Question about Acer AL1916W 19" LCD Monitor
Noise High pitched squeaking noise coming from inside back panel.
  • 11,361 Answers
First place to look will be power supply, look for caps with bulging top first, report back what you see so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Posted on Feb 08, 2010
Magic chef dryer making very loud noise as it turns, how to get the bottom off
No need to take the bottom off - the top, front, and back come off - if the noise is a rather high pitched squeak the pads on the drum are worn out, if it sounds like a squeak but more metallic/raspy sound check the motor bearings, also check the drive belt.
Oct 13, 2014 | Dryers
Dryer makes a squeaking/high pitch rubbing noise
bad drum bearing, bad drum teflon pads or both possibly
or both possibly or in combination the belt could need replacing
& if your not sure get a service tech so you dont do more damage
Apr 06, 2014 | GE DVLR223 Dryers
My Asko font loader is 9 years old. just lately it has been making a high pitch squeaking type of noise each time the machine is turning during the washing cycle. It did this in the first six months of...
Hello, as far as your unit makeing a high pitched squeaking noise you would have to remove the top panel of the machine by unscrewing the 2-3 screws along the back upper part of the machine. You would then slide the panel towards the rear of the machine and then remove the panel from the machine. After you did this you would then run the machine and try to distinguish if the noise was being made from the main bearing in the unit which holds the inner and outter tub together. Or if the noise were coming from the motor in the unit. Most of the time when someone does describe a high pitched noise that is described like a jet taking off when the unit goes into the spin cycle this would tend to point towards a main bearing issue with the unit. To replace a main bearing in a washer is a very costly and long proces if done by a technician and most do decide not to fix the unit due to this. On the other hand if it were a motor noise that you were hearing or a pulley noise which on some is located on the back of the tub these are much less costly repairs as well as less time consuming. If you have any other questions message me back. I await your reply
Thank you,
Rick
Nov 27, 2011 | Asko W6661 Front Load Washer
Have tumble dryer that makes high pitched squeak before it reverses direction sometimes. not all. took back and panels off to try and isolate where sound coming from but cant seem to locate.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 25, 2010 | Dryers
Dryer makes a high pitch squeaking noise
This could be a dry support bearing, a dried out drum seal or something stuck in the drum seal. If I could hear it I would know better where to start. Listen and try to locate the source from the above list. It could be the belt but that is not as common.
Eric
May 20, 2010 | Dryers
High pitched noise from inside the TV when picture comes on
Hello randapaint,
This might be from the IHVT (Integrated High Voltage Transformer), or more specifically a short in the IHVT causing it to arc, producing the high pitched whine, you are hearing. Take the back off of the TV and try to detect where the sound is coming from, more then likely you will notice it coming from the section that contains a large component with a large red cable coming from it, to the top of the CRT (picture tube). Replace the IHVT (with the exact same model) if it is bad.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Apr 07, 2009 | Televison & Video
High pitch squeaking noise at idle
you might need a stethiscope to hear where this is coming from could be a idler or maybe the tensioner or maybe the alternator .. none of these would bother power
Jan 25, 2009 | 2007 Mercury Hybrid 4WD Hybrid
High Pitched Noise on TV
THIS NOISE IS NORMAL. IS THE DEGAUSING COIL
Sep 16, 2007 | Televison & Video
Squeak
The high pitch squeal you hear is usually caused by a coil vibrating, normally in the horizontal circuit. I've also seen the ferrite bead on the horizontal output transistor do this, but, it is rare. I normally will repair this by finding the coil and "tightening" it. To tighten a coil, technicians use different chemicals, such as, a hot glue gun, rubber silicone or even finger nail polish. I will find the coil that screams by starting with the usual suspects and using a wooden dowel, barely touch the coil and if the pitch of the noise changes, then, thats the coil that needs repaired. If you do not know your way around the inside of a television, I never recommend you do so, since, this procedure must be done with the set turned on and you poke your hands around the inside of the set by the high voltage circuit. Hope this helps your decision.
Mar 01, 2007 | RCA 27F650T 27" TV
Acer AL1916W 19" LCD Monitor Logo
210 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
