID of the remote:
The P/N of the remote:
The PID of the RF Wireless Extender:
The P/N of the RF Wireless Extender:
Full Name:
Email:
Login ID (Current Login for Harmony Remote Software):
Phone number:
Street:
City/Town:
Country:
Zip/Postal Code:
Please Note: The PID (Product Identification) and P/N (Part Number) for the remote can be found either on the underside of the battery cover, or at the bottom of the battery compartment (the battery might be covering it). Your PID number is a character code with a combination of letters and numbers, starting with either WL, WD, or LZ
Posted on Feb 10, 2010
Red lights on charged but wont go on charger and battery are new
Hard to understand your question, but the battery may need to be cycled. That means 3-12 charge/discharge cycles. Even lithium batteries can get a hard to charge by sitting on a shelf a long time. Make certain it is the correct adaptor for the charger.
Sep 17, 2015 | Radio Communications
Battery just changed, but then went dead. Battery Tender blinks red.
Its possible the charger is telling you the battery is too dead for the charger to work. A safety feature to keep from burning up the charger.
I'm not aware of any fuses between the jumping post and the battery. You may have a short in the car that is draining power.
Mar 05, 2014 | Chrysler Sebring Cars & Trucks
Charging pad the remote batteries are dead, won't hold charge anymore...
Sadly that's how they make the new rechargable batteries for controllers. You are supposed to recycle that and buy new. Luckily you can find chargers for the wii very cheap nowadays. I have used a few different chargers and have found the Nyko brand ones are junk so steer clear of those. The Duracell induction chargers however work very nicely. You just set the wii remote down on the charge pad and it charges fairly quickly. My kids run around and even if the remote shifts a bit it will continue charging. Hope this helps!
Apr 22, 2013 | Nintendo Wii Remote Control 4 Charging...
My wii remopte won't charge. The battery dies and when I try to charge it, it only charges for about 30 seconds then says that it's charged and it's obviously not. (please help, thanks)
Your battery or charger is probably toast - this is the exact same thing my remotes did, so I went to Amazon and bought new batteries and charger - now they work fine. The batteries are designed for so many charges then they die.If, like me, you park your remotes on the charger stand when not in use that counts as charging whether or not the batteries need it so it would be better to lay your remotes next to your Wii or charger base if they don't need charging. Also - charging the batteries when they don't need it can shorten the battery's life, depending on the specific type of battery you bought. Before buying a replacement battery, find out the specific type of battery and whether or not it requires charging before getting low or needs to run out before charging. You can get this info from the seller of the battery. Hope this helps!!
Dec 28, 2010 | Video Game Consoles & Games
My Asus S6F laptop battery wont charge it sits on the charger and when you unplug it the battery its dead even after leaving it on the charger for a couple of days. I have bought new batteries for it but...
1)Reason:
a.The battery has no voltage.
b.There is problem with charger, as it has no output electric current.
c.Low charging efficiency due to external cause.
2)Solutions:
a.Test whether the charger has voltage and output electric current or not.
b.Check if the charger is well contacted with battery.
c.Activate the battery with voltage and current 1.5 time higher then the highest ones of battery. (Use this method only when the battery can't be charged.)
come from laptop battery site:http://www.buy-battery.ca/faq.htm
May 20, 2010 | ASUS S6F Notebook
Dead. When I put on charger I get no response
Generally there are three possibilities (apart from the battery going bad) that can cause your remote not to charge:
1) Some folks have reported that the battery is not sitting tightly enough in the battery compartment. You can try folding a small piece of thin cardboard and place it between the battery and the back of the compartment. This will push the battery towards the front of the compartment and create a tighter connection against the contacts.
2) There have been reports of problems with some of the charging cradles in which the remote does not make sufficient contact with the contacts in the cradle. To ensure that the remote begins to charge, place it in the cradle and listen for a single beep. The slide show2_bing.gif should start and then, after a few moments the screen should darken. If you hear two beeps at any time, it means that the remote has lost contact with the charging cradle and has 'woken' and is no longer in charging mode. Wiggle the remote to ensure that it is sitting in the cradle and making contact.
3) If you still have trouble after you have tried everything above, there may be a loose connection inside the remote itself. There is a very small plug that connects the charging terminals on the remote to the battery compartment. In some cases, this plug can become loose (especially if the remote has been dropped). Opening the remote and checking to make sure that the plug is completely seated is another thing to check if all else fails.
Dec 01, 2009 | Logitech Harmony 880 LCD Remote Control
Batteries don't charge. I have a new battery, and neither of the old or new batteries work in the charger. I get flashing lights only, sometimes red, sometimes green, but in the end, the battery isn't...
Dust getting in the charger is a problem, Try blowing it out with a moisture-free dust remover, found at most any store. Green flashing means improper power, due to dust or power from the outlet, try a differant wall outlet. Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been droped or hit the floor the coil inside could have broke loose and dammaged the charger requiring it to be replaced.
Jul 11, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Can't charge my e-scooter
ok you do not need a new charger. the problem is you let the battery get too low. the battery has to have a little bit of power left in it to send to the charger, if it dosent then the charger can't tell if there is rilly a battery hooked up or not. you shuld probubly get a new battery. or you can email me and i will tell you a few things you could try to jump it back to life.      wildnfuzzy@gmail.com
Jan 24, 2009 | Transport Schwinn Rechargeable Portable ...
Havoc heli will not charge
As far as the green light on the charger not coming on: after I tested the batteries in the remote, I found that it was due to 2 of the 6 batteries in the remote control being dead (0.1volts) The charger probably sucks the power out of the #1 and #6 battery.
Make sure all batteries in the Remote have the same charge.
Also, there seems to be a loose contact in the charger plug prongs. You will have to find a way to sit the helicopter so that it stays in contact with the prongs while charging. Mine has to be on it's side to keep the green charger light on.
Dec 26, 2008 | Air Hogs Havoc Heli Helicopters
Mx 3000 universal lcd remote
There are 4 reasons why your unit is behaving this way:
1. Charger is the problem.
2. The docking station is the broken.
3. The battery is broken or not accepting charge.
4. The actual unit is the problem.
It is very hard to tell which one is causing this to happen.
Let us do some troubleshooting first:
1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken.
2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken.
3. If the red power light is lit and the status light (right) is lit too, your docking station is broken.
4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged.
5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
Aug 29, 2008 | Universal Remote Control MX-3000 LCD...
Logitech Harmony 880 LCD Remote Control Logo
408 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
Jerry Umali
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
