Question about Acer Ferrari 4000 Notebook
Computer shutdown this computer will go no farther than saying across the blac screen General Protection Fault... What do I do?
  • 520 Answers
Reinstall windows,use repair if you want to keep previous data but I would choose fresh copy(both options take about the same time)so may as well have fresh clean copy.
Posted on Feb 22, 2008
Aspire 9500
This issue sometime occur when the system detected hardware problem. sometime this was cause by the memory problem, maybe u can cure this cleaning the memory or maybe replacing it.
If ever the newly installed hardware can cause also this error. in this case reformatting and reinstallation is very effective.
The VGA also is another cuase of this problem, please try cleaning the VGA card if ever it is add on.
Feb 02, 2008 | Acer Aspire 9500 Notebook
Dell dimention E310 green light will go on and off
You turned off the surge protection....Ummm did you remove the plug from the wall after doing this?. If you did then it has become corrupted due to a bad shutdown meaning that the system had not fully shutdown when power was turned off which has corrupted the data stored on the MBR ( Master Boot Record ) but I do not understand why you can not restore from a previous good known configuration. If you have a recovery disk or windows os boot disk try to repair it, if it will stay on long enough that is.
If you turned off the surge protection and did not remove the plug from the wall because you turned off the surge protection it is not available to protect your devices etc and in turn a lightening strike close enough will fry the computer due to EMP ( Electro Magnetic Pulse )
You may need to have a qualified person look at it but if it has been fried due to EMP sorry to say but you can say goodbye to the computer as it will not be repairable, You may be able to reuse the case as long as you use another Dell motherboard as Dell have an unusual way of mounting the M/B ( Motherboard ). I hope this helps.
Oct 18, 2012 | Dell Dimension™ E310 PC Desktop
I keep the message General Protection fault with a black screen when I turn my acer aspire 3000 on and it won't go past that screen/What can I do to fix it?
To repair corrupted system file/s, boot up with the Windows installation CD then -
Press R to repair when instructed.
Press 1 or Enter to repair the C:\Windows folder.
Then type chkdsk /r and then press Enter.
The repair process will take quite a long time.
Jun 16, 2012 | Acer Aspire 3000 Notebook
Throws an error on running wheelman game.
General Protection error usually occurs when the serial key is not original or the game is pirated.
This can be removed by installing a wheelman crack from the internet.
Mar 17, 2010 | Video Game Consoles & Games
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
My pc shows general protection fault
This fault can arise from any number of scenarios. You need to specify what you did prior to the onset of the message. To attempt a solution, you may want to
1. uninstall any software that put it prior to the problem.
2. scan your system for spyware, rootkits, viruses. No telling what these malicious codes can do.
For further information please visit the Wikipedia link:
http://en.wikipedia.org/wiki/General_protection_fault
Regards
Jan 04, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Trap 0000000D =========== General Protection Fault ============
Trap is the one of the hardware intrupt..this means u have any hardware prob.
Mar 28, 2009 | Dell Latitude C500 Notebook
Blue blinking light
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Jan 10, 2009 | Samsung SyncMaster 930B 19" LCD Flat Panel...
GEneral protection fault
You probably should get a new HD like 24 seven mentioned. It's your best bet. But youo should try to get like a 10GB HD off Ebay just to test. If it works from there, Get whatever size HD you want.
Jun 11, 2008 | Computers & Internet
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
