Question about Microsoft Zune JS8-00001 Digital Media Player
BACKLIGHT WHEN I TURN ON MY ZUNE IT LOADS UP AFTER THAT IT ONLY SHOWS THE BACKLIGHT
  • 58 Answers
The best thing to do would be to start from scratch... Turn off the zune by holding down and back.
then hit play to turn it back on... as it's loading hold the center button left and back at the same time... this will remove everything from the harddrive... after that you will see a message saying to connect your zune to a computer with the Zune software...
so plug it in... the software will see the Zune and tell you that you need to install the lastest version of the firmware... it will install and should work after that
Posted on Mar 13, 2008
  • Sarah Harmon Mar 05, 2013
    Didn't work for mine! :-/
My zune 32gb hd wont turn on
won't come on has black screen with backlight
May 25, 2011 | Microsoft Zune JS8-00001 Digital Media...
Zune will not turn on
1. If the Zune device is not connected to a power source, set the Hold switch to unlocked. Then, press and hold the Play/Pause button to turn off the device. • If this does not work, restart the device. To restart the device, set the Hold switch to the unlocked position, and then press and hold the Back button zune_button_back.gif as you press the top of the Zune Pad. When the device begins to reset, you can release the buttons. 2. If the Zune device is connected to a power source, it is operating correctly. You cannot manually turn off the Zune device. Note Depending on how you configured your backlight setting, the backlight for the Zune device may automatically turn off in this situation. To access the backlight options, select display on the settings menu, and then press the center of the Zune pad. To adjust the setting, select backlight, and then press the center of the Zune pad.
Mar 21, 2008 | Audio Players & Recorders
My zune wont turn on it just has the back light on ive tried to plug it in re start it just nothing works yestur day the zune logo came on but then went right back to backlight and black screen
Try manually rebooting the Zune by holding the back button and the up direction on the pad for several seconds. Let go of the buttons when you see it restart.
Apr 08, 2011 | Microsoft Zune JS8-00001 Digital Media...
120GB Zune wont turn on
Please try to hold Back, Center and Left at the same time to restore the zune,
Jun 02, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My zune just stopped working
run the battery completey dead or you could possibly reset the device to factory default...
Try this....
Reset Zune: Press and hold the back button while pressing up on the control pad.
Connect Zune to a power source: If the Zune device is in sleep mode, this action will wake the Zune device and turn it on. If the battery does not have a charge, you may have to wait several minutes for the Zune device to turn on.
Also, make sure that the hold button on top of your zune is turned to the off position.
Hope this helps!
Mar 22, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My Zune will not light up.
There is an issue with the backlight of your screen. Sorry but your screen probably needs to be replaced. There are third party Zune repair services, that will fix it for cheap. Even better, I found an DYI Zune repair guide,so you can do it yourself too, not that difficult. Part is available on Ebay. If you can't do it yourself, have a tech savy friend do it for you. If it does work on a different PC, then the issue lies within your windows. If you re-install your PC to factory and then re-install fresh zune software it should work.
Jan 06, 2009 | Microsoft Zune JS8-00001 Digital Media...
Backlight doesn't come on
if the back light is not coming on then the backlight is eather bad or is not getting power from the circuit board.
Dec 31, 2008 | Microsoft Zune 2nd Generation Digital...
Zune blank screen
my zune had the same problem. but i found a solution. hold the down button and the return key at the same time for 5 seconds. make sure you dont hold the up key while doing this because it will reformat your zune. i havnt tried the reformat but thats what i heard
May 14, 2008 | Microsoft Zune JS8-00001 Digital Media...
Microsoft Zune JS8-00001 Digital Media Player Logo
124 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
